AutoTalent | Dinan spring set+control arm+tuner for Bmw F22/23 228i 2014-2016 |
09-25-2019, 11:21 AM | #1 |
2324
Rep 12,654
Dinan Adjustable Anti-roll Bar Set To order anti roll bar set for Rwd please visit our website by clicking HERE To order anti roll bar set for xdrive please visit our website by clicking HERE Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. Features + Less Body Roll + More Mechanical Grip + More Stable At Limit + Large 28mm size* + 3 hole bar with 3 possible positions on the bar Less Body Roll + More Mechanical Grip + More Stable At Limit + Large 19mm size ---------------------------------------------------- Dinan Shockware Edc Suspension Tuning To order please visit our website by clicking HERE Just as Performance Software dramatically changed the world of engine tuning, Shockware™ will forever change suspension tuning and now its available for all F30/31/32/33/36 3 and 4 series vehicles. With the wide spread use of the Adaptive M Suspension, throughout its most powerful models, DINAN has tuned it for ultimate performance. Match DINAN Shockware™ with a DINAN Performance Suspension System for superior handling in all driving conditions. Since the introduction of the Adaptive M Suspension system, DINAN has embraced the flexibility and performance that can be achieved by a suspension upgrade that leaves the Adaptive M Suspension system in place. With the addition of DINAN Shockware™ this solution takes another large step forward by also reprograming the damping curve of the damper itself. ---------------------------------------------------- Lower Control Arm Monoball Kit To order please visit our website by clicking HERE The quietest bearings on the market are virtually noise free so you can live with them everyday. These are the only bearings on the market that are sealed using a rubber boot to keep out dirt and road grime stopping them from wearing out prematurely. The Dinan Monoball Kit provides responsiveness you can feel by replacing the rubber bushings in the thrust arms with precision ball joints and machined aluminum housings. Improves responsiveness by eliminating the deflection inherent in the stock rubber bushings while also reducing brake shimmy. Features + Improved Steering Responsiveness + Reduces Brake Shimmy + Nylon-lined Bearings for Quiet Operation + Machined Aluminum Housings + Sealed Bearings ---------------------------------------------------- Dinan Camber Plates To order please visit our website by clicking HERE The positive adjustment range on the camber plates is unique to Dinan and allows the end user, if desired, to retain OEM camber settings on a lowered car or to combat excessive negative camber brought upon by springs that aggressively lower the car. Not only do the Dinan camber plates provide a wide range of adjustment but they also have ride quality in mind like all of Dinan's suspension components and are designed to properly retain the bumpstop so that it compresses as designed from the factory. Dinan camber plates are also built to take a beating and are the only ones that utilize a steel alloy mount plate that will resist deforming from pot holes on the street or curb hopping at the track. Aggressive drivers will benefit from reduced outside edge tire wear as well. Features + 43mm of total camber adjustment (30 negative, 13 positive from OEM). This translates to 2.5 degrees of negative camber and just over a degree of positive camber being possible. + Decreased understeer + Decreases outside edge tire wear + Steel alloy mount plate and not aluminum + Fits with factory strut tower weather seal --------------------------------------------------- Dinan Performance Spring Set To order please visit our website by clicking HERE Dinan's Performance Spring set for the F22 228i (non xDrive) provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan lowers the 335i by a 1/2" in front and rear for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car. The 50% increase in stiffness will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs will also provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at speeds as low as 20 mph, up to the top speed of the vehicle. --------------------------------------------------- Dinan High Performance Dual Core Intercooler To order please visit our website by clicking HERE The system has been engineered to be as direct a replacement as possible to the stock unit, requiring only minor modifications for a clean, factory-like installation. The increased thermal efficiency provided by the Dinan dual core intercooler will also enhance turbocharger reliability in addition to overall power. On a stock vehicle power gains can be had from 4000 RPM and beyond (when the car is in boost). In order to achieve the best performance the intercooler should be paired with the Stage 3 DINANTRONICS Performance Tuner as it provides optimization of the intercooler. In particular it extends the power band to be more robust and powerful from 5000 RPM to redline whereas without tuning the bulk of the gains are from 6000 RPM to redline. Features Max gains of 15 HP and 13 lb-ft of torque @ 6250 RPM (greater gains and a wider power band can be achieved when paired with stage 3 DINANTRONICS) Face area 240% larger than the stock intercooler setup for maximum cooling efficiency to deter heat soak. Charge Air Pressure drop: 0.80 PSI (25% improvement over stock) Charge Air Temperature drop: 155ş F (11% improvement over stock) Charge Air Temperature / Ambient Temperature Delta: 18ş F @ 6250 RPM (60% improvement over stock) --------------------------------------------------- Dinantronics Performance Tuner To order stage 1 N26 please visit our website by clicking HERE To order stage 1 N20 please visit our website by clicking HERE To order stage 3 please visit our website by clicking HERE To order stage 4 please visit our website by clicking HERE To order sports tuner please visit our website by clicking HERE DINANTRONICS Performance Tuner is a highly engineered and sophisticated piece of computer hardware and software that enhances engine performance, without ineffectively or invalidate your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It was also designed to be emissions legal in 50 states (E.O. Pending). The objective of developing this piece of technology was to provide the ability to control every signal entering and exiting the BMW factory Engine Control Unit. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package. How to Place Your Order: Phone Domestic: (855) 973-2757 X 104 Phone International: (310) 231-7800 X 104 E-mail: online@autotalent.com Website: www.AutoTalent.com Payment: Installations: Feel free to visit us at our facility in Los Angeles, CA. We install everything we sell. 19143 S. Hamilton Ave Gardena, CA 90248 Shipping: All orders are shipped via FedEx, UPS, USPS and Pilot. International, Hawaii and Alaska customers: Please contact us for the best quote possible. Hours of Operation: Monday through Friday: 10AM-7PM Pacific Time Saturday: By appointment only Last edited by AutoTalent; 09-27-2019 at 11:41 AM.. |
