2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning MP: Dyno day with Stage 2 M235i. JB4 and Flash Tuning results
      03-31-2016, 11:22 PM   #23
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Originally Posted by kd0t
@ocN55 hey we should do a pull to see the comparison! You're local to me as well
Safely as possible of course
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles
      03-31-2016, 11:28 PM   #24
kd0t
Safety first. Always
      04-01-2016, 01:25 PM   #25
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Also, everyone note how the flash tune was not only able to give me 30 more hp and 60 more tq over the JB4. But it did so with a richer AFR and less boost!
Originally Posted by ROBNYC View Post
Great to hear, are you planning on upgrading your turbos?
How about a can of Torco to see what it does with 93-94 octane on your next dyno considered?
Can you run E30 blend with your current tune?
If you're only at 13lbs of boost, how much were you doing with JB4?
I don't plan on going big turbo on this car. Maybe I'll try that but I'm a fan of running an E85 blend.
And yes, Alex said that my ecu can adapt to ethanol. We will be playing around more with this in the coming weeks!
let me know brotha, maybe we can see meet up at a car meet.
FBO M235i r
F80 M3
      04-04-2016, 11:49 AM   #26
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
ocN55 keep us posted
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      04-05-2016, 01:16 PM   #27
Zel335
Zel335's Avatar
82
Drives: 2012 335I Sport
Yes please do.
      04-05-2016, 01:55 PM   #28
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
would be interested in seeing the JB4 logs of these runs if possible...
      04-06-2016, 03:43 PM   #29
ocN55
ocN55's Avatar
I have them. I'll post them on datazap when I get the chance.
FBO M235i r
F80 M3
      04-09-2016, 05:00 PM   #30
ocN55
ocN55's Avatar
http://www.datazap.me/u/sc67065/mp-s...-4-5-6-9-12-18
Here is a log of my current flash tune.
I'll be posting my old jb4 91 octane logs too. You will notice that my AFR are leaner, avg ign is poor, my throttle is struggling to stay open, and I'm boosting more despite making less power.
FBO M235i r
F80 M3
      04-09-2016, 11:43 PM   #31
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Luminous Darkiedm4 cryptocar dd1981 you guys know more about logs than me lol
IG: @bmwF9XG80
      04-10-2016, 12:13 AM   #32
ocN55
ocN55's Avatar
Compare the flash tune log above with this JB4 log here. Same fuel and mods (minus IC).
http://datazap.me/u/sc67065/jb4-map-...-4-5-6-9-12-18
Notice how without the flash tune my car has leaner afr, poorer timing, more throttle closures and more boost while making significantly less power (if you see the dyno chart in the OP).
FBO M235i r
F80 M3
      04-10-2016, 12:21 AM   #33
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Flash tunes are smoother no doubt. Not to discredit the jb4 because Terry does have some nice backend flashes that compliment the jb4 on the n54. Not sure if he has backend flashes for the n55 or otherwise.
IG: @bmwdoubles
      04-10-2016, 12:24 AM   #34
ocN55
ocN55's Avatar
Terry has none for the N55 sadly, it would be a game changer if he did. But there are a few pioneers of stacking flash tunes as a BEF (from places like MP, ENZO, ACF).
FBO M235i r
F80 M3
      04-10-2016, 11:10 PM   #35
ocN55
ocN55's Avatar
Did a log today with the flash tune and 91 octane, JB4 only used to log.
I'm shocked that I was was hitting 17psi of boost and a 0.9 avg ign, on 91 octane!
AFR still looking nice and safe
http://www.datazap.me/u/sc67065/stre...=1-2-4-5-12-18
FBO M235i r
F80 M3
      04-10-2016, 11:34 PM   #36
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
17 psi on 91 octane? Jesus. Hope your motor doesn't kaboom.
      04-11-2016, 12:06 AM   #37
ocN55
ocN55's Avatar
I've ran 17 psi quite a bit before but with E85 mix.
I was just surprised to see the ECU target 16-17psi on its own on such low octane fuel. My AFRs are still on the richer side at low 12, my motor should be on a good path
FBO M235i r
F80 M3
      04-11-2016, 12:32 AM   #38
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
You good at 17. Jb4s map 5 push as much as 15 psi on 91oct.
IG: @bmwdoubles
      04-11-2016, 11:08 AM   #39
ocN55
ocN55's Avatar
ocN55 i looked at the log and the highest I see is 14 psi
I doubt the ECU Flash is making you push 17 psi lol since supposedly thats a current flash limit with the stock tmap sensor , correct me if im wrong
Look between 3-4k
FBO M235i r
F80 M3
      04-11-2016, 12:41 PM   #40
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Not sure if the JB4 logs read differently with ECU flash, but if the logs are accurate then you have some issues with your timing.
You're running pretty rich for the N55 platform too.
That timing would make me nervous. It would be even more pronounced in higher gears.
FPL and FPH look good though.
Just my opinion based on my limited experience with tuning my JB4.
      04-11-2016, 12:42 PM   #41
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
I believe the stock tmap sensor is limited to 20psi, but you're right he's only hitting like 14psi max.
      04-11-2016, 12:45 PM   #42
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Look between 3-4k
Yes, you get close to 17psi for a bit at a very low rpm, but quickly taper down to 13-14psi.
I would adjust the boost table to hit it a little later and longer. Just me though.
Edit: after you get your timing issue sorted that is.
      04-11-2016, 01:06 PM   #43
ocN55
ocN55's Avatar
You can't really adjust boost per se on a flash. The ECU decides how much it wants to boost depending on the torque being asked to put out. This amount boost is quite impressive I think for CA 91 octane. Also you're right about stock TMAP, its good for 20psi.
I'll be hitting more boost soon with some E85 tuning. Hope to be at 407/475 again.
Here's what an E40 log looks like if you're curious. I'm having major HPFP issues running the car like this though and it's too lean for me. I'll be getting a new flash to help accommodate for this boost curve and fuel. This is the only log where my HPFP barely got by.
http://www.datazap.me/u/sc67065/log-...a=1-2-4-5-9-10
Hm... What do you think is wrong with timing? I'll have to look into it more myself. My avg ign retard is at the lowest it's ever been at 0.9. The FPL parameter is meaningless on F series N55, those values should be arbitrary.
Also I prefer to run my car the richer side.
Edit:
I think I see what you mean with timing. I guess that's what happens when one of plugs for valvetronic comes loose lol
FBO M235i r
F80 M3
      04-11-2016, 02:53 PM   #44
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Edit:
You can't adjust boost with JB4 stacked on it?
I've read the same thing about the FPL and N55. There does seem to be some correlation though, because I see it change as expected when I adjust my boost/FOL. Anyone know?
Your timing looks much better in that last log. Yes, your FPH is at the limit it appears. I would lower your ethanol a little.
Really you should log in 4th or even 5th. I think 5th is the best.
Short <3rd gear runs can hide a lot of possible issues.
Just my opinions. I'm still learning Jb4.
