07-01-2016, 02:47 PM | #1 |
Rep 50
JB4 Stage 2 FF Wires
Hey guys just a quick question- are the FF wires necessary to a jb4? If so what is the difference that it makes and where would the connection be.
07-01-2016, 04:32 PM | #2 |
IG @bmwF9xG80
3812
Rep 7,593
BMS Stage1 = BMS STage1
Stage 2 = JB4 http://www.n54tech.com/forums/showthread.php?t=18588 FlexFuel is for E85 usage (blends of e30) really recommended for increasing octane and power
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
07-02-2016, 12:43 AM | #3 | |
Rep 4,510
FF is essential for EWG cars so as JB4 has direct control over the fuelling to maintain correct Fuel trim and AFR, especially if you have extra EWG harness installed. Without it, higher boost maps could cause car to run too lean and jb4 would failsafe to map 4.
Current '22 X3M LCI.. |
07-03-2016, 08:11 PM | #4 |
Rep 50
So only way to connect is before a cold start because the engine would be to hot? I'll post a picture of what I'm talking about ( it's on the left side towards the bottom of the engine?)
07-04-2016, 02:36 AM | #5 | |
Rep 4,510
Are you talking about EWG harness which is front low down RHS ?
07-06-2016, 09:05 PM | #7 |
Rep 1,184
So got a related question. I just got jb4 with the ewg harness. I installed the jb4 but not the ewg harness so far. Will I see increased boost with the ewg harness and not the ff wires.
I do not plan on running ethanol or meth, at least not yet. I have exhaust, CP, and do currently on my car. Fr what I understand the ecu limits boost to around 14.5 psi without ewg harness. Could higher boost be achieved without ethanol? |
07-07-2016, 11:30 AM | #8 | |
Rep 4,510
With EWG harness installed it allows JB4 to directly control WG so you will benefit from absolute map capabilities JB4 has with pump gas, these being map 5 [autotune] and map 6 [custom map 6] Differences between maps 1 & 2 v map 5:- Map 1 or 2 - additive, lower boost targets [+4.5 psi map 1 and +6psi map 2]- more subservient ie OE ECU is primary to control parameters and no direct control of waste gate Map 5 - absolute, higher boost targets - JB4 sets and controls more parameters - matches/ succeeds OE ECU and has direct control over waste gate. Been running map 5 on and off on my EWG m135i for nearly 2 years on pump gas - no issues. Had map 6 setup on a dyno - its immense !!! BP
07-07-2016, 11:43 AM | #9 | |
Rep 1,184
07-08-2016, 02:32 AM | #10 | |
Rep 4,510
If you have EWG harness fitted you should feel a difference between map 2 and map 5 as maps 1&2 have EWG control disabled whereas map 5 has EWG control enabled. Try some octane booster with your 91 on map 5....Enjoy....
07-08-2016, 11:07 AM | #11 |
Rep 447
and it goes without saying if you're going with the JB4 and running map 2 or 5 you should invest in a charge pipe as these seem to blow on the higher boost maps. I know people say they blow on stock boost, but most of the blown pipes seem to come from higher boost maps of the stage 2 tune which makes sense.
07-08-2016, 03:48 PM | #12 |
Rep 4,510
Still on stock CP with 16-16.5psi map6 - no issues
07-08-2016, 10:20 PM | #13 |
El Capitán
521
Rep 2,652
I'm in the midst of buying the right one as I purchased a PWG one (don't even ask-but guy said it was EWG and burger confirmed that it's not)
How can I tell from looking at it that it's the correct one? This is a photo of the unit...which I think is the right one but if someone can confirm that'll be amazing! |
07-08-2016, 10:33 PM | #14 | |
Rep 201
Drives: 2017 GT350
07-09-2016, 06:43 AM | #15 | |
Rep 4,510
07-09-2016, 08:29 AM | #16 |
El Capitán
521
Rep 2,652
Yeah man lol
I have a JB4 that I need to sell...and I need to pick up the right one. I was slammed at work and finally got a day so I started reading only to find out it was not the right one. I basically got scammed but it's all good. I'll sell it and lose a few dollars... Are you sure it's not EWG? The owner had it on his 2015 335i and it looks like the newer slim case which I thought was EWG. |
07-11-2016, 08:29 AM | #17 | |
Rep 4,510
07-11-2016, 01:42 PM | #18 |
El Capitán
521
Rep 2,652
07-11-2016, 04:18 PM | #21 |
Rep 4,510
Yes
