04-04-2017, 04:37 AM | #1 |
Rep 350
FBO/JB4 Torco (Accelerator)
2015 M235XI
FBO/F Series JB4 w EWG/FF Latest firmware(v11) 92 Pump+Torco I know ill need to post some logs WOT 3rd gear but I didnt have time that day and will post on N54 when possible. Anyways, I threw in some Torco Accelerator mixed with 10g 92 pump (shell v-power).. This should have put me in the 103 ballpark. Ran the car 30mins on MAP5 and did a few pulls while cruising to allow for adaptation. Once I had the car nice and adjusted I met up for some 1/4 mi races. Heres where I put it in MAP7 and let her go. I know I should have logged first but I thought what the heck, ill check the logs later after a few runs. The car ran extremely well, and well lets say I could see a Chevy SS, and Camaro Z71(headers) in the rear view. I came here to post up my experience and wanted to hear from others with experience running Torco(accelerator) and JB4? Should I stick to MAP7 or is this to aggressive? After looking at my logs all the values looked normal to me but Im worried if MAP7 is to aggressive for my Fuel Pumps and or stock turbo? Any issues running the Torco every couple weeks? Graph shown for any feedback.(from DIG) JB4 showed max boost at 19-20psi. (Bad for stock turbo??) |
04-04-2017, 05:34 PM | #2 |
Rep 1,184
You want to look at your fuel trims and hpfp values. I was running map 7 for a while fbo w3.2 gallons of e85.
My fuel pump was straining a little bit but not terribly. If your trims are reading 49 for a portion of time or if your hpfp drops below 11 you may have issues. I was hitting 17.5 psi and it felt pretty beast. |
04-04-2017, 10:36 PM | #3 | |
Rep 350
MAP7 sure does feel pretty beast and and the car has never had an issue. Im just concerned for the stock turbo, im not sure if 18-20psi is pushing to much when I run from a dig. Can anyone say if I were to run this setup/fuel and purchase a meth kit it would be to aggressive? Im guessing I would run map3 then but would meth + 103 be to aggressive for the turbo? I would only be interested in adding meth for top end increase? |
04-05-2017, 06:37 AM | #4 | |
Rep 1,184
I am not sure how running 20 psi is for the stock turbo longevity wise, maybe someone will chime in on that? As fast as adding methanol you are not only increasing octane, but also cooling. From what I understand you could be running the same psi, but with better timing and get more power and a better power curve. |
FSociety3812.50 |
04-05-2017, 06:42 AM | #5 |
Rep 1,184
[QUOTE=SerenVoX;21515627]2015 M235XI
FBO/F Series JB4 w EWG/FF Latest firmware(v11) 92 Pump+Torco I know ill need to post some logs WOT 3rd gear but I didnt have time that day and will post on N54 when possible. Anyways, I threw in some Torco Accelerator mixed with 10g 92 pump (shell v-power).. This should have put me in the 103 ballpark. Ran the car 30mins on MAP5 and did a few pulls while cruising to allow for adaptation. Once I had the car nice and adjusted I met up for some 1/4 mi races. Heres where I put it in MAP7 and let her go. I know I should have logged first but I thought what the heck, ill check the logs later after a few runs. The car ran extremely well, and well lets say I could see a Chevy SS, and Camaro Z71(headers) in the rear view. What years were the Camaro and ss? I'm trying to get an idea how I'll run against my buddies c7. He's been busting my balls ever since he got it. |
04-05-2017, 11:42 AM | #6 | |
Rep 350
[QUOTE=jmwilson125;21521269]
**(Just gonna disclose that there are zero tracks in this area and these races are well organized on a private road. Just enjoy the video please. )** 2015 M235XI FBO/JB4 VS. 2015 C7 V8 Supercharged (LT4) Stock CHEVY SS (Stock) Camaro Z28 (Headers) Last edited by SerenVoX; 04-07-2017 at 01:15 AM.. |
04-05-2017, 04:48 PM | #7 | |
Rep 1,184
[QUOTE=SerenVoX;21522560]
04-05-2017, 09:59 PM | #8 | |
Rep 350
[QUOTE=jmwilson125;21524156]
04-06-2017, 06:42 AM | #9 | |
Rep 1,184
[QUOTE=SerenVoX;21525308]
I have not put it on. The dyno yet. I'd like to, but to do it properly I'd like to do 3 runs on each map and take an average of each. I'd rather just save my money at that point though. Spending hundreds for a couple prints outs of numbers is not in my list of things to do right now. |
SerenVoX146.00 |
04-06-2017, 08:51 PM | #10 | |
IG @bmwF9xG80
3813
Rep 7,593
Baseline + Tune = Delta is what you're looking for
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
04-07-2017, 05:47 AM | #11 | |
Rep 1,184
Don't get me wrong. I'd love to do it I just don't want to spend the cash. In my mind the wat to do it would be 3 runs stock, 3 in map 2, 3 in map 3, and 3 in map 7. Then take the average of each set. That would be a lot of dyno time. |
04-07-2017, 09:27 AM | #12 |
IG @bmwF9xG80
3813
Rep 7,593
Even if you're not running a Custom Tune, dyno is still safer than the inconsistency you get from street logging. Plus on the dyno you will be able to achieve it quicker because you can turn off car cool off analyze log and continue. I've been street logging JB4 before and finding empty road, etc etc makes it harder and longer.
But hey its your money and your car , plenty of ppl wondering why their car is losing or not making proper power band because all they think is street log is what they need. Just think about it, how do you think some Tuners (the good ones) develop their solid tunes? is 99% on the controlled environment and then taking it to the street to see how it feels afterwards. Tuning is not to cheap out on (everyone buys FBO parts right, so why cheap out on a Dyno), and I'm not talking going to Dyno for 3 pulls where you can pay the same to rent dyno for 1hr. If you're adding in Meth do it the right. Rent a dyno for 1-2hrs and you'll be happy.
