2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning 2014 m235i engine seized?
      01-06-2021, 04:47 AM   #1
webjuice
Drives: m235i
Exclamation 2014 m235i engine seized?
Hi Guys,
I recently had an oil leak coming from the oil filter. I checked the oil level and came up below halfway. I topped up 1L and drove to work and booked in service for that same afternoon. I drove very lightly to a mechanic about 30min drive away and he then informs me that it had less than 1L of oil.
I get the car back and 1 day later the engine light turns on. I call my mechanic and tells me it's most likely a short in some electricals because he degreased the engine bay and washed it down because oil ended up all over the place. Unfortunately, this was on Christmas so he and everyone else was closed so I could do nothing about it. I drove the car for 2 days, very lightly, and was running much smoother and more responsive. I decided to "give it a little" nothing too strenuous and nothing I haven't done before. The engine turned off on me. I turn it back on, it was a very rough start and then died on me again. Did this one more time, got 20m, and died. It won't start at all now. Tried to manually crank the engine, no luck.
My mechanic is dumbfounded and everyone I speak to is pointing to the engine seizing or a spun bearing. I'm no mechanic, nor do I know what a spun bearing is lol - I'm now looking for an experienced BMW specialist.
Does anyone have any idea what this could be?
Thanks
Steve
      01-06-2021, 12:58 PM   #2
jb-slow
Drives: m235i
The engine will still run with a spun bearing, it will sound terrible though
      01-06-2021, 02:27 PM   #3
overcoil
Drives: M235i 6spd
I didn't think was a good idea to wash down these engines. I think it's electrical.
      01-06-2021, 04:19 PM   #4
cooolone2
cooolone2's Avatar
625
Degreasing an engine isn't uncommon and if done correctly, shouldn't be an issue as all eletrical sensors and such get covered.
That said, there were no warning lights? CEL? Because even with the low oil something should've came on. And yes, spun bearings don't seize engines, it could wreck them though... So don't drive it.
      01-06-2021, 04:59 PM   #5
Fudz
Drives: 2015 435I 8speed
Did he fix the leak at the oil filter housing ?
      01-06-2021, 08:55 PM   #6
MidwayMuller
MidwayMuller's Avatar
36
Drives: BMW M235i
I had a similar leak happen when I first got the car. Caught it in time before anything serious happened, but it caused issues later on. It was due to using an aftermarket mobil1 filter- the large o-ring is a different thickness from OEM and doesn't create a proper seal, even when the cap is torqued to spec (25+5nM)
Check the belt and signs for pulley wobble. The oil may have gotten into the lower MAP sensor, camshaft position sensor, the alternator windings or many of the main lines leading to the alternator.
Main voltage might not be getting properly supplied to the computer or sensors. Whether that's due to the oil bridging contacts or burning something out completely will take a good amount of troubleshooting.
      01-06-2021, 10:22 PM   #7
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
It's not uncommon for engine seizing when doing OFHG replacement
https://www.1addicts.com/forums/show....php?t=1537202
https://x3.xbimmers.com/forums/showthread.php?t=1582839
      01-20-2023, 08:38 PM   #8
seansurfn2
Drives: 2014 M235i m-sport
Just had this happen to me after getting an oil pan gasket replaced. Crankshaft is seized up suddenly.
      01-21-2023, 06:14 PM   #9
jb-slow
Drives: m235i
How is that even possible? Did they break off the oil pickup or something?
      01-24-2023, 04:01 PM   #10
XutvJet
Oil pump cavitation. BMW is very aware of this issue when major engine service is done, oil pan gasket replacements, and oil filter housing gaskets.
BMW issued a TSB noting that the oil pump needs to be primed using the following procedure after completing work like this. See page 2 of the TSB regarding oil pan gasket replacements, and oil filter housing gaskets.
https://static.nhtsa.gov/odi/tsbs/20...51166-9999.pdf
      01-24-2023, 04:02 PM   #11
XutvJet
Did a BMW dealer do the work or did you or an independent shop do the work? The oil pump should have been primed after the repair.
      01-24-2023, 06:53 PM   #12
jb-slow
Drives: m235i
Crazy, I've done the ofhg, oil cooler gasket twice, and had the pan off for a baffle install and never primed anything, no issues at all.
Tags
n55 m235i, seized
