2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Can I fit 225/45 R18 on a 2015 228xi M Sport Line?
      09-20-2017, 08:07 PM   #1
ThatKrazyPolak
Drives: 228xi (SOLD)
Hi guys, need some help with tires I'm looking to get. Basically I want to get a set of tires with a larger sidewall to minimize impact of pothole damage as winter is coming up (tire warranty expired).
I want to get something similar to BFGoodrich g-force size 225/45 R18.
https://www.tirerack.com/tires/tires...omCompare1=yes
Currently running stock Pirellis (225/40 R18)
Does anyone know if there would be any clearance issues here on an M Sport model? Can't seem to find anything online.
Thanks
      09-20-2017, 09:56 PM   #2
aerobod
aerobod's Avatar
3699
Should be fine, I have 225/45-18 Pirelli Sottozeros on 18x8 45mm offset wheels (tyre measures about 230mm wide) on our M240i, no rubbing issues. There is about 10mm below the strut spring perch and a similar clearance at full lock from the wheel arch liner at the front of the wheel arch.
      09-21-2017, 02:21 PM   #3
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
Call Tirerack and speak with a PERSON. They are usually very knowledgeable or can direct you to a manager if they are not.
      09-22-2017, 07:15 AM   #4
Maynard
Drives: 228iX & M2C
Have you considered 17" wheel/tires? I run 205/50-17 Conti WinterContacts and have not had a problem. Many members swear by 17"ers for pothole resistance even in summer, but especially for winter tires where the extra compliance is a bonus not a detriment. Much more dramatic than a 5% change in profile, and it won't throw speedo off. That said, I run the stock summer RFT Conti 18" in summer and have not lost a tire, despite some fairly bad roads (not NYC bad, but enough to jack my alignment once already)
