2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Engine / Drivetrain / Exhaust / Bolt-ons AutoTalent | Dinan exhaust+roll bar+spring set+tuner for Bmw F22/23 M235i 2014-2016
      09-25-2019, 01:13 PM   #1
AutoTalent
AutoTalent's Avatar
2312
Drives: e92 M3 6mt | e60 M5 6mt
Dinan Free flow Exhaust
To order exhaust polished tips with m-performance rear valance please visit our website by clicking HERE
To order exhaust black tips with m-performance rear valance please visit our website by clicking HERE
To order exhaust polished tips please visit our website by clicking HERE
To order exhaust black tips please visit our website by clicking HERE
The system is built to exacting specifications to ensure perfect fit using the factory hangers. It is made from 100% 16 gauge 304 stainless steel and will resist corrosion for years to come. The design features twin 89mm polished exhaust tips for a tasteful, high-performance look.
Features
+ Includes mounting hardware
+ Helmholtz chamber to reduce drone
+ Enjoyably louder, sportier Sound
+ 100% 304 stainless steel construction
+ Twin 89mm laser engraved polished exhaust tips
+ 6 HP @ 6600 RPM, 5 FT-LB
Dinan Resonator Delete Kit
To order anti roll bar set for Rwd please visit our website by clicking HERE
The Dinan Resonator Delete Kit for the for the F22 M235i allows for an aggressive tone to be achieved out of the stock system. Coupled with the associated Dinan exhaust the sound is further perfected into an agressive growl that is hard to ignore. This piece removes the factory resonated section and replaces it with straight through 3.25” T304 stainless steel tubing for better flow, and sound.
Supplemental Big Turbo Hardware Kit
To order please visit our website by clicking HERE
The N55 xDrive turbo hardware kit consists of the required additional components when upgrading to the Dinan big turbocharger on an xDrive vehicle. These components are replaced when installing a turbocharger per BMW recommended procedure.
Dinan Adjustable Anti-roll Bar Set
To order anti roll bar set for xdrive please visit our website by clicking HERE
Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner.
+ Less Body Roll
+ More Mechanical Grip
+ More Stable At Limit
+ Large 28mm size
+ Large 19mm size
Lower Control Arm Monoball Kit
The quietest bearings on the market are virtually noise-free so you can live with them every day. These are the only bearings on the market that are sealed using a rubber boot to keep out dirt and road grime stopping them from wearing out prematurely. The Dinan Monoball Kit provides responsiveness you can feel by replacing the rubber bushings in the thrust arms with precision ball joints and machined aluminum housings. Improves responsiveness by eliminating the deflection inherent in the stock rubber bushings while also reducing brake shimmy.
Features
+ Improved Steering Responsiveness
+ Reduces Brake Shimmy
+ Nylon-lined Bearings for Quiet Operation
+ Machined Aluminum Housings
+ Sealed Bearings
Dinan Camber Plates
The positive adjustment range on the camber plates is unique to Dinan and allows the end user, if desired, to retain OEM camber settings on a lowered car or to combat excessive negative camber brought upon by springs that aggressively lower the car. Not only do the Dinan camber plates provide a wide range of adjustment but they also have ride quality in mind like all of Dinan's suspension components and are designed to properly retain the bumpstop so that it compresses as designed from the factory. Dinan camber plates are also built to take a beating and are the only ones that utilize a steel alloy mount plate that will resist deforming from pot holes on the street or curb hopping at the track.
Features
+ 43mm of total camber adjustment (30 negative, 13 positive from OEM). This translates to 2.5 degrees of negative camber and just over a degree of positive camber being possible.
+ Decreased understeer
+ Decreases outside edge tire wear
+ Steel alloy mount plate and not aluminum
+ Fits with factory strut tower weather seal
Dinan Performance Spring Set
To order for Rwd please visit our website by clicking HERE
To order for xdrive please visit our website by clicking HERE
Dinan's Performance Spring set for the F22 M235i/M240i provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan lowers the M235i/M240i by a 1/2" in the front and 5/8" in the rear for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car. The Dinan performance springs provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at low speeds up to the top speed of the vehicle.
Features
+ 10% increase in spring stiffness in front and 15% increase in the rear
+ Lowers the vehicle 1/2" in the front and a 5/8" in the rear
Dinantronics Performance Tuner
To order stage 1 please visit our website by clicking HERE
To order stage 2 please visit our website by clicking HERE
To order stage 3 please visit our website by clicking HERE
To order stage 4 please visit our website by clicking HERE
To order Sports tuner please visit our website by clicking HERE
DINANTRONICS™ Performance Tuner is a highly engineered and sophisticated piece of computer hardware and software that enhances engine performance, without ineffectively or invlidate your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It is also the only tuning device emissions legal in all 50 states. The objective of developing this piece of technology was to provide the ability to control every signal entering and exiting the BMW factory Engine Control Unit. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package.
Dinan High Performance Dual Core Intercooler
The system has been engineered to be as direct a replacement as possible to the stock unit, requiring only minor modifications for a clean, factory-like installation. The increased thermal efficiency provided by the Dinan dual core intercooler will also enhance turbocharger reliability in addition to overall power. On a stock vehicle power gains can be had from 4000 RPM and beyond (when the car is in boost). In order to achieve the best performance the intercooler should be paired with the Stage 3
DINANTRONICS Performance Tuner as it provides optimization of the intercooler. In particular it extends the power band to be more robust and powerful from 4000 RPM to redline whereas without tuning the bulk of the gains are from 6000 RPM to redline.
Features
Max gains of 15 HP and 13 lb-ft of torque @ 6250 RPM (greater gains and a wider power band can be achieved when paired with stage 3 DINANTRONICS)
Face area 240% larger than the stock intercooler setup for maximum cooling efficiency to deter heat soak.
Charge Air Pressure drop: 0.80 PSI (25% improvement over stock)
Charge Air Temperature drop: 155º F (11% improvement over stock)
Charge Air Temperature / Ambient Temperature Delta: 18º F @ 6250 RPM (60% improvement over stock)
Dinan Carbon Fiber Cold Air Intake
Efficiency and maximizing the potential of the stock intake design were the keys to development for this N55 intake. The sealed system delivers as much cold outside air as possible to the engine via an optimized carbon fiber tube that mimics the stock pipe but with less resistance with a straighter freer flowing design. The increased amount of air feeds into a larger volume airbox complete with a larger filter that elicits a sporty tone that makes the intake sound as good as it performs. This optimized design yields an incredible 10HP and 15 lb-ft of torque even without any additional modifications. Simply perform the short bolt-on installation in under an hour and enjoy a more powerful and audibly satisfying driving experience.
Features
More Power: +10 HP & +15 lb-ft of torque without additional modifications
Even more power can be achieved when combined with the DINANTRONICS Performance Tuner and exhaust. Consult the applicable DINANTRONICS product page for details.
Sportier Sound
Larger volume air box that completely seals
Optimized carbon fiber intake tube
Larger cylindrical air filter
Larger MAF
Quick and easy installation
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail:
online@autotalent.com
Website:
www.AutoTalent.com
Payment:
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
      11-08-2020, 09:31 AM   #2
AutoTalent
AutoTalent's Avatar
2312
Bump!
Visit our website by clicking HERE. You can also PM or email us with any questions!
      12-28-2020, 06:50 PM   #3
AutoTalent
AutoTalent's Avatar
2312
Visit our website by clicking HERE. Please feel free to reach out with any questions or inquiries!
      01-18-2021, 07:21 PM   #4
AutoTalent
AutoTalent's Avatar
2312
      02-03-2021, 07:04 PM   #5
AutoTalent
AutoTalent's Avatar
2312
      02-22-2021, 07:26 PM   #6
AutoTalent
AutoTalent's Avatar
2312
      03-02-2021, 08:38 PM   #7
AutoTalent
AutoTalent's Avatar
2312
      03-10-2021, 07:22 PM   #8
AutoTalent
AutoTalent's Avatar
2312
      03-22-2021, 07:56 PM   #9
AutoTalent
AutoTalent's Avatar
2312
      03-29-2021, 10:54 PM   #10
AutoTalent
AutoTalent's Avatar
2312
      04-05-2021, 09:59 PM   #11
AutoTalent
AutoTalent's Avatar
2312
      04-16-2021, 01:24 AM   #12
AutoTalent
AutoTalent's Avatar
2312
      05-31-2021, 07:44 PM   #13
AutoTalent
AutoTalent's Avatar
2312
      08-10-2021, 08:02 PM   #14
AutoTalent
AutoTalent's Avatar
2312
      08-25-2021, 01:58 AM   #15
AutoTalent
AutoTalent's Avatar
2312
      09-17-2021, 03:35 PM   #16
AutoTalent
AutoTalent's Avatar
2312
      11-04-2021, 05:42 PM   #17
AutoTalent
AutoTalent's Avatar
2312
