03-25-2015, 02:25 PM | #1 |
Rep 53
Exhaust Valve Open in Comfort?
I recently learned that (in addition to other changes) putting the car into "Sport" will open up a valve in the exhaust to allow for a sportier sound.
Is there a way to have this valve remain open even in Comfort mode? The NYC roads are brutal and I find myself driving the car in Comfort mode unless I know I have a smooth stretch of pavement ahead. I'd like to have the increased exhaust note at all times, though. |
03-25-2015, 02:36 PM | #2 | |
Rep 862
Drives: '19 M2 '21 X5
That or disconnect the solenoid in the exhaust when it is open. |
03-25-2015, 04:25 PM | #3 |
Rep 53
Hmm, I'll have to take a look! For some reason I thought I remembered the only parameters I could adjust were "drivetrain" and "chassis".
03-25-2015, 04:34 PM | #4 |
Rep 5,262
03-25-2015, 04:47 PM | #5 | |
Rep 53
I wish there was a way to give me the "Sport" exhaust note all the time, without altering any other chassis or drivetrain parameters. That's one of the things I love so much about my Miata; it's analog. I hop in, start it and go. The suspension is fixed, the steering is fixed, the exhaust always sounds the same. Don't get me wrong, I absolutely love () my M235, it's just quite the change from what I'm used to in a daily driver. |
03-25-2015, 04:57 PM | #6 | |
Rep 845
I have the MP Exhaust and in sport mode, the overrun is LOUD in underground parking garages. It's nice to be able to "turn it off" sometimes so I don't scare the crap out of anyone or make the parking attendants at my office building think my car is going to explode. |
03-25-2015, 05:04 PM | #7 | |
Rep 53
03-25-2015, 05:28 PM | #9 |
Rep 845
03-25-2015, 05:52 PM | #10 |
Rep 1,797
I agree - I've owned two previous generation M3's and never felt the need to change the oem exhaust (especially on the S65 drool) -- but so glad I got the mpe on the M235. I think it sounds awesome!!
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
03-25-2015, 05:53 PM | #11 | ||
Rep 5,262
03-29-2015, 04:34 PM | #12 |
Rep 284
"disconnect the solenoid in the exhaust when it is open"
I agree with the OP, I would like to keep the valve open regardless of drive setting or configuration. How does one keep the valve open? Does simply disconnecting the solenoid work? Is it spring loaded? How do you disconnect it? I searched for a DIY but couldn't find it. TIA |
03-29-2015, 07:20 PM | #13 | |
Rep 886
03-29-2015, 08:11 PM | #15 | ||
Rep 5,262
03-29-2015, 08:16 PM | #16 |
Rep 4,203
Just unplug the flap. Wait till the car is cold and flap is open then just unplug it....done. Unplugged mine when I installed the MPE and have not plugged it back in
03-30-2015, 03:22 AM | #17 |
Rep 886
Thanks.
Sounds like a better design. The vacuum system on the 3 was such that they would rattle on minor leaks. Sounded terrible.
03-30-2015, 07:30 AM | #18 |
Rep 284
03-30-2015, 07:46 AM | #19 |
Rep 1,496
Ok so could anyone explain more simply what this accomplishes? What it sounds like is that the valve remains closed on cold start up so that the exhaust only flows from one side, so if you unplug it at that point then the valve remains closed and the car is louder all the time?
I'm confused between the valve being open/closed and which exhaust pipes are flowing and how it makes it louder.
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i | |
03-30-2015, 09:47 AM | #20 | |
Rep 284
designatedposter175.00 |
03-30-2015, 09:48 AM | #21 | ||
Rep 1,496
03-30-2015, 10:03 AM | #22 |
Rep 886
Are you talking about outside of the car or inside? If inside, there's also the contribution from the from the simulated engine sound level changing.
