01-03-2024, 09:10 PM | #1 |
Rep 51
Exhaust valve actuator clip install
my clip broke off and im trying to install a new one but its not lining up with the actuator. I tried switching from comfort to sport mode and the actuator doesnt move...I also tried a different actuator. Is there anyway to recalibrate the actuator using ISTA+ or something else? many thanks!
01-06-2024, 03:08 PM | #2 | |
Rep 759
Drives: M2
'17 M2 DCT Long Beach Blue
01-06-2024, 04:03 PM | #3 | |
Rep 211
Here's a post with a few pictures that might help: https://www.2addicts.com/forums/show...8&postcount=26 And another: https://f87.bimmerpost.com/forums/at...0&d=1617470455 So, the notches on the actuator and flap should be essentially parallel to each other. If you can't get them lined up by spinning the flap, it might be the actuator. See below. Edit: Check this video out too: https://www.youtube.com/watch?app=desktop&v=zKg3K0tBAKk Looks like this person's issue was with the actuator itself, possibly overstroked past where it should stop and snapped the clip. If you have bm3/bimmercode/bimmerlink you could try using that to exercise the actuator and make sure it's working correctly. Last edited by TheHaze; 01-06-2024 at 04:28 PM.. Reason: More links/info |
01-13-2024, 07:15 PM | #4 |
Rep 51
i ended up breaking my actuator because i tried to force it to line up. I ordered a new actuator will give it a try. It should actuate at idle switching from comfort to sport correct? My old one didnt do that..
01-13-2024, 07:45 PM | #5 |
Rep 211
Not necessarily. I know for a fact the exhaust flap on my car stayed open at idle regardless of drive mode, engine temp, etc. Not sure if there was an issue or if this was by design. I installed a CG Precision VSC-1 valve controller when I put on my Remus exhaust so I could open and close them whenever I wanted.
02-12-2024, 03:41 AM | #6 | |
Rep 2
