05-15-2016, 07:16 AM | #1 |
Member
902
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Front Passenger Footwell Power Outlet
Going through the owners manual and I've read there is supposed to be a Power Outlet located underneath the glove box compartment. When I went to investigate there is nothing but an empty hole. I also have the 493 Storage Compartment Package. Does anyone have this power outlet underneath the glove box?
05-15-2016, 07:36 AM | #2 |
Rep 5,112
My 2015 & 2016 235 did not have it. My z did though. I've wired everything to the fuse box in the trunk using a fuse-tap (i.e. dashcam, RD)
05-15-2016, 08:56 AM | #3 | |
Rep 886
You can still get the parts for the outlet, install it, and tap a power line if you want to have both.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 05-15-2016 at 03:11 PM.. |
05-15-2016, 03:12 PM | #5 |
Rep 886
Well. there's the one on the back of the center console. It's a nice improvement over not having one there in my E92.
05-15-2016, 05:00 PM | #6 |
Rep 5,579
05-15-2016, 05:33 PM | #7 |
Member
902
Rep 2,032
Yes, there is on the driver side.
05-15-2016, 07:22 PM | #8 |
Rep 886
Yup, assuming you remember to reconnect it after installing an amp or ASD removal harness. Ask me how I know.
05-24-2016, 07:22 PM | #9 | |
Rep 101
Did you get an error message 'Battery Discharge' after doing the fuse-tap? |
05-24-2016, 07:47 PM | #10 |
Rep 886
I have my V1, front dashcam, and a mini-USB for phone charging all from a single tap on the radio fuse in the trunk fuse block. I got no error messages after setting up the tap. FWIW, the tap is on the back side of the fuse.
05-25-2016, 06:46 AM | #11 |
Rep 5,112
No battery discharge messages at all. Both devices have been installed for quite some time and I haven`t had any discharges messages whatsoever. Works like a charm when tapped in to the fuse. For the 235 I used fuse number 147 in the trunk (credited to forum member Lazee1) but can`t recall what number I used in the x3.
05-25-2016, 10:42 AM | #12 |
Rep 99
12-25-2021, 05:42 PM | #13 |
Rep 4
2016 f87 m2
in KOREA..
There is no socket at there. Just 2 sockets. downside of radio and trunk. But there is HOLE at under grovebox... So, I want to make Socket at there. I'm trying.. haha |
12-27-2021, 02:24 PM | #14 |
msej449
514
Rep 717
My 2016 UK M235i Convertible has four sockets as standard, (i) under the passenger glove box, (ii) between the front cupholders, (iii) between the rear centre vents and (iv) on the left trunk wall.
I was going to no-charge-delete the smokers package but fortunately, the dealer recommended leaving it as standard. As deleting the smokers package would lose me (i-iii) and (ii) is where I would insert my small rechargeable torch. They also said to leave it as standard in case I wanted to resell it to a smoker who might be put off if the sockets weren't there.
2023 Peugeot e-208 GT (electric) Last edited by msej449; 12-28-2021 at 06:21 AM.. |
