07-15-2016, 08:45 AM | #1 |
Rep 52
M235i A/C Question
Noticed that when I turn the A/C on higher settings, the car will have a vibration when idling at a Stop Light.
Is this normal? Also another thing I noticed is that when I have the fan at Max, it seems like the passenger side fan doesn't kick in until car has been running for about 5 minutes. I'll be driving around and all of a sudden I can hear passenger side fan kick in. Car is 3 months old about 5k miles on it Not sure if this is normal or not. Thanks, K |
07-15-2016, 08:59 AM | #2 |
Rep 3,331
The AC compressor runs off the accessory belt so when the car is demanding it to run at the highest load possible (especially on extremely hot days in the middle of summer) it can cause the engine idle to drop more and vibrate a bit. This is normal, and almost every car will do this in similar conditions (I see you're in Texas, so I'm guessing its pretty hot).
For the fan kicking in, are you using auto or manual mode? Auto usually waits until the AC compressor actually begins cooling off the air before blasting you with a steamy blast of air, but it shouldn't take 5 minutes. I'm not sure if that's just a result of extreme heat or not. If you are in auto mode, try manually changing the passenger vent setting and see if it turns it on - that will tell you if it's just the computer intervening.
Current: '20 X5, '18 M3 ZCP
07-15-2016, 09:57 AM | #3 |
Rep 556
The high today in Houston is 100 degrees, On Tuesday it will be 99 with thunder storms. The high in San Diego will be 74 degrees, the solution to your problem is clear.
07-15-2016, 07:02 PM | #4 |
Rep 6,936
Drives: 2018 M2 AW DCT
07-15-2016, 11:24 PM | #5 | |
Rep 2,526
Drives: 2011 328i Wagon
I just bought a '95 Land Rover Discovery that lived in San Diego it's entire life - silly thing is SHINY underneath. And on top, and inside. For the OP - sounds pretty normal to me, and my M235i does the same stuff when it is 95F+ out.
07-17-2016, 06:51 AM | #6 |
Rep 628
Being from LA and having gone though our massive heat wave last month when the temps hit 117 the behavior you are describing is completely normal. BTW I'm impressed with how ice cold the AC is in this car.
07-19-2016, 04:06 PM | #9 |
Rep 1,452
07-19-2016, 05:59 PM | #10 |
Rep 72
07-19-2016, 07:27 PM | #12 |
Rep 1,452
07-19-2016, 07:31 PM | #13 | |
Rep 442
07-19-2016, 09:17 PM | #14 |
Rep 1,797
AC in my M235 is no where near as effective or powerful as the one in my wife's X4
Only a year difference in vehicle age too....
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
07-20-2016, 10:25 AM | #15 | |
Rep 52
Like a long vibration followed by 2 short ones. then pause and then it happens again. Something along those lines K |
07-22-2016, 09:12 AM | #17 |
Rep 52
