02-15-2017, 11:03 AM | #1 |
Rep 647
Coolant Loss (opinions needed)
On 8-10-16 I topped up my coolant from Min to Max which is roughly 14ozs or so. Thought it was odd but not unheard of and figured it may not have been topped since car was delivered. I am the 2nd owner of the vehicle for historical reasons and i purchased from a private seller in Oct of 15 with 14,000 mi. I just checked the coolant again yesterday cold of course and just above the Min line again. I topped up again which needed about 14ozs. I have never noticed milky oil or oil in expansion tank. I dipped a piece of paper towel in exp. tank and comes out perfectly blue. There were a few tiny specs of blk deposits but chalked that up to fine debris from the coolant system. I have not pulled plugs yet but planned to replace them soon anyhow. I am running an ER catless D.P. And armytrix exhaust so what smoke/moisture is coming out doesn't seem out of place. Im thinking something is leaking in the engine bay but have never noticed anything. I want to avoid stripping parts off my car to take to the dealer. I plan to open the exp. tank lid and run the car looking for bubbles in the tank but dont suspect i will find any. I have done leak downs and compression checks before but this car seems a bit more complex. Any advise would be greatly appreciated. FYI. I do not drive the car very often the first top up was prob at 18,000 mi and now im close to 22,000. any advise would be greatly appreciated.
02-15-2017, 12:40 PM | #2 |
Rep 5,577
Other people have also suspected coolant loss.
First thing I would not top off the coolant if the level is at the minimum line and would only top off of the coolant was significantly low or none in the expansion tank. The cooling system in the 235 is more complex and therefore more susceptible to wider range of levels - I understand you added coolant 4K mikes back but that amount and level can throw you depending on ambient temp. |
Drpoomanchu307.50 Taunto281.50 |
02-15-2017, 12:53 PM | #3 | |
Rep 647
02-15-2017, 01:43 PM | #4 |
Rep 5,577
I would not draw coolant, there is nothing wrong with going to the MAXIMUM level, but if you filled to the very top of the overflow tank that could be messy or interfere with the pressure cap.
I do think like most liquids, internal engine temps along with ambient temps, mean the coolant level can fluctuate and as long as between MIN and MAX the system is fine. Also it's normal with increased mileage to get oil droplets in the coolant, when things look like chocolate-milk then you have an issue. |
02-15-2017, 02:14 PM | #5 |
Rep 1,117
Drives: 2015 BMW M235i
I don't think that amount of coolant adding is normal at all for any mileage. Mine is coming up on 23k miles and my levels haven't moved when warm or cold. Could you take it to a good indy shop so you don't have to remove the mods? Do you run anything to monitor temps? With the coolant levels changing so much I would imagine swings in oil or coolant temps as well..keep us posted!
Also, are you running high boost? Could be a gasket leak. Last edited by amw896; 02-15-2017 at 02:37 PM.. Reason: typo |
Drpoomanchu307.50 |
02-15-2017, 02:43 PM | #6 | |
Rep 647
02-15-2017, 03:43 PM | #8 |
Rep 5,577
You do know the car has a coolant level sensor, I'm not even sure the sensor is in the overflow tank, it could even be down by the lower radiator hose - and that gives you some idea how much coolant can drop before a warning appears.
I googled BMW coolant level and it seems coolant drop is so common some dealers keep a 50/50 mix out by the service writers desk. I guess anything is possible but your coolant drop reads to be minimal and usual. |
02-15-2017, 03:47 PM | #9 | |
Rep 647
02-15-2017, 06:41 PM | #11 |
Rep 647
02-16-2017, 07:29 PM | #12 |
Car Enthusiast
282
Rep 501
This amount of coolant loss is typically normal and should try and carry some spare coolant from the dealer around with you if possible.
Coolant loss can happen through evaporation in small amounts of time. If your loosing alot of coolant, then i would have it looked at for any leaks. On a side note, if the engine is cold - and the coolant is on or just slightly above the MIN mark - your doing fine.. that is normal and where the coolant level should be at. Coolant level should be around Max mark when vehicle is at operating temp. if your concerned about it tho, doesn't hurt to take it into the dealership and have them inspect for a coolant leak and express your concern about it, wouldn't hurt and could supply a peace of mind as well.
2016 M235 - Melbourne Red
Drpoomanchu307.50 |
02-16-2017, 09:17 PM | #13 | |
Rep 647
02-16-2017, 11:10 PM | #14 |
Car Enthusiast
282
Rep 501
You Should typically never take it off when its warm. If you do tho, unscew it slowly and let the air slowly bleed off before unscrewing it completely. if it's warm onscrew it like half turn at most i think.. if you do it fast and its hot and under alot of pressure, it can pop off and damage the cap and possibly the tank it's self.
