2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Heater Blend Door
      12-15-2023, 09:19 PM   #1
cth6
cth6's Avatar
Drives: '16 M235i
Heater Blend Door
I have been running down a lack of cabin heat issue for two years now. I get slightly warm air, nothing significant like I used to get.
Confident the core is circulating hot coolant. I am trying to see if anyone has a diagram for the blender doors actuators. I am assuming there is a single door that allows heat into the cabin before it gets dispersed. I am going to proactively replace that actuator in an attempt to fix, but I need to see the diagram where it sits so I replace the right one. 16 M235
Thanks
CT
      12-16-2023, 06:41 AM   #2
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
It might throw a code if that’s the case, get a proper BMW scanner to check
I’ve heard of heater cores being plugged. Have you ever changed your coolant and flushed the system with distilled water?
