01-29-2016, 07:34 PM | #1101 |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
SOUND_SIGNAL_SET
Default: bmw Changed: rolls_royce "Premium" Rolls-Royce gong, sounds better than the BMW one: It also emphasizes that you'll be paying top dollar when the gong goes off and the CEL turns on
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
01-29-2016, 09:48 PM | #1102 | |
Rep 47
Am I doing something wrong? |
01-29-2016, 10:00 PM | #1103 |
Rep 5,262
01-29-2016, 10:16 PM | #1104 |
Rep 47
When I compared 6NH vs 6NS, a few different were
HU_NBT_EVO > HMI 3000 > CDMM_USB_PORTS = usb1_sia (USB1 in 6NH) HU_NBT_EVO > HMI 3000 > HMI_36_36_8 = aktiv (Nicht_Active in 6NH) HU_NBT_EVO > TELEFON_TELEMATIK_ONLINE 3003 > AUDIO_NOTES_EIN_AUS = aktiv (Nicht_Active in 6NH) Others don't show up > CDMM_USB_Audio |
01-29-2016, 10:23 PM | #1105 | |
Rep 5,262
01-29-2016, 10:29 PM | #1106 |
Rep 47
01-30-2016, 04:02 PM | #1107 |
Rep 1,254
It appears with the newest software update to my car. Activating the rear fog light is not working. Anyone know if the codes changed?
Here is my write i did before the dealer updated my car. http://www.2addicts.com/forums/showt...&highlight=fog
01-31-2016, 04:28 AM | #1109 |
Rep 35
Well Ive added 6NS to the FA and coded it to the HU_NBT2 (no combox)
I now have a small '1' next to my phones on the Bluetooth devices page on the Idrive. There are only options for audio and telephone but no office,and when I re-pair the phones there is no option for enabling notifications,so I guess it's not working. Is there anything else I need to code? |
02-01-2016, 05:23 AM | #1110 |
Rep 444
It seems like they cracked the TPMS for a 2015 F30. Any of the experts think it will work for us?
http://f30.bimmerpost.com/forums/sho...1214970&page=2
Quickest Stock Turbo F8x In The World
02-01-2016, 06:51 AM | #1111 | |
Rep 47
02-01-2016, 10:28 AM | #1112 | |
Rep 5,262
So remove 2VB from the FA and VO Code DSC NBT ICM KOMBI seems like |
02-01-2016, 05:37 PM | #1113 |
Rep 444
If someone wants to give me step by step instructions I'm willing to try it.
I have no idea how to remove 2VB from the FA. I'm assuming the VO code is the same thing we've been doing to add speed to bc, etc?
02-01-2016, 06:49 PM | #1114 | |
Rep 5,262
http://www.2addicts.com/forums/attac...8&d=1418672353 be advised that VO coding will wipe all your FDL coding so you will have to re-do any FDL coding that you had on the ECU's that you VO code.... (DO NOT VO CODE the whole ECU tree, that will VO the whole car, make sure you have a single ECU selected) alternatively you could FDL code all the single items they say on that post and see what happens FEM_01 > RemoteControl 30D0 > RC_RDC_ENABLE = aktiv ICMQL > Daten 3000 > IcmKod_B_S2VBA = verbaut DSC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RDCi_l = nicht_aktiv [Default] DSC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RPA_e = nicht_aktiv DSC_CT01 > DSC_CODIERDATEN_RPA_CONTI 3002 > C_RPA_Extra = nicht_aktiv HU_NBT_EVO > EXBOX 3001 > RDC = aktiv HU_NBT_EVO > EXBOX 3001 > RDC_DRUCK_TEMP = druck HU_NBT_EVO > EXBOX 3001 > RDC_FORTSCHRITTSANZEIGE = nicht_aktiv [Default] HU_NBT_EVO > EXBOX 3001 > REIFENUEBERWACHUNG_RDC_RPA = rdc HU_NBT_EVO > EXBOX 3001 > RPA = nicht_aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_ALIVE = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_TIMEOUT = aktiv KOMBI L7_MID > FZG_Ausstattung 3003 > DSC_MIT_RPA = ohne_RPA [Default] |
02-02-2016, 04:32 AM | #1115 |
Rep 444
Did all the single items first and it's a no go. After some research, found out how to remove the 2vb. Will report back tomorrow.
02-02-2016, 09:05 AM | #1116 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
Does anyone know if the outside temperature warning can be coded off?
02-02-2016, 07:04 PM | #1117 |
Bright Sky
1164
Rep 922
I've written a step-by-step guide on how to install and setup E-Sys for people who are overwhelmed and can't seem to get the application running right. It explains even the very basic steps one by one, so anyone should be able to do the installation:
https://mega.nz/#!lRgVBLzB!U9JUAYYL4...4K_YJUHPLsRHqs I will likely write a procedure for actual coding in a similar format at a later time. Comments/suggestions/constructive critisism are always welcome of course.
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. Last edited by wjjkoevoets; 02-03-2016 at 02:31 PM.. |
02-02-2016, 08:08 PM | #1118 | |
Rep 1,254
Not sure if you seen this youtube video but it definitely helps with coding. I was a bit hesitant at first but after watching this video i started coding with out issue.
02-03-2016, 03:28 AM | #1119 | ||
Bright Sky
1164
Rep 922
EDIT: Added rollback (back-out) instructions: https://mega.nz/#!lRgVBLzB!U9JUAYYL4...4K_YJUHPLsRHqs
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. Last edited by wjjkoevoets; 02-03-2016 at 02:30 PM.. |
02-03-2016, 02:39 PM | #1120 | |
Rep 5,262
02-03-2016, 02:49 PM | #1121 |
Bright Sky
1164
Rep 922
Of course! I hope it helps people.
02-04-2016, 09:49 AM | #1122 |
Rep 101
Drives: 2016 m235 xdrive
