06-07-2015, 10:42 PM | #1 |
Rep 2
jb4 tunning help
so im having a werid issue i thought id share with the fourms and see what people think. I have a manual m235i catlessdownpipe, bms intake , jb4 running 10 gallons 100 octane 3 gallons e85 when i do a solid pull in a gear like in 3rd i get good afr but when i shift and pull in the next gear my afr skyrocket i have ewg and flex fuel wires hooked up.
any suggestions would be appreciated here is an example in my logs 2nd gear only 1st to 2nd to 3rd |
06-08-2015, 01:58 AM | #3 |
Rep 2,354
Strange that your ignition is staying so strong - worrying. Switch to map0 until Terry has had a look at this.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
06-08-2015, 06:34 AM | #5 |
Rep 171
Same thing happens to me. It doesn't matter what map, even map 4 it happens. Happens with straight pump gas as well. I have been working with them but it's getting pretty old quick not being able to bang through gears and have fun. A single gear pull is fine but as soon as you shift your trims flatline and afr's skyrocket. Same thing I have, take a look at what happens to your trims in your logs...
I actually feel better seeing these I know it's definitely the tune |
06-08-2015, 09:29 AM | #6 |
Rep 2
well in map 0 and map 4 it dosent do this to me i already emailed burger motorsport and waiting for a reply. i wouldnt mind going to there actuall shop if they would take a look at it for me. but i work 6 days a week lol im running map 0 until i figure this out. if anyone wants to see the actual files ill upload them let me know
06-08-2015, 11:57 AM | #7 |
Rep 190,633
As mentioned above contact Burger tuning technical support.
06-08-2015, 12:04 PM | #8 | |
Rep 1,503
Is everyone on the latest ewg firmware? Using the ewg wires, ewg board, ff wires? All these 3 things will allow for optimal performance on our cars.
FBO M235i r
F80 M3 |
06-08-2015, 03:53 PM | #9 |
Rep 171
Even map 4 lol. Only map it doesn't happen in is map 0. Oh yeah this has followed me through multiple firmware updates and now I am on the obd2 firmware. It's a dangerous thing, see how lean I run in some of these logs? Take a look...
http://www.n54tech.com/forums/showthread.php?t=30670 |
