2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics M240 F23 Convertible Boot Installed Subwoofer
      10-09-2023, 07:01 AM   #1
Ketax
Drives: BMW M240i F23
Post M240 F23 Convertible Boot Installed Subwoofer
Hello,
I would like to install a 12" low profile sub in the boot of my F23 convertible as this is the only size i can fit in there. I plan to install the 4" Focal speakers front+rear with the Focal 8" under seat subs.
I would like more bass than this so also want the 12" sub in the boot but i am concerned with it being a convertible that i won't get much bass from the sub in the boot (both with the roof up or down)
Has anyone tried similar and have any advice for me?
Thanks.
      11-15-2023, 01:35 AM   #2
jose.munoz
Drives: 228xi
I would also like to get some insight on this
      11-30-2023, 08:10 PM   #3
O Stater
O Stater's Avatar
Drives: 2017 M240i
I have the M240 coupe and stuffed a full size JL 12W3v3 in it with a 1.25cuft box, but I also have a JL 13TW5v1 in my Tundra. The 13 hits harder and lower than the full size. Granted I have a zapco 750watt amp on the 13 and only a 600watt JL on my 12. All that said, yes you lose bass if you use a sealed box in the boot! I would get the JL12TW3 and put it in a ported box if you can find a way to vent the port into your cabin. Thank me later!
Edit: I would get the Morel drop ins over the Focals or just put a good amp on your HK's if your car has them. I put in a JLVXi 600/6 amp on the morels and love them. If you need some HK, I'll sell the ones I removed from my car.
      12-02-2023, 01:17 PM   #4
audiovert
Drives: f23 cabrio
info
adding a sub with box will always be a compromise.
another war is to use custom built stealth boxes made by visual ice here in the uk.
there not cheap £160.00gbp
12"s are too much as the depth they need to be they would be too much.
10"s are perfect tho.
ive ordered 2 pods,1 each side for f23.
il post results soon as i get them.
1 sub may be enough, but 2 guarantees better results.
      12-08-2023, 05:02 PM   #5
O Stater
O Stater's Avatar
Drives: 2017 M240i
If you are getting a Visual Ice box, make sure you not only communicate to him what woofer you are using but also what the box volume needs to be. I ordered one from him for my F22 Coupe and specifically told him what woofer I planned to use. He built it to accept the 12" woofer but he didn't build it with the required volume. It came at .8 cuft and I needed 1.25 cuft. I had to cut it apart and rebuild it to my needed volume. I don't blame him, I should have been explicit on the size I needed and that is all I am suggesting you do.
      12-09-2023, 01:59 PM   #6
audiovert
Drives: f23 cabrio
reply
when considering what size speaker to use i did communicate with visual ice.
he recommended me not to use a 12" as his builds dont give the the volume required that the sub box needs to be.
so i ordered 2 x 10s
      12-11-2023, 11:48 AM   #7
O Stater
O Stater's Avatar
Drives: 2017 M240i
Sounds like you got this!
      12-14-2023, 12:23 PM   #8
audiovert
Drives: f23 cabrio
info
thanks stater
il report on here when done
      12-17-2023, 12:10 AM   #9
O Stater
O Stater's Avatar
Drives: 2017 M240i
thanks stater
Post pics as well
      12-18-2023, 01:30 PM   #10
audiovert
Drives: f23 cabrio
sub pic
heres the sub waiting for enclosure
      12-18-2023, 01:50 PM   #11
audiovert
Drives: f23 cabrio
other sub
heres the other sub
      01-28-2024, 01:52 PM   #12
audiovert
Drives: f23 cabrio
info
https://share.icloud.com/photos/069D...iaV7_M_mGWEFsA
