Has anyone re-installed the stock exhaust after installing MPE? (M235i) |
09-04-2017, 10:14 PM | #1 |
Rep 505
If so, was it easy? From what I remember, stock exhaust had to be cut in order to install MPE. So I'm wondering if I have to do something different to reinstall the stock.
Currently have MPE, but I might sell my car stock. Want to get an idea of the process. Thanks in advance! |
09-05-2017, 10:55 AM | #2 |
Rep 181
It depends on the install ofc.
If the MPE muffler was welded after stock being cut then you have to cut/weld again. If you used BMW´s exaust band(that covers the cut between pipeing-muffler) then just replace the muffler, could be done from a parkinglot. |
bimmer4life24267.50 |
09-05-2017, 01:29 PM | #3 |
Rep 1,931
its probably easiest to:
1- remove clamp 2- unbolt hangers and drop the entire exhaust 3- remove hangers and put on other exhaust while off the car 4- bolt the exhast back on the car, plug in valve, re-do the clamp Shouldn't take more than 20 mins.
www.nybmwcca.org
09-05-2017, 01:39 PM | #4 |
Rep 505
I had my local BMW dealer install the MPE. You think they used the clamp method or weld method?
09-05-2017, 02:04 PM | #5 |
Rep 1,931
just look under the car.
www.nybmwcca.org
JP's M2xx20.00 |
09-06-2017, 08:42 PM | #7 |
Rep 505
Thanks for all the advice, everyone.
Has anyone removed the stock black tips from MPE and put back on stock exhaust? If so, what method did you use to do that? |
09-06-2017, 09:16 PM | #8 |
Rep 1,931
wd40, rubber mallet.
spray the rear of the tips... drink a beer.. go to work knocking them off.
www.nybmwcca.org
bimmer4life24267.50 Mbezzled0.00 |
