01-03-2017, 03:04 PM | #1 |
Supreme Allied Commander
3842
Rep 54,353
Drives: F80 M3
Awe Tuning Bmw F22 M235i S-flo Carbon Intake
The perfect compliment to the M235i’s athletic spirit. The AWE Tuning BMW F22 M235i S-FLO Carbon Intake:
63.4% increase in air filter surface area Featuring the AWE Tuning ® S-FLO Filter Easy access design allows for filter inspection, removal, and replacement without removal of entire air box No extra couplers in system means smooth flow from filter to turbo inlet Fully sealed carbon fiber box and filter combination Max gains of 9hp and 15ft-lbs of torque at the crank Perfect integration with OEM inlet ducting Retains stock mounting locations Plug and play MAF and breather locations UV stabilized resin and clear coat prevents yellowing from heat Included S-FLO Filter is durable and washable Featuring No Check Engine Light Guarantee Perfect Fitment - Guaranteed The carbon fiber air box The AWE Tuning BMW F22 M235i S-FLO Carbon Intake is a fully enclosed carbon fiber air box made from high grade UV stabilized 2x2 twill carbon fiber to reduce yellowing from under hood heat. This air box mounts securely in the stock location and mates up to the factory air inlet pipes, perfectly. It boasts simple access for filter inspection and helps to deliver as much power as it does good looks. The AWE Tuning ® S-FLO Filter The included AWE Tuning ® S-FLO Filter is specifically designed to maximize airflow in the AWE Tuning ® S-FLO Carbon Intake. This increased flow unlocks impressive max gains of 9hp and 15ft-lbs of torque at the crank. The carbon fiber airbox and S-FLO Filter combination makes for an easily serviceable air filter without removing the airbox. The combo produces a more aggressive intake note than stock, with a distinctive turbo spool sound, all while keeping your car operating Check Engine Light free. What’s in the Box The AWE Tuning ® S-FLO Carbon Intake includes the carbon fiber airbox itself, the AWE Tuning ® S-FLO Filter, and all necessary mounting hardware. Please note, AWE Tuning S-FLO Intakes are for racing use only. SKU: 2660-13036 Installation instructions: http://www.awe-tuning.com/media/pdf/...35i_intake.pdf Fits: F22 M235i F3x 335i, 335ix, 435i, 435ix and convertibles $850.25 Order here: http://www.hpashop.com/AWE-TUNING-BM...2660-13036.htm Last edited by HP Autosport; 01-03-2017 at 03:37 PM.. |
02-15-2017, 04:32 PM | #15 |
3842
Rep 54,353
Drives: F80 M3
Awe Tuning Bmw intake
