08-16-2014, 08:44 PM | #221 |
Rep 1,078
I have successfully coded! For some reason I couldn't activate FA on my first attempt, but after I reconnected it went through. I wanted to thank pikcachu for all your help!
Coded: Digital speedometer No dimming of halos with headlights Roll up windows with key fob Fold mirrors with key fob Unlock doors with engine off Turn off radio when door is open The rest of the stuff I didn't care much for so I left it. |
08-17-2014, 02:01 AM | #224 |
Rep 1,078
I got a chance to look at the 100% halos at night now and it looks to be a bit too bright. From a distance, it almost hides the halos when the light is on because they're so bright. Rather than choosing one of the given percentages, I changed the actual value to 32. Since 100% = 64, can you confirm that 32 = 50%? At 32, it is definitely more noticeable than stock but not overpowering.
08-17-2014, 09:20 AM | #225 | |
Rep 5,262
08-23-2014, 10:54 AM | #228 |
Rep 5,262
I didn't, but it should....
you can always put the headlight switch to off and the washer won't activate... headlight washer will only activate on auto or on setting... so never bothered to code it |
08-23-2014, 09:46 PM | #229 |
Rep 1,254
Yes true i have done that on my previous car but at in pitch black night its a little dangerous. i just find they waste so much washer fluid and really don't clean the lights all that much.
08-28-2014, 10:11 PM | #231 |
Rep 5,262
a few more ...
auto map zoom - HU_NBT 3001 AUTO_MAP_ZOOM google voice search - HU_NBT 3000 GOOGLE_LOCAL_VOICE_SEARCH min speed for cruise control - ICM 3000 C_Wunschgeschw_min_mph |
starlord722.00 |
08-29-2014, 10:34 AM | #233 |
Rep 1,254
What does everyone do when bringing car in for regular maintenance like oil change or a problem covered under warranty? Do you change all coding back to stock?
08-29-2014, 10:58 AM | #235 | |
Rep 1,040
I don't believe a service department would care about your coding features. Might be another store during my end of lease pre-inspection |
08-29-2014, 11:12 AM | #237 |
Rep 1,254
Yea true that's what i figured but if you change the start up screen to the M logo might be a little suspicious. But then again most tecks probably see so many diff models they figure that might just be specific to the model
09-01-2014, 12:48 AM | #238 |
Rep 636
Does changing 'Ambiente_Helligkeit' from 64 to 99 even work....? 64 in hex is already 100 in decimal... so changing it to 99 would be at 153 :O
Has anyone tried this and reporting it to be 'effective'? |
09-02-2014, 05:58 PM | #240 | |
Rep 1,254
09-02-2014, 06:33 PM | #241 |
Rep 5,262
you can create it with google map and export it with tyre basic to the bmw format.
http://www.tyretotravel.com/download...ad-tyre-basic/ |
09-03-2014, 08:17 AM | #242 | |
Rep 1,254
