07-18-2016, 01:53 PM | #1 |
Rep 225
How to check for boost leak location?
I'm pretty sure I have a boost leak somewhere on my car, and wanted to see if anyone had an idea of how to check where specifically the leak might be occurring. I'm gonna do some logs tonight to verify it exists, then hopefully start some tests to see where the leak is occurring.
2015 ///M235i | Alpine White | 8AT | RW Carbon Front & Rear Lips | Autotecknic Paddles | MP Side Decals | AWE Axelback | Shifteck DP | MHD Stage 2+ | BMS Intake | FTP Charge Pipe | VRSF FMIC
07-18-2016, 02:25 PM | #2 |
Rep 5,097
Cracked chargepipe perhaps?
07-18-2016, 02:41 PM | #3 |
Rep 225
My charge pipe is made of aluminum, so I definitely would have heard if it cracked. My thought is that it must be a loose clamp or band.
07-18-2016, 02:54 PM | #4 |
Rep 1,184
From my understanding it's kinda a pia to find. N54 tech has a sticky on it I believe.
I think the most fool proof way is to make a fitment out of PVC and pressure the system with a vacuum and some sort of smoke and look for it. That or use soapy water, spray it on and look for bubbles. |
07-18-2016, 02:56 PM | #5 | |
Rep 1,184
http://www.n54tech.com/forums/showthread.php?t=13114 here ya go. |
07-18-2016, 05:39 PM | #6 |
Rep 5,097
Right, sorry. Just noticed your signature
07-18-2016, 05:39 PM | #7 |
Rep 1,541
I would first look at the logs and see if PWM is high/max. If so then start tightening the easy to reach hose clamps etc. Careful not to over tighten.
Then log again. If it still shows a leak then do the pressure test the others mentioned. |
Luminous742.00 |
08-04-2016, 10:34 AM | #8 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
Do you know if OBDII can read out PWM? I don't have a JB4 but can run data logs off of OBDII. Can't seem to find the parameter within the Dash Command app that I have though...could it be under a different name?
08-04-2016, 12:16 PM | #9 | |
Rep 1,541
If it does then it might be under something title wastegate...? Do you have any buddies with Jb4?
