11-08-2022, 01:57 PM | #1 |
Rep 38
Videos: SCCA Time Trial - Road Atlanta
November 5-6, 2022. 2015 M235i, stock except for camber plates, 17x9s with 245 Nankang CR-1 tires, and PFC 08 brake pads.
Disclaimers: Data didn't work properly all weekend. The phone GPS just wasn't good enough for any of the 3 apps I tried to consistently pick up start/finish. So there are no useable lap times, if you're super interested you'll have to use a stopwatch. Sound is awful, again. The video where you can see the driver, that wonderful-ish noise is the heavily modded Camaro I was chasing. I eventually backed off so I could actually hear my own car. And, as always, the data lags. This winter I'm buying an OBD2 BT dongle and probably a GPS puck before going back out, so maybe next time all I'll have to whine about is the sound. I shot videos two ways and neither was amazing, so will keep trying different things. First was Saturday, from the windshield: This session, if I'm remembering, correctly, was the second of the weekend, so I was working to steadily build speed. Second video was Sunday, mounted in the rear window looking forward, so you can see the driver. However, when the sun came out it REALLY washed out the view out the windshield, so I dunno what to do there. This one was a little faster (fastest lap of the weekend should be lap 4 (so maybe 2 laps after the video starts?), with lap 5 being just off it). This session was a couple laps of warmup, then "Send it" for a couple laps, then cool off a couple, then "Send it" one more. Last edited by RacerBowie; 11-08-2022 at 02:26 PM.. |
11-09-2022, 01:03 PM | #3 | |
Rep 38
Great place to drive, races well (if biased a bit toward cars with torque, makes setting up a pass tough), but MAN is it an unforgiving place if you go off. If there is any track in the US where you should get the TrackDay insurance, it's Road Atlanta! |
11-09-2022, 03:11 PM | #4 |
Rep 38
Road Atlanta is the reverse of VIR. RA = Downhill "S"s, short straight between 6 and 7, long back straight, pucker factor turn 12. VIR = Up hill "S"s, short straight between 11 and 12, shorter long back straight, off camber turn 17. Was told the track designer made an effort to copy VIR.
It was not until I raced RA, and had talks with others, that it hit me about the similarities. Helped me improve my section time between turn 11 & 12 at VIR, I was coasting/lifting between the two (not coasting/lifting at RA 6 & 7, since the distance was longer), thinking it was one turn (not thinking it was two turns). |
RacerBowie33.00 |
11-10-2022, 07:35 AM | #6 | |
Rep 38
And really, South Bend's approach is different than RA turn 1, but thecommitment level to go fast through it is the same. If you have the right pace at turn in you aren't sure you're going to make it until well past the apex. Interesting comparison that I've never heard made before... explains why I love them both. Thanks! |
11-14-2022, 03:28 PM | #8 |
Rep 372
Are you running a baffled sump or S55 oil pan and pump? I've heard Road Atlanta is one of the danger tracks for our cars due to some of the longer corners.
11-15-2022, 07:55 AM | #9 |
Rep 38
11-19-2022, 10:50 AM | #10 | |
Rep 445
Turn 9 (the Carousel) at Road America is way longer. Turn 8 at Brainerd is 180+ degrees. And the Keyhole (5) and the Carousel (14) at Mid-Ohio are both 180 long turns also. Brainerd and Road America are my usual tracks, and I live in mortal fear of oil starvation. In addition to max oil level, I also run a relatively narrow 225 width on my RS4 track tires. Originally started at 225 for other reasons, but sticking with it to keep overall cornering forces lower. Same with the RS4, which aren't as sticky as some options. And it's also a reason I haven't put in camber plates. Hoping that these choices keep me safe enough. And on the upside, they are all also the cheapest choices. |
MassNerd171.00 |
11-19-2022, 02:33 PM | #11 | |
Rep 3,505
If that's the case, I think from T10B turn-in to straightening the wheel after exiting T12 is one very long right-hander (some of it much more turning-right than the rest (i.e., T10B and T12)). Bowie runs that section pretty consistently between 14.2-14.3 secs, making for a long stretch of turning. His hands also straighten-out a couple of times, whereas if you watch an in-car video from significantly faster cars (LMP3 and BW's E36 Pikes Peak), you'll see the driver is steering the car right throughout the section. That section also goes uphill soon after starting and then turns into a long downhill before reaching the flat of the main straight. I have no idea what effects upon oil pickup those changes do or don't have. Oil pressure would seem to be data worth capturing to see if there's an issue with it on that part of the track.
11-19-2022, 05:18 PM | #12 |
Rep 38
So multiple thoughts:
First, my "knowledge" of the problem with oil starvation was from braking Gs and long LEFT hand turns. Now admittedly the long left handers knowledge I extrapolated from well known issues with older BMW inline 6 engines, but the architecture between the M series and the N series is similar and German engineers have always seemed to do the same things over and over. In the M20, overfilling is generally good enough until have R compound tires and good suspension. I've been using that logic to hopefully be safe enough until I can get either the MMR baffle in there or convert whole hog to the S55 system. As far as Road Atlanta... Let's just say I've got enough laps there that my phone auto completes road Atlanta from "road". 😂 In a car like ours, 10b and 12 are two separate turns with a bendy straight between them. You exit 10b in third, straighten briefly, bend back right to go under the bridge more or less under the red square and touch or slightly cross the white line for the pit entry lane, then let the car drift back left down the hill to set up for 12. Shift to 4th and feather the throttle while berating yourself internally for not staying flat the whole way down the hill even though it's a street car with no safety equipment and 12 is fast fast fast. So there's a sold few seconds where there are no real lateral Gs happening for the oil to settle. |
11-19-2022, 05:26 PM | #13 |
Rep 38
Reading more of Doug's post, there is also a little bit of Negative G while going under the bridge, but it's pretty negligible so I doubt it's doing anything. It's enough to cause a loss of traction in the rain, but not in the dry, for reference.
dradernh4459.50 |
11-19-2022, 07:38 PM | #14 | |
Rep 3,505
As I say, however, that's just me, a guy who always looked to qualified sources when an engineering issue was the subject.
11-19-2022, 08:23 PM | #15 | ||
Rep 38
dradernh4459.50 |
11-20-2022, 03:15 PM | #16 | |
Rep 294
Drives: 2019 M240i Coupe RWD
11-27-2022, 02:04 PM | #17 | |
Rep 445
If anyone is monitoring oil pressure on track, please tell us how you are doing it. |
11-27-2022, 03:51 PM | #18 | |
Rep 3,505
