01-27-2017, 10:00 AM | #23 |
Rep 2,825
if you are not at the limit of adhesion around corners I dont imagine it will do much, but any sort of sliding/oversteer will be alot better. you will also have better traction off the line.
01-27-2017, 10:03 AM | #24 |
Rep 3,395
Its also a bonus for folks with a RWD F22 that drive in the snow.......
01-27-2017, 10:35 AM | #25 |
Rep 2,825
01-27-2017, 10:47 AM | #26 |
Rep 3,395
01-27-2017, 11:05 AM | #27 |
Rep 8,942
If you mount studless ice and snow tires and put 100lbs sand in the trunk you will be total fine no LSD. Just be a bit careful cornering at speed the back end will be a tiny bit more ready to step out on you.
01-27-2017, 11:26 AM | #28 | |
Rep 3,395
Was/Am using Hakka R2's and had same weight in the trunk The difference after the addition of LSD is profound.....when I say this, I'm reflecting on how much better it performs on going UP the "Cliff" of a hill I live on in snow. |
01-27-2017, 11:34 AM | #29 | ||
Rep 8,942
JL1002133.50 |
01-27-2017, 11:45 AM | #30 | |
Rep 3,395
Most of my neighbors run studded snows to add perspective. |
01-27-2017, 11:47 AM | #31 | ||
Rep 8,942
This shit is the worst in the northeast with the hills. Midwest soooo much easier.
01-27-2017, 11:51 AM | #32 |
Rep 556
These LSD threads usually fall into a fairly predictable pattern. Those that say you don’t need it for driving around town and others that say you do citing all sorts of performance benefits. So, to the question that continually pops up here; Do I need a limited slip differential? The short answer is no, you don’t need a limited slip differential. But then, if you look into your soul of souls and really think about it, you don’t need 13.4 inch four piston disc brakes, or a 320 horsepower direct injection 3.0 liter engine, or Adaptive M suspension with variable damper control. In fact you don’t need a BMW! I suspect though that you wanted a BMW, most likely because it is a fun car to drive, looks cool, and has a reputation for being, for want of a better moniker, "the ultimate driving machine". These are all very good reasons that entered in to your illogical decision to spend $50,000.00 on a sports coupe that is smaller and less practical than a $15,000.00 Toyota Corolla.
But, what makes it the ultimate driving machine? Is it the laser focused design of the car to maximize performance and handling above all else? Or is it a cleverly effective marketing plan designed to make you feel good on the road as you crush your enemies, see them driven before you, and hear the lamentations of their women? Where you fall on that spectrum, marketing versus performance, determines to some degree whether you purchase a limited slip differential. Let’s face it, BMW put in an open differential as standard equipment for one reason and one reason only, to lower the cost of the car by 5%. This is a logical move from a profit standpoint as it widens the appeal to a broader audience, most of whom wouldn’t even be able to tell you where the differential is let alone describe the difference between an electronically assisted open differential and a limited slip differential. So, dear reader you don’t need one, but if you’re in the small minority that believes an overly expensive high performance sedan should have a performance differential, get one whether you need it or not. The rest can be content knowing they are driving one of the coolest best handling cars on the market. Last edited by mdputnam; 01-27-2017 at 12:01 PM.. |
01-27-2017, 11:56 AM | #33 | |
Rep 3,395
Heading out if you blow the 45 degree down hill left hand turn onto the 1 lane bridge at the BOTTOM of the hill you go off a 20' embankment into a river. This same geography makes it challenging to get much of a running start up the multi pitch climb....where the steepest section is the last...... Its so bad my oil guy told me I better plan ahead because he wont go up my hill for a couple days after a snow storm......... Cant tell you how many times I've had to "Plow" a set of tracks up the hill and back down to take 2-5 additional "Plow" runs before I could make it UP the whole hill........this hill is a natural barrier to neighbors who are not particularly hearty |
01-27-2017, 12:01 PM | #34 |
Rep 3,395
01-27-2017, 01:04 PM | #35 |
Rep 5,577
Don't limited slip differentials lose their efficiency over time?
I had read years ago that rear differentials with clutch packs lose efficiency rather quickly. But how about other types of limited slips? |
01-27-2017, 01:54 PM | #36 |
Rep 1,202
Torque biasing types (Quaife, Wavetrac) don't wear like a clutch type due to using helical gears instead of clutch mechanisms for its operation.
01-27-2017, 08:47 PM | #37 | |
Luxury at the redline :)
9105
Rep 7,563
Point being is that you can't blame BMW for the smart strategy of not including an LSD stock, even though the brake-based fake ELSD KILLS the power around spirited corners. It saves them money and in turn, they pass alone the savings to us in the form of a lower sticker price (imagine how many M badges we can buy now..) I am just grateful that BMW listened to us minority drivers, all the way from the E90 days and at lease offered the MP LSD as an option, regardless of the cost.. I have one and I don't regret the money spent at all (No more DSC flashing) If you have to ask about an LSD, you probably need one.. Last edited by Poochie; 01-27-2017 at 08:52 PM.. |
01-27-2017, 10:08 PM | #38 | |
Rep 587
TL;DR: No. It isn't.
I suspect that driving it all the time in ways that an LSD is important for would get you frequent tickets and/or arrests You can always add one later if you find RWD with an open diff and DSC insufficient.
01-27-2017, 10:28 PM | #39 |
Rep 671
I have another solution. I could just revert back to driving my boring but serviceable Ford Focus all the time, and put on the snow tires every winter.
And, I could use the savings to spend most of the winter somewhere warm, every year. If I was worried about badges and such, I would have put all sorts of crap on my 1-series. And, thanks for calling me "dear reader." I'll remember that when I go to the gym tomorrow. Think I'll throw an extra plate on every bar--I always work out better if I am a bit irritated ; ) |
01-28-2017, 05:23 AM | #40 | |
Rep 5,538
jpnh1424.50 |
01-28-2017, 10:11 AM | #41 |
Rep 3,395
01-28-2017, 12:38 PM | #42 |
Rep 447
I added an LSD on my tuned 135i and never tracked that car. You won't notice much if anything from a straight-line acceleration standpoint, at least I didn't. I noticed it most when making sharper turns. Without the LSD the car's traction control and other nannies would kick in and you simply wouldn't accelerate, but rather pause and accelerate not so fast until the car was pointed straight again. With the LSD you could aggressively make turns without the interference. Now this was the 135i and I know of an m235 with xdrive and I find if I put it in sport plus mode it rarely if ever has the same issues as the 135i did without LSD so maybe the 235i is a little less intrusive, but it may just be xdrive vs RWD.
It's a nice to have, not a got to have as you can turn off most of the interfering stuff and most will find this sufficiently sporty.
01-28-2017, 12:40 PM | #43 |
Rep 5,372
I'm telling you, drive around in DSC OFF and take note of just how easy it is to get the rear wheels to spin in a drift, lay equal tracks of rubber, etc. I NEVER see any DSC lights flashing because all the nannies are off. The eLSD is pretty dang good in most all situations. Add really sticky rubber and you may be hard pressed to find a measurable difference in lap times on most tracks.
01-28-2017, 08:37 PM | #44 |
Rep 671
Again, thanks for the replies. Still thinking about it. Not that it is about the money, but minus metallic paint, and heated seats, that's half of the cost of an LSD. Something to think about, because I am a bit on the thrifty side (thanks, Dad). I've never slid my 128. But, that is 100 HP less.
