BMW M2 Forum > BMW M2 Discussions > Soft Close Door Lock Retrofit
      06-19-2020, 03:41 PM   #23
Nezil
Nezil's Avatar
1404
Drives: LCI '18 6MT M2
Originally Posted by ASAP View Post
This is a real odd choice of a retrofit for a 2 series... albeit I appreciate the effort.
You don't find the frameless doors often require a second attempt at closing them? Sure, you get used to it, but passengers often don't want to slam doors when they first get it in and end up struggling.
Of course, I'm making excuses for wanting to tinker with the car anyway...
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings
      06-20-2020, 11:20 AM   #24
Nezil
Nezil's Avatar
1404
So I promised I'd come back with some feedback on the cheaper Chinese units on sale on eBay for much less than the OEM part...
The answer is... at least for me... it didn't even work!
The first problem I had was with fitting. I'm not sure if it's a tolerance issue or not, but the cheaper lock was far more difficult to move in to place and secure, whereas the genuine passenger side lock fit like a glove. I was able to get the lock fitted in the end, and the door did close and line up correctly, but that's when I ran in to the next issue.
The next problem was that the motor mechanics would move the lock to the fully closed position, but then rather than springing back to their original location in the lock ready for the next time, they got stuck in that position and in that situation the motor runs, but doesn't pull anything because the Bowden cable is already taught. I actually tried improving this by putting a cable tie in place to sort of act as an additional spring to pull things back after the close, and this fixed this, but it's hardly a solution. I'm prepared to believe that this might be an isolated problem with the lock I received, but I was already dissatisfied with the part by this point.
The last, and perhaps most important issue was that the lock just wouldn't pull the door shut. You can see in the video below that it tries, but it just doesn't succeed. In most cases it just stops in the part closed position but in some cases it would just keep trying.
I have a feeling that this is caused by the fact that our 2er frameless doors need quite a bit more force to close than a typical BMW framed door. The OEM lock seems quite capable of doing that, but perhaps these cheaper ones don't?
In any case, I managed to get a refund from the eBay seller and have now ordered another used genuine part for nearly double the price. Once that arrives I'll update here with the results.
FaRKle!4017.00
dtmurf481.50
      06-20-2020, 11:56 AM   #25
FaRKle!
Drives: 328d Wagon, M2 Comp, i4 eD35
Oh boy, even the Dremel came out? What required some extra fitting?
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      06-20-2020, 11:57 AM   #26
Nezil
Nezil's Avatar
1404
Eagle eyes!
That was just actually just for trimming the connector to fit better. I had to do the same on the OEM part as well.
No BMW original parts were harmed in the making of that video
AndyinHou479.00
      06-25-2020, 07:38 PM   #27
Nezil
Nezil's Avatar
1404
New (used) front driver door lock arrived today and works perfectly. Install was far easier than the cheaper aftermarket version presumably because the tolerances are better. The motor also has plenty of power to pull the door closed against the pressure of the glass against the door seal.
Having to use genuine Kiekert locks and motors does increase the cost a bit, but I'm happy with the result.
      06-26-2020, 09:27 AM   #28
dtmurf
dtmurf's Avatar
482
Drives: M2
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Nezil, as we’re talking about ebay purchases, is there a way to connect power to the locks ‘on the bench’ so to speak? I’d hate to tear the door apart only to discover the lock was bad.
'17 M2 DCT Long Beach Blue
      06-26-2020, 11:07 AM   #29
Nezil
Nezil's Avatar
1404
Sure... the soft close motor is very ‘dumb’. It has power and simply responds to the signal from the door lock that the door is half closed... that’s it. If you power up the motor on the bench you can use a screwdriver blade or similar to move the striker plate to half close and it will operate.
My cheaper eBay unit did move when I tested it before fitting, but also showed its locking up behaviour. I thought it might get better after fitting but it didn’t. The genuine parts fell heavier and stronger.
      06-26-2020, 11:58 AM   #30
dtmurf
dtmurf's Avatar
482
Drives: M2
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
All-right-then, off to ebay I go lol
      06-26-2020, 12:02 PM   #31
Nezil
Nezil's Avatar
1404
Try to confirm from photos that the motor has kiekert logo around the rounded section on it on one side. Kiekert is also stamped on the metal of the strike body section but it's probably clearer on the motor cover.
This image, for example shows the Kiekert AG logo on the plastic:
And this one does not:
      06-27-2020, 03:01 AM   #32
dtmurf
dtmurf's Avatar
482
Drives: M2
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Got it, will do and thanks!
      03-21-2023, 11:02 AM   #33
Drifter2090
Drifter2090's Avatar
Drives: E90 M3 | E92 335i | E90 335d
Thanks for the write up! Will definitely be doing this mod
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD
JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD
SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD
AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD
      03-23-2023, 05:08 PM   #34
BadgerDog
BadgerDog's Avatar
178
Drives: 2017 BMW M2
2017 BMW M2  [9.50]
Interestingly I find that mine dont require a lot of force to close really. Less so than other cars I have owned. I've always attributed that at least in part to the auto-roll-down of the window when the door is opened (that quarter inch movement it makes).
That being said, I can also totally understand how this would be a nice to have that makes the car feel a bit more "luxury" than not having it.
      04-03-2023, 03:17 PM   #35
dtmurf
dtmurf's Avatar
482
Drives: M2
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Using all the info provided by Nezil, I completed this mod and while it is nice to have, it is a PITA to accomplish!
Nezil, is missed around here, he provided a bunch of good info on this and other mods but I think he sold his M2 and moved on from posting here.
m2
