07-02-2016, 08:23 AM | #1 |
Rep 151
Failed emissions? Wtf
I just failed emissions cause my car wasn't in ready state? I only have a jb4 I turned it to map 0 before the test. It's the new one with the obd plug. Was I supposed to unplug it? I was told by bms to turn it to map 0 when I asked about it before I made the purchase. I'm in pa. Anyone have this happen to them? only has 6,000 miles
07-02-2016, 09:19 AM | #5 |
Rep 151
07-02-2016, 09:39 AM | #6 |
Rep 893
Perhaps the auto clear function was on before you switched to map 0. If that's the case you'll have to drive around 50miles on map 0 before the status will change to ready.
2019 SG M5C
07-02-2016, 09:42 AM | #7 |
Rep 151
Thanks for the info I'll drive it for a couple days and check it. I guess my down pipe is not going in this weekend
07-03-2016, 08:23 PM | #8 | |
Rep 5,262
Why do you even have do do emissions in a new car? |
07-16-2016, 08:22 PM | #9 |
Rep 957
In NY you need like 6 of the 9 systems ready, basically they do not want people clearing the ecu and getting passed. All cars get tested. I wish we had inspection here in Fl, most cars are junk.
07-17-2016, 05:23 AM | #10 |
Rep 151
Every year you have emissions and visual inspection in pa. You can get an exemption if you drive under 5,000 miles a year. I passed now. When I switched to map 0 it reset everything so I had to do a drive cycle to get everything back in ready state. Just put my downpipe on last night😎
07-17-2016, 09:25 AM | #11 | |
Rep 957
To bad jb4 is not at volkswagon levels of programming, then you would not even have to put back in the cat. |
07-19-2016, 06:22 PM | #12 |
Rep 190,804
You probably reset the codes before doing the emission test
I would just remove the JB4 all together to be 100% safe
07-19-2016, 07:05 PM | #13 |
Rep 151
