BMW M2 Forum > BMW M2 Discussions > 0-60, particularly in a manual
      05-23-2020, 01:13 PM   #45
trey100
trey100's Avatar
Drives: 2020 M2 Competition
Originally Posted by SeanWRT View Post
This is the 0-100kph(0-62mph) time what I got a few weeks back.
0-60mph would be 3.9ish.
Ambient Temp was about 100F. It's really all about traction.
The difference must be the shift. Your 0-30 mph (0-50 kph) was only .15-.2 different than his but the 0-60 mph is off by a full second.
For reference on my 6MT M3, best i could do using the M app was 0-60 in 4.6 but most were 5.0+. Just the nature of a manual in a car with a lot of torque that comes on all at once combined with what I believe is a suspension that has a hard time putting power down.
      05-26-2020, 06:46 PM   #46
Nezil
Nezil's Avatar
1404
Drives: LCI '18 6MT M2
Sorry guys... it is the shift... and it's not the shift.
I've posted about this in another thread here, but it's an artificial delay the DME imposes between shifts on 6MT cars, both N55 and S55.
My testing, which you can see in this thread, suggests (with a lot of data), that there is a 2 second delay in waste-gate behaviour started from when you first lift off the gas for the shift. The waste-gate doesn't fully close until this 2 second duration is up, and that slows the rate of boost spooling.
Shifting faster actually makes the situation worse, not better, because you'll feel the delay for longer.
Shifting quickly at higher RPM can mask the situation because less boost will be lost between your shift, but logs show that it's still there.
I've been working with a tuner to eliminate this delay, and it's going really well. I'm basically on the base map from my tuner intended as a starting point for 91 AKI fuel, combined with changes focussing on this waste gate delay and lost boost between shifts. My tuner is still trying to make it more consistent, but it's already about holding boost between 2nd to 3rd shifts about 80% of the time, and 3rd to 4th shifts about 50% of the time. Butt dyne and Draggy data show that the car is way faster once the shift delay is eliminated.
I went for a drive to run some errands over the weekend with the Draggy running, and only just now looked at my data. I stated in this thread that my previous best was 5.12s I believe, but without really trying that hard I now have valid draggy from street 0-60 of 4.45, 4.48 and 4.47 (1ft). Screen captures below:
Of course, I cannot explain how R&T testers were able to achieve their results, but I actually suspect BMW may have had custom flash for the DME on those cars.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings
ZPrime611.50
JustChris17489.00
      05-28-2020, 03:54 AM   #47
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
... fascinating.
Nezil, prior to messing with a tune, what mode did you have the car in when testing 0-60? Full DSC-off, or something else?
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice.
I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway.
I'm also a fan of aural pleasure.
      05-28-2020, 06:57 AM   #48
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
The only way to avoid the delay is to keep the foot on throttle while clutching in to shift. Not good for the clutch, but gets rid of the boost delay.
      05-29-2020, 09:05 PM   #49
trey100
trey100's Avatar
In your case it looks more like the 0-30 time slowing you down. In one case as high as 2.5 seconds. Tough cars to launch with a manual.
      05-31-2020, 11:01 AM   #50
Nezil
Nezil's Avatar
1404
Originally Posted by ZPrime View Post
... fascinating.
I think I tried everything. In the end Sport+ is usually best if you have a good DSC coding. It allows slip and has aggressive throttle mapping. DSC off would probably be good too; if you have DSC come on, the run will probably be bad, if you spin too much it will be bad also. The important thing is to not be in a mode where DSC cuts in unnecessarily.
      05-31-2020, 11:02 AM   #51
Nezil
Nezil's Avatar
1404
Yes. You’re right. I have a feeling that this is what journalists did to get their times.
It really doesn’t feel good though!
      05-31-2020, 11:06 AM   #52
Nezil
Nezil's Avatar
1404
trey100... you make a good point, but I think you’re missing mine. My point is that the lag between 1st and 2nd has been reduced, and I’m not able to get ~4.5s without much trying. If I kept trying, or had Sport Cup 2 tires, I might be able to improve the 0~30 time, but the fact that I’m getting respectable, repeatable times even with less than stellar 0~30 further reinforces the point that there is a 2s DME delay between shifts in 6MT cars.
      05-31-2020, 09:23 PM   #53
trey100
trey100's Avatar
trey100... you make a good point, but I think you're missing mine. My point is that the lag between 1st and 2nd has been reduced, and I'm not able to get ~4.5s without much trying. If I kept trying, or had Sport Cup 2 tires, I might be able to improve the 0~30 time, but the fact that I'm getting respectable, repeatable times even with less than stellar 0~30 further reinforces the point that there is a 2s DME delay between shifts in 6MT cars.
But if your 0-30 would have been 1.8-2 seconds, you'd have a phenomenal 0-60 time. So why blame the delay rather than the poor 0-30? I feel the delay, trust me, but it is not 2 seconds. If it were 2 seconds and your 0-30 time is 2.5, that is 4.5 seconds right there. 0-60 would be 6.5+. So is there a delay, sure, but I find It to be minor in sport plus with fast shifts, maybe 50% of the time.
      06-01-2020, 03:39 PM   #54
TrentMeister
TrentMeister's Avatar
2860
Drives: g82 comp
This makes me excited 😂
That feeling is the bane of the 6mt driving experience with these cars
Really looking forward to the final product you guys put together!
It would be cool if somehow it could be coded out with BM3
      06-02-2020, 08:38 PM   #55
Nezil
Nezil's Avatar
1404
Check out my logs in the Lag between shifts thread I started... I don't mean that the delay costs you 2 seconds in 0-60, rather that the WG behaviour is delayed for 2 seconds. It does close 80% after the shift, so it costs you maybe 0.4 ~ 0.5 seconds tops.
Shifting faster is quicker overall, but the delay is from the time you come off the gas not from the time you get back on it after the shift. Shifting quicker therefore makes the delayed waste gate behaviour more apparent because it happens for longer after you're back on the gas. It's quicker because you loose less boost if you shift quickly.
On the N55 and probably S55, shifting quickly above 6,500 masks the delayed waste gate behaviour because less boost is lost and it rises quickly to the point at which 80% WGDC would be correct anyway. The delayed waste gate behaviour is still there, but it's masked.
BruceM985.50
trey1001125.00
m2
