09-18-2017, 10:48 AM | #1 |
Rep 1,184
Stainless Methanol Lines An-4 fitting
So I am almost finished doing a stainless steel line conversion to my methanol kit. I went with Devils own ss lines with an-4 fittings. Right now I have everything installed except for the line that goes from the tank to the pump.
I ordered a line with no fitting on one end so that I could install my own 120 degree hose end. The an-4 hose end that I ordered did not fit. the socket seemed a little bit loose. The fitting seemed too big to go into the hose end as well. https://www.amazon.com/Swivel-Hose-E...4+120+hose+end Can someone recommend a 120 degree an-4 hose end that will be compatible with devils own ss line. Here are the specs from their website. Tube diameter 1/4" (5/16" on my dialed caliper), nominal i.d. size .187". "Extruded teflon core with outer stainless steel braid for strength" |
09-19-2017, 12:44 PM | #2 |
IG @bmwF9xG80
3813
Rep 7,593
Jeff@TopGearSolutions
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
09-26-2017, 04:12 PM | #3 | |
3441
Rep 79,211
Thanks |
09-27-2017, 10:24 AM | #4 |
Rep 1,184
Yeah they weren't too sure on it. I ended up contacting a tech rep at jeggs. They are awesome! They responded to my email within an hour or 2 with a link to the correct part.
When I get some time on my computer I will post what worked, what didn't, and a sketch of how to correctly install the hose end. Got my wmi system back up and running last night. What a great dealing it is to have that power back! |
10-05-2017, 03:41 PM | #5 |
Rep 986
So i need a methanol update. How is the system working? Do you have the Jb4/meth integration kit ? What nozzles are you run ? Stock turbo, 93 octane ? What are you using for methanol? Windshield washer fluid or straight meth?
Dylan861330.00 |
10-05-2017, 05:26 PM | #6 |
Rep 2,214
^^ If you need more feedback I've been running the single CM10 Burger Meth kit, aligned with the JB4 and after dialing it in, I can say the car is running pretty strong, any stronger and the power wouldn't be very usable (maybe good for another 20whp or so via back-end flash). The car blew out any and all carbon buildup that used to exist on the tips, and the WW fluid (blue -40) has been working well, as it always has, for me.
One of the biggest things with Meth, is the tuning. And to me, the JB4/Bluetooth config has to be the best setup I've used on modern cars. I'll continue to run this setup along with a back-end flash, for next year and onward. |
10-06-2017, 07:15 AM | #7 | |
Rep 1,184
That being said the methanol system is up and running perfect. Car feels like a complete beast now even without e85 mixed in. Now that the system is smoothly I will have time to experiment with differnt methanol concentrations. I have been talking with one of the guys from pure turbos Peter a lot recently. He was telling me best results for him were around 80/20 mix by volume. That is likely where I will start. I was originally running 100% meth. I would use the yellow heet bottles from home Depot, gas stations ect. They are actually pretty confident. I would fill my tank up with about 11 of them, then just keep 3 or 4 in the side cubby in the back. That way I could always easily top off. I do plan on buying a 5 gallon drum of methanol and mixing with distilled water myself eventually when I find a supplier close by. I believe this will be the most controlled way to do things. Just make sure that if you go windshield wiper fluid that you get the cheapest kind and look for -20 degrees or whatever winter mix you can find. Once you have the brand that you are going to use check the msds sheets (Google it). That is the material saftey data sheets, those will tell you the methanol concentration. Just be aware that it may be by volume or by weight. Just make sure you convert to volume if that is the method you prefer. Then add the appropriate amount of heet to get to the blend you'd like to use. * Side note* notice that windshield washer fluid and heet, and most other similar bottles have a plastic/foil seal. When you puncture or tear it off the foil will somewhat delaminate from the plastic. It is only a matter of time before small scraps of foil ride the flow off the bottle and into the tank. I noticed this right away so I am always very careful to completely remove it or do a clean cut with a knife to avoid foil particles. When people say meth is finicky and clogs I suspect that the foil is a large cause of flow issues. I have the one gallon tank, stainless steel lines and an-4 fittings. I run dual nozzle injection on the charge pipe with a cm5 and cm7. I did run a single cm 10 at one point. 2 nozzles are slightly more of a pia to set up, but it feels like smoother flow. My car uses jb4 integration and is fbo. I always use 93 pump and occasionally add e85 when I happen to be driving by that gas station. I just bought an external GPS logger to track times like 0-60 or 60-130 as a performance measure. I plan on trying different settings in the jb4 on map 3 and maybe creating a map 6 tnd logging times to check performance. I am having an issue with my wheel fitment rubbing right now so I won't be logging untill I figure that one out. I rolled the fenders last night, but there is still one more spot that is rubbing and has substantially damaged my tire. I need to figure that one out and get a replacement tire before I start performance testing haha. Also I'd like to verify the GPS accuracy at the drag strip so I know that the numbers are precise and accurate. (Gpsx 160 skyview). It is supposed to be decent, but was also on the lower end for cost, $130. That is why i'd like to test it out, before dedicating the into "tuning". |
10-06-2017, 07:21 AM | #8 | |
Rep 1,184
I have also found e85 and map7 to be pretty fun as well. Although it does put stress on the hpfp for me. |
Dylan861330.00 |
10-06-2017, 07:28 AM | #9 |
Rep 1,184
As far as power difference goes, I think my butt Dyno is broken or just not sensitive to change.
From stock to map 1, to map 2, to map2 fbo, I hardly notice any change. Map 7 with e35 though... That's another story Map 3 with methanol.... That's another nother story Map 3 with e35 and methanol .... Winning Map 3 I have 265 mpss in the rear. I had been driving for about 15-20 min so the car was warm and tires at normal temp. It was about 60 farenheit, so not the warmest, but not too bad. In sport plus, on a dry, level, clean road I could mash the pedal at 40-45 mph and have both rear tires spin a decent amount before traction control would step in. Map 2 fbo Similar condition I think the best I could get was a chiro rolling from 20 mph. The timing advance that the methanol or e85 gives you is equally important as the amount of boost imho |
10-06-2017, 08:05 AM | #10 |
Rep 1,184
also to keep this on track here is a sketch that I made up of the fitting assembly that worked that worked.
Here's a link if anyone is interested. http://www.jegs.com/i/Earls/361/612194/10002/-1 there's a 25$ steel version that I got. Here's a link to the one that didn't work https://www.amazon.com/dp/B074J85R35..._7HNYzb8SPPHB9 |
10-06-2017, 04:48 PM | #11 | |
Rep 2,214
Happy camper. I'll take 15-16psi with 10* of timing advance over 19psi with none, it feels so much better. I will be doing a back-end flash while the car is parked over winter. Sounding like BM3 w/the Enzo file is the way to go? Last edited by Dylan86; 10-06-2017 at 05:11 PM.. |
10-06-2017, 04:54 PM | #12 | |
Rep 1,184
Right now mine feel like the opposite. It accelerate pretty good, then the meth hits and I literally feel like I just hit the nitrous button fast and curious style. Its not really too harsh or choppy, but there definitely is a surge in power when it is spraying. |
10-07-2017, 11:27 AM | #13 | |
Rep 2,214
10-09-2017, 08:40 PM | #14 | |
Rep 1,184
Then voltage from 0-5 equals 0-100% meth flow? Would you mind sharing the settings that you use? |
10-09-2017, 08:44 PM | #15 |
Rep 1,184
http://www.n54tech.com/forums/showthread.php?p=159161
This is what I have been reading up on. Looks like it is for the n54. I'm assuming that the n55 is similar? |
10-10-2017, 03:54 PM | #16 | |
Rep 2,214
I have used the suggested flow scaling, from Burger, never touched it otherwise. I believe it's set to 60, for signal scaling? I'd like to know if there's a better way, but my experience with the JB4 is very vague. Into learning more, though, always.
10-17-2017, 07:56 PM | #17 | |
Rep 1,184
10-18-2017, 10:06 AM | #18 |
Rep 2,214
