11-03-2016, 07:38 PM | #1 |
Rep 211
Wagner intercoolers: which one should I choose?
Hello everyone. I can't decide which wagner intercooler to install. I hope some of you can share your advise/experience. Cheers!
Mine is 2014 M235i, FBO minus intercooler (eisenmann exhaust, HJS 300cell sport cat, ER turbo-intercooler pipe and charge pipe, intake, JB4). Not planning on upgrading larger turbos. I live in tropical area with hot summers, mostly street driving. I'm thinking of the Wagner Evo 2 competition. Is anyone here with FBO running Evo 2 comp? I've read it's mainly for upgraded larger turbos. If I use this IC, will there be any downside e.g. lag? My logic for choosing this IC is a) lighter and better flow than performance version, b) larger than evo 1 (better cooling), c) newer than evo 1 (ha). Or would I be better off with the Evo 1 competition? Thanks! |
11-04-2016, 01:56 AM | #2 |
Rep 4,496
Just fitted evo 2 comp FMIC in conjunction with ER boost pipes and Pure hi flo inlet pipe.
Not driven the car much since install but my initial impression is that throttle response is improved |
11-04-2016, 02:46 AM | #3 |
Rep 199
I'm very sensitive with throttle response.
I've the Wagner Evo 2 Competition intercooler since one year. Before this, I had an ATM FMIC (bar and plate like Wagner Evo 2 Performance). So yes the Evo 2 Competition is lighter, cooling is better than Evo 1, and more interesting it flows better than ATM. It's more noticeable in the 6000-7000 rpm range were there is no more a slight decrease like with the ATM. Motor pushes up to 7000 rpm with no decrease in power. Throttle response is also better compared to ATM. My car has Wagner Evo 2 Competition, ER TIC and ICTB charge pipes, Pure High flow Inlet pipe, Gfb DV+, HJS EU6 downpipe, M Performance exhaust. |
11-04-2016, 04:35 AM | #4 | |
Rep 4,496
My setup is now very similar to yours and my recent map 6 dyno chart below backs up what you say above. Latest pull [red line] compared to pull [green line] on same dyno in 2015 before fitting ER boost pipes, Pure inlet pipe and Wagner EVO2 Comp FMIC More info in this post BP
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT |
11-04-2016, 06:54 AM | #5 | ||
Rep 211
11-04-2016, 07:05 AM | #6 | |
Rep 4,496
AW M2 DCT |
11-05-2016, 01:17 AM | #7 | |
Rep 211
Also, any fitment issues with the ER charge pipe? Thanks! |
11-05-2016, 01:58 AM | #8 | |
Rep 4,496
No issues fitting ER CP as I choose to buy new seals as opposed to removing/reuse existing seals
AW M2 DCT |
11-05-2016, 05:28 PM | #9 | |
Rep 190,143
If you are tracking your car get the competition because it is a tube and fin FMIC (less weight, way better recovery). If you do not plan on tracking the car, EVO 2 performance is the way to go
11-05-2016, 08:17 PM | #10 | ||
Rep 211
11-05-2016, 08:23 PM | #11 |
Rep 190,143
Make sure to check the vendor section before buying direct
02-08-2017, 04:15 AM | #12 |
Rep 211
Quick update. I have installed the Wagner Evo 2 competition FMIC back in november. Very pleased with it. Install was straightforward but it was a tight fit. A bit of plastic can be trimmed at the underside for a better fit.
I don't feel any lag. Intake temperature is now much lowered and stable compared to stock IC during driving and on WOT. Before the IC, I couldn't run map 2 due to timing pull, thus I was on map 5. After the wagner IC, on map 5, the car pulls better from 5000 to 7000 rpm. I tried map 2, did a log and sent to BMS for review, and guess what, my car can run on map 2 now! No more timing issues. Most probably due to the IC, but also could be due to the temperature slightly cooler now than back in november. Only downside is when it sits in traffic, the intake temp will slowly creep up. However, once it gets going, the intake temp drops very quickly. All in all, a good mod. mods list : JB4, HJS downpipe, eisenmann exhaust, gruppeM intake, ER chargepipe, forge BOV and now Wagner Evo 2 competition FMIC. |
02-08-2017, 05:17 AM | #13 | |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
I wouldn't worry too much about the creeping IAT in slow traffic. Stock intercooler suffers from this issue as well (probably worse even).
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
02-08-2017, 01:19 PM | #14 |
Rep 190,143
@KAY-OS Thank you for the review
IAT will always rise when car is on idle ... It is even worse with stock intercooler
02-09-2017, 06:05 AM | #15 | |
Rep 2,577
Have you dynoed your car on this setup? I know of a similarly built m2 putting down close to 360WHP on a dynojet with dinantronics.
http://f87.bimmerpost.com/forums/sho....php?t=1352092 Quote:
Lemania 2320
02-09-2017, 06:54 PM | #16 | |
Rep 211
BM235iW97.00 |
02-09-2017, 07:32 PM | #17 |
Rep 2,214
Since there's some good experience in this thread, which map would you guys recommend on the following setup? TIA
Catless DP VRSF 6" HD Race w/charge pipes OEM Intake w/ drop in AFE +Pure turbo inlet mod MPE 91 or 94oct available locally -Dylan
02-09-2017, 08:31 PM | #18 | |
Rep 211
Map 5 is smoother and power is more linear, but some say less consistent due to JB4 constantly learning. FYI, I have 98 octane gas available here. However, your gas is not that great. Your best bet is map 5. If you want to run map 2, you should take a log and see if there are any timing issues or send the log to BMS (Jon is very helpful) for advise. If you can't run map 2 due to bad gas, then you're limited to map 1 or map 5. Of course, if you are keen and if you are good at deciphering the logs, you can play around with custom map 6 as well. I am no expert, but I've been reading n54tech forums, talking to Jon at bms and learning as I go. Others here definitely has more experience than me, so feel free to correct me. Lastly, have fun experimenting with the different maps. |
02-10-2017, 12:59 PM | #19 |
Rep 190,143
Map 2 0r map 5 would work ... Try each for a week and decide for yourself which one you like better
01-18-2018, 11:30 AM | #20 |
Rep 190,143
01-19-2018, 11:05 AM | #22 |
Rep 190,143
Looks like the Wagner EVO I with Evolution Racewerks charge pipe
