07-22-2016, 07:45 PM | #1 |
Rep 5
North East - M235i xdrive convertible in winter
Hey all,
I'm getting back to the world of BMWs after a long hiatus. I've never had a convertible before and would like to know if anyone who actually drives their car in the winter if the convertible is going to be too much of a hassle. This is going to be my daily driver, and I like the idea of a convertible but if the reviews are negative then I'll just suck it up and go with the coupe. Odds are I will work from home if it's real nasty out, but interested in hearing experiences with cold, windy days etc. Any experiences would be great. |
07-22-2016, 08:46 PM | #2 |
Rep 1,452
What would make you think that a convertible would be a problem? Everyone we have had had an insulated top. If there is a major snow,just wipe the snow off the top. Heating the inside has never been a problem. Do the coupes lower the window slightly when the door is opened? If they do then there is no difference. If only the convertible does that then ice could be a problem.
07-22-2016, 08:55 PM | #3 |
Rep 5
Really just asking the question about any known issues to be cautious. The seal it made seemed pretty good with the body, unlikely any ice buildup would come in from there. Those are the types of things I'm interested in learning.
07-22-2016, 10:04 PM | #5 |
love to fish!
46
Rep 649
Drives: 13: SG 135i M-Sport Cabrio 6mt
I live in Vermont, drive a 135 vert. Put four snows on go anywhere. Never had a problem and that is with rwd, you will have xdrive. It's all good. Enjoy the ragtop!
PSS|PPK|PE|LUX H8 V4's|CDV Delete|Performance Pedals|Motorsport Emblem|
07-23-2016, 06:06 AM | #6 |
Rep 886
Yup, to clear the top edge trim. In fact, during an ice storm I got so much buildup on the doors that neither window would drop, and I couldn't get into the car without 10 minutes of ice chipping.
07-23-2016, 06:54 AM | #8 |
Rep 8,942
You'll be totally fine like others have said either with a good all season (DWS 06) or even better a dedicated set of winter wheels and tires. Only thing I'd be mindful of is if you're someplace prone to excessive snow and you get over a foot, brush the roof off. When that stuff gets wet and heavy it can weigh a lot. You'd probably be totally fine but 2 mins of effort seems like a good investment for some added peace of mind.
07-23-2016, 06:13 PM | #9 | |
Rep 2,067
When the 228i xDrive ragtop came in MY 2015, we sold both the 128i ragtop and X1 SUV and replaced both with the 228i xDrive ragtop in the early spring 2015 on the basis that we would see if the 2er xdrive ragtop could be a suitable all year all weather vehicle. If we found that the 2er ragtop was deficient in any way handling all sorts of weather or road conditions, we would revert to the ragtop and SUV paradigm. 16 months onward and every type of weather, we have not missed the SUV one iota. Last fall we switched the 2015 228i xDrive ragtop for the 2016 M235i xDrive cabrio (due to a BMW recall/replace program) and the M235i xDrive ragtop handled all weather/road scenarios as well as the 228xi ragtop. Could not be more pleased with the 2er xDrive in ragtop format. BTW, I run the OEM RFT A/S in the winter and had no problems. Don't let that out though as a lot of winter tire aficionados here will pee all over me for that..
2019 X2
07-24-2016, 07:02 AM | #10 |
Rep 50
Here's the problem as described above.
I've had about 6-7 BMW's where the window goes down a few inches when you open the door. On those days where the moisture freezes on the car, the window wont go down and you can't really open the door freely. What I do is take a credit card and run it the entire length of the window between the rubber and the window at the bottom. This 'breaks' the frozen seal and allows the window to retract. Except for that, the convertible is 100 percent worth it. Good luck with your decision. Moke |
07-24-2016, 08:00 AM | #11 |
Rep 6,029
Glad you've been good so far! No doubt those tires can help you get going. If/when you ever need to really stop/turn evasively in winter, I think you may wind up just peeing on yourself!
07-24-2016, 08:53 AM | #12 |
Rep 5
Thanks all
Thanks all for your thoughts. Yes i remember back on my old e36 the joys of the ice around the window when it was trying to drop to open the door. That never bothered me much.
I will definitely need to keep an eye on the snow pack on top though. During the work day we can easily see a foot or more plus additional from wind drift etc. Appreciated the note from Vermont! As i'm currently sitting in the green mountain state and will be traveling here a bit during the winter to come up and visit family and skiing. I did see i could get my skis to pass through the rear seat area. I will probably end up getting a dedicated set of winter tires and rims, just because i have a pretty good resource to help reduce the overall cost. I see a lot of people keep them squared up for winter vs. the offset that it looks like the M235i Xdrive comes with. |
07-24-2016, 10:14 AM | #14 | |
Rep 50
07-24-2016, 09:40 PM | #15 | |
love to fish!
46
Rep 649
07-24-2016, 10:39 PM | #16 |
Rep 5,538
07-27-2016, 02:05 PM | #17 | |
Rep 227
http://www.autogeek.net/1z-einszett-...are-stick.html Works great for all the weather seals and keeps them working well, not sticking.
Current
19' G05 X5 40i 03' e46 M3 Convert. Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi |
