10-08-2021, 11:08 AM | #1 |
Rep 283
My 2021 m240ix has a little less than 9,000 miles on it. I drive with the top down most days, but it does get put up a few times a week.
Today I noticed that the rubber around the windows (bad description, see picture) is showing some creasing and wear. Is this normal? It's on both sides in about the same spot, but the left side is more severe. I will be going to the dealer for my 10k mile oil change (don't worry, I did one at 5k) soon and wanted to know your thoughts before I bring it up. |
10-09-2021, 12:46 PM | #3 |
Rep 283
10-10-2021, 03:31 PM | #4 |
msej449
518
Rep 721
BMW does recommend that you always keep the top up when storing the car, even if it's garaged. This is to keep the fabric under tension. That said, what you show in the photos' is not normal, I'd say. Mine is at 36,000 miles and shows nothing like what's in the photos. Indeed, I'd say that your top looks like it's got more creases and bumps than mine.
10-21-2021, 07:58 PM | #5 | |
Rep 283
08-08-2022, 05:12 PM | #7 |
Rep 283
As a follow-up, it has gotten it tad worse, but more of a blemish . I had the car in for a suspected coolant issue (which they can't duplicate/figure out) and asked the dealer for an opinion. Apparently, when the top is down, the back cover is touching those spots and causing the wear. The dealer sent pictures to BMW, and they said it was normal. Seemingly the technicians didn't agree and pressed the issue. From some magical place, someone from BMW is visiting the dealer tomorrow to see it in person… let's see what they say. I've been without the car for over seven days now…
08-15-2022, 02:22 PM | #9 |
Rep 1,146
doesn't sound right, I'm a total top down sl*t, i drop my top every chance I get done 7k no sign of wear. my 1 series on 22k, to 150k, had some very slight material crimps shall we say but NOTHING on that side
sounds like it's rubbing somewhere I'd bet you only fix is a new roof or major component and there not going to swap a whole roof or top just for that |
