05-02-2015, 11:08 AM | #1 |
Rep 9
Replacing transmission oil in my 730d E65 - which oil?
Hi there!
I'm planning to replace the transmission oil of my BMW 730d E65. Here is the pic: I've searched this code on eBay and I found different prices: From 4$/Liter to 30$/Liter. What's the difference between these oils? Here is the products: http://www.ebay.com/itm/20-Liter-ATF...item3a8b44e79a http://www.ebay.com/itm/BMW-ATF-PLUS...item27ee439423 It is worth to buy the cheapest or not? |
06-18-2017, 12:50 PM | #2 |
Rep 6
i think the dealerships should have knowledge and tell customers that bmw was wrong to say this is lifetime. no oil can last a lifetime. you know anything that lasts a lifetime beside jeweler. everything breaks down. what pissed me off more is that some service people say bmw recommends not to change it. i think many will agree with me that changing the tranny fluid extends life. !
06-18-2017, 04:45 PM | #3 | |
Rep 610
Your lifetime goals vs BMW goals are very different. |
06-18-2017, 05:16 PM | #4 |
Rep 3,211
Its been said over and over.. even ZF recommends 50-60,000 mi oil changes.. earlier if you drive hard. I drive hard.. every 30,000 mi for me.
As far as oil.. do your own dd and decide.. I'm ben a lifelong AMSOIL guy and they told me their signature ATF will work in the ZF and its a workhorse protector. I'm way over 10k miles and my trannys humming along its early but I trust the stuff. Anyway decide for yourself Im not paying $200 for ZF tranny oil which is supposedly "formulated" for their specific application and is likely inferior to other ATF on the market. do your own dd and decide.. |
06-18-2017, 05:20 PM | #5 | |
Rep 3,203
BTW, anyone, including the dealer, that tells you to never change your transmission fluid is delusional. ZFs own literature recommends regular transmission services roughly every 50000 miles, or less if you use your BMW to tow anything. Good luck, and don't forget to follow proper fill procedures per ZF guidelines, there is more to it than just draining old fluid out and putting new fluid in. If you don't do it correctly, you'll underfill the gearbox. |
06-18-2017, 08:48 PM | #6 | |
Rep 610
06-18-2017, 09:26 PM | #7 |
Gateropode
329
Rep 2,848
I recommend you use ISTA-D and follow the procedure steps dictated by the computer. The computer will monitor oil temperature and tell you when you are ready for the next step (or if you have exceeded fill temperature, and need to stop and wait).
06-19-2017, 05:28 PM | #8 | |
Rep 3,203
https://5series.net/forums/diy-do-yo...thread-137584/ |
