03-04-2024, 09:50 AM | #1 |
Rep 62
Which Flex Fuel Kit for Manual Gen 1 B58?
Hi,
I'm looking to buy a plug & play flex fuel ethanol sensor for my manual Gen 1 B58. I have the TU pump and I want MHD preferably. I guess the BM3 option for the LPFP works, but then I'm stuck with BM3. Is Dorch the only viable option with MHD and manual transmisson? How much work is it install it and pull the wire through the fire wall? Thanks! |
03-04-2024, 05:40 PM | #2 | |
1306
Rep 3,554
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
03-06-2024, 02:42 AM | #3 |
Rep 62
From what I have heard the flex fuel maps on MHD is a bit better. But the main reason would be that the LPFP is far away from that actual engine. Let's say you run 98, and then fill up E30. The ECU would think that the fueling is E30, but inbetween the sensor and the HPFP, there is a lot of 98 still in the fuel lines.
03-17-2024, 08:53 AM | #4 | |
Rep 718
Unless you had the engine off, at the race line, refueled while sitting there, started the engine and floored the pedal immediately after starting engine, what you're talking about wouldn't make a difference. And even then... Simple, if you're worried about a minute and miniscule difference in fueling then just don't slam anything for a mile or so... Difference of fuel in the line from what the sensor has read and hasn't... That's nuts! Just sayin'! Completely discounts the fact that even with programming, the ECU is still going to push the engine, fuel and air, to reach stoich... Very slight variations like that will only hurt performance for a split second, if at all as the fuel trims might bounce around while adjustments are made because of an unexpected reading from your O2 or wideband. Good luck! |
03-17-2024, 09:23 AM | #5 | |
1306
Rep 3,554
