06-08-2018, 10:28 AM | #45 | |
Rep 1,154
Gotta pull it out and see if I can get reimbursed. |
06-08-2018, 02:24 PM | #46 |
388
Rep 889
I'm pretty sure I can feel the difference between my 135is run flats and my winter run flats, and my summer tires. I wouldn't bet big money on it.
I'm going to keep the non run flats but when they wear out, as they surely quickly will, I suspect I'll go for a run flat next time, maybe even a high performance all weather, as it gets wet here more often than one might like. Will continue with real winter tires/wheels as well. |
06-08-2018, 07:01 PM | #47 | |
Rep 314
06-09-2018, 12:23 AM | #48 |
Rep 59
is bridgestone driveguard available for your car? they are all seasons rft and they last a long time -- at least 35k miles with moderate-aggressive driving. i paid $801 for my most recent set installed.
06-15-2018, 08:14 AM | #49 |
IG @bmwF9xG80
3813
Rep 7,593
Michelin Pilot Sport AS 3+
Continental ExtremeContact DWS06 Better than all RunFlats put together and will serve its purpose for daily drivers in all weather conditions. Having experience with both of these and its predecessor as well as those AWFUL RFT.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
06-15-2018, 08:24 AM | #50 |
Rep 478
I have these on my 2 and love them. Better than the Michelin PSS.
'22 M440xi GC (BSM/Tacora) Previous: 2017 M240i Convertible; 2016 X5 50i; 2017 Boxster 718s; 2012 328iT Sport; 2009 X5 3.0; 2006 M3C; 2006 530xiT; 2003 325xiT; 2002 330i Sport; 2001 Z3 2.5; 2001 330i.
06-15-2018, 09:20 AM | #51 |
Rep 8,942
They are great tires
06-16-2018, 05:10 PM | #52 |
M6GCComp, Porsche Cayman S PDK, Peug 208 GT1 BPS
512
Rep 1,280
However they make a lot of road noise
Acceleration is heavenly
06-16-2018, 06:36 PM | #53 |
Rep 2,214
In the rain, yes. Dry traction, down on grip, but most wouldn't see the difference. I pushed hard on AS3's on my old GTI before getting PSS's to replace them. The PSS's had noticeably higher dry grip at the limits than the AS3's, but definitely down on wet grip, which is more important for most DD owners I'd imagine.. I always recommend the AS3's to the locals who want the best bang for buck performance tire, they've always come back raving!
06-16-2018, 06:44 PM | #54 | |
Rep 8,942
06-16-2018, 07:12 PM | #55 |
Rep 2,214
Pretty much
06-18-2018, 07:23 PM | #56 |
Rep 314
That they do. I've tried to grow accustomed to it, but some days that's all I hear unless I crank the stereo. That's my only complaint about these tires. Dry, wet, and snow traction are every bit as good as claimed. I guess not all great things come without at least some detraction.
09-28-2018, 03:16 PM | #57 |
Rep 7
Very newbie here: I have a question re: 228i (normal) front tires beginning to show uneven wear on outsides. Rotate? Or not. (Non-Run Flat tires)
Also: What torque used for tire bolts? Thanks Last edited by Shatzbot10; 09-28-2018 at 03:20 PM.. Reason: Added “Non-Run Flat” for clarification. |
09-28-2018, 04:55 PM | #58 | |
3626
Rep 3,593
Bolt torque is 140 Nm (103 lbft). |
09-29-2018, 04:24 PM | #59 |
2017 red m240 convertible
Rep 8
Be sure to drive at high speed if you change
I got regular tires on my 135 instead of run flats. They were totally fine until I drove 70 mph. Then my car wobbled side to side as if I was behind a tractor trailer. The tire dealer replaced them for free w run flats. I’m sorry, I can’t remember the make of the tires. But if you switch, I definitely recommend getting out on the highway sooner rather than later in case you have the same issue.
09-29-2018, 06:30 PM | #60 | |
Rep 375
09-29-2018, 08:55 PM | #61 |
Rep 8
Nope, it wasn’t. I had to drive all the way from Georgia to South Carolina with it doing the back and forth. Had a death grip on the wheel. It could’ve been just that particular tire but we heard afterwards that it was a problem with using standard tires on a car designed for run flat. Thought I should mention it...some people might not get on the interstate for months when it’s too late.
09-29-2018, 09:03 PM | #62 |
Rep 78
Already posted how BMW highly frowns on replacing RFTs with non-OEMs. But tons of people have probably done this. Yes, could have been tire, or specific to 135, or both.
What are you running in your m240i? |
09-29-2018, 09:13 PM | #63 | |
3626
Rep 3,593
A death grip on the wheel and incorrect tyre pressure will cause the car to move around more, as you are constantly correcting out of phase with the tyre movement. A relaxed grip allowing the tyres to move a little without over correction tends to let the car track straighter, you just tend to feel the steering weight continually changing and telegraphing the road irregularities, as opposed to continually over correcting to the feedback. |
09-30-2018, 04:22 PM | #65 | |
Rep 8
I didn’t mean to start a conversation about which tires are best or how best to drive. All I know is I wished I’d done a trial run at high speed before I set off on a lengthy trip, so I thought a “heads up” might be appreciated. I never had trouble once I had run flats back on the car and the tire dealer agreed it was a problem with the tires, not inflation or driver error. I don’t know what I have on 240 - whatever came from the dealer 😃 Obviously I don’t know all that much about cars, or tires, just that I like to drive fun cars. |
09-30-2018, 05:18 PM | #66 | |
3626
Rep 3,593
A bad tyre could cause pull that you may have experienced, but it wouldn't be due to run-flat vs non run-flat. Tramlining as a characteristic can happen with any wide low profile tyre, irrespective of it's design. I expect the tyre dealer was happy to sell a set of tyres as opposed to getting to the root of the problem. It is just false information that the current cars are designed or engineered specifically for run flats. I'm glad you don't have the problem now, but if you want the best performance out of any sports car in the future, run flats and/or all-season tyres will be inferior to pure non run-flat summer tyres for non-winter use. |
