2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions F22 coding cheat sheet
      05-08-2018, 01:39 PM   #2003
Bombermon3
I recently got "Chassis stabilization: Drive moderately, and Increased steer. effort. Drive moderately" code.. The Dealer says it is my electronic steering rack. I got quoted at 4k for them changing it and "programing" it to the car, and getting an alignment.
The car feels fine driving, in sport mode it seems like there was nick every now and then.. I have wider front rims. 18x8
I could not delete the codes using a Autel scanner.. On your program (E-sys software) can I code out the steering rack? so I don't have to replace the steering rack? Or if I buy and used rack, can I "program" it to my car??
The scanner read :ESP control unit. Fault, rotor position sensor (steering angle index). belt jump detected.
      05-08-2018, 07:50 PM   #2004
pikcachu
pikcachu's Avatar
849
Drives: M235i (F22 Red angel)
I wouldn't drive with a broken steering rack.
For programming the control unit you need ISTA if you buy a used one you will need to program it but you need to know what you are doing
Funny thing I got mine replaced under warranty as there was a knocking sound when shuffling steering left and right quickly or sometimes over bumps
      05-09-2018, 12:37 AM   #2005
Almaretto
Almaretto's Avatar
Drives: Coded '16 F10/F15 MSport
If you code out hardware, it will not work.
Personally, I would not want to drive around with malfunctioning steering.
      05-15-2018, 04:47 PM   #2006
zup2sky
Drives: M235I AW
Originally Posted by zup2sky View Post
Hey Everyone. I was able to successfully add digital speedometer in the BC and M Performance logo too. In doing so, my fuel consumption gauge switched from KM/L to MPG. I own a Canadian BMW and I'd like to have KM/L instead.
Also, I noticed M2 Cluster have digital clock on the right corner of the cluster. Can we code in the M235i/ M240i cluster?
To contribute to this community, let me answer my own question
1) The fuel consumption gauge unit can be switched via setting on idrive.
2) The digital clock can be added via following code on KOMBI:
BASISANZEIGE_VARIANTE" to "aktiv"
      05-20-2018, 06:25 PM   #2007
Randyran
Drives: X6
Extended Bluetooth
Can I upgrade my Navigation system Professional in my 2015 X6 to get extended bluetooth? The office app doesnít show in bluetooth screen only shows in BMW online. Help
      05-20-2018, 06:45 PM   #2008
Almaretto
Almaretto's Avatar
Yes, just VO code NBT with 6NS.
      05-21-2018, 05:39 PM   #2009
Randyran
Drives: X6
Is there a cheat sheet for VO coding for F16
      05-21-2018, 11:24 PM   #2010
Almaretto
Almaretto's Avatar
VO coding is used to add or remove factory options. E-sys takes care of making necessary changes. Cheat sheets do not exist for VO coding, other than those for NGHB.
      05-24-2018, 06:39 PM   #2011
Randyran
Drives: X6
Enhance bluetooth
I donít see NBT, in the list of codes. Can I add 6NS?
      05-25-2018, 01:46 AM   #2012
Almaretto
Almaretto's Avatar
NBT is not found in FA. NBT is found in SVT.
      05-25-2018, 08:33 AM   #2013
Randyran
Drives: X6
When I go to the SVT i see HU_NBT with only one check on CAFD. Now how do I change that to 6NS.
      05-26-2018, 12:25 AM   #2014
Almaretto
Almaretto's Avatar
Not how it works.
609 is pro navigation. That can be CIc, nbt, or nbt2 depending on production Year and chassis.
6ns is just another vo code.
      05-26-2018, 09:55 PM   #2015
mrcastle
Drives: 228i
Angry Help please
I used to be able to code everything just fine untill my dealership re coded everything when they broke my radio and screen. I got the latest esys and everything in a new computer and i am only able to code HUNAV as of now for FEMBODY and BKOMBI I keep getting this error. Does anyone know how to fix it?
      05-26-2018, 10:42 PM   #2016
Almaretto
Almaretto's Avatar
Attachment 1831287
Choose F020 in E-sys
      05-29-2018, 12:57 AM   #2017
mrcastle
Drives: 228i
I chose F020 and it is fibbing me the exact same issue, it only does it for BKOMBI and FEM_BODY
      05-29-2018, 01:28 AM   #2018
Almaretto
Almaretto's Avatar
      05-31-2018, 03:18 AM   #2019
jimmy235
Hey folks,
hope you all doing well.
I am Coding since i got my M235i in 12/15.
Last week i got an ECU update, cause Connected Drive hasn`t had Internet connection anymore.
So yesterday tried to Code all my stuff again and most of them worked.
But i am not able to change the blink indicator amount anymore.
Had werte=04 before and now it doens`t change in any case.
I also figuered out that the "lane changing warning" is changed from factory. It is now activated only above 70km/h
Any idea?
      05-31-2018, 09:22 PM   #2020
Almaretto
Almaretto's Avatar
Originally Posted by jimmy235 View Post
Hey folks,
Any idea?
Blinker no longer possible to change.
Search this Thread:
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
