Awe Tuning Bmw F22 M240i / M235i Exhaust Suite WE WILL PRICE MATCH! |
06-12-2017, 10:06 PM | #1 |
Supreme Allied Commander
3888
Rep 54,553
Drives: F80 M3
Compact powerhouse. The athletic M240i/M235i gets a voice to match the bite. Introducing the AWE Tuning BMW F22 M240i/M235i Exhaust Suite.
Available as sophisticated Touring Edition Axle-back or aggressive cat-back with Performance Mid Pipe Touring Edition Axle-back features AWE Tuning's proprietary drone-canceling solution, 180 Technology® Max gains of 9 hp and 11 ft-lbs of torque at the crank (M240i) Max gains of 8hp and 15ft-lbs of torque at the crank (M235i) Less is more: clean, non-baffled, straight-through design maximizes performance Handcrafted from U.S.-sourced CNC mandrel-bent .065” wall T304L stainless steel 90mm or 102mm double-walled adjustable tips available in chrome silver or diamond black Engineered, designed, and manufactured in-house at AWE Tuning Perfect fitment - guaranteed No Check Engine Light Guarantee Featuring the AWE Tuning Lifetime Exhaust Warranty The F22 M240i/M235i Exhaust Suite: The AWE Tuning Touring Edition Axle-back Exhaust The AWE Tuning ® Touring Edition Exhaust is an axle-back system that leverages AWE Tuning’s proprietary sound cancellation solution, 180 Technology®, to produce the a signature, sophisticated, drone-free exhaust note. If you’re unfamiliar with 180 Technology®, learn more through this brief 180 Technology® video. The AWE Tuning Performance Mid Pipe The AWE Tuning Performance Mid Pipe is non-resonated, and replaces the factory resonated section with straight-through 3-inch T304L stainless steel tubing that delivers the perfect exhaust note for those looking for all-out aggression. Ready to rumble. The AWE Tuning F22 M240i/M235i Performance Mid Pipe is only confirmed to fit with AWE Tuning Touring Edition Exhausts. Fitment with stock, or other axle back units is not guaranteed. Sound Perfection: AWE Tuning 180 Technology® Perfect tone comes compliments of AWE Tuning AWE Tuning 180 Technology®. As exhaust gases exit the N55/B58 engines and flow into an AWE Tuning 180 Technology® equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies. More on AWE Tuning 180 Technology® in the tab above. Tip Options: AWE Tuning logo. Double walling. Individually adjustable. Available as 90mm or 102mm, Chrome Silver or Diamond Black. Lookin’ good. What’s in the box? Depending on which options you chose, the AWE Tuning BMW F22 M240i/M235i Exhaust Suite includes the axle-back exhaust system itself, the Performance Mid Pipe (if chosen), two exhaust tips, and all clamps and hardware required for installation. Important Fitment Note: If you're looking to equip your F22 with the Performance Mid Pipe alone, please note that cutting the stock exhaust is necessary. Please see our installation instruction guide in the tab above. The Performance Mid Pipe is not applicable to the M240i by itself. Please Note: The AWE Tuning BMW F22 M240i/M235i Performance Mid Pipe is for racing use only. Fits: 2014+ M235i M240i and x-drive Download Installation Instructions: http://www.awe-tuning.com/media/pdf/...ipe-rev1.0.pdf Download Installation Instructions: http://www.awe-tuning.com/media/pdf/...st_midpipe.pdf (SKU: GRP-EXH-BWM2402351) Order here: http://www.hpashop.com/AWE-TUNING-BM...BWM2402351.htm Last edited by HP Autosport; 01-16-2018 at 12:30 PM.. |
06-16-2017, 04:05 PM | #2 |
3888
Rep 54,553
Drives: F80 M3
06-27-2017, 01:29 PM | #5 |
3888
Rep 54,553
Drives: F80 M3
07-07-2017, 03:25 PM | #6 |
3888
Rep 54,553
Drives: F80 M3
07-13-2017, 07:12 PM | #8 |
3888
Rep 54,553
Drives: F80 M3
08-11-2017, 12:33 AM | #14 |
3888
Rep 54,553
Drives: F80 M3
08-18-2017, 11:41 PM | #16 |
3888
Rep 54,553
Drives: F80 M3
