2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning ZF8 Reliability High Torque (650 Ft lbs)
      08-22-2020, 05:20 PM   #1
Bfrancom2
Drives: M240i
Hi all!
I am looking for input about the reliability of the 8AT (ZF8HP50) found in B58 equipped cars.
I'm currently making about 550ftlbs at the crank. I'm not really worried about that. While it's over the 369 rating, I have faith as they're wildly underrated from the factory.
My question is, I am looking to upgrade my HPFP and in turn, I'd be doing about 650 ftlbs at the crank. Is this feasible on the 8AT?
**BEFORE ANYBODY COMMENTS** I don't want to hear "It's rated at 369....you're exceeding the specifications." No shit. I am looking for B58 owners on AUTO transmissions that have been making over 500wtq (600+ at the crank) and their experiences, mileages, etc.
Thank you!
      08-25-2020, 05:24 PM   #2
AleksanderSuave
Drives: 2017 M240iX Coupe
the 3 series b58 forums will likely be of more use for you.
I notice the engine tuning posts in this forum are primarily a small handful of us, and its been dead for a little while.
      08-25-2020, 11:55 PM   #3
Bfrancom2
Drives: M240i
Yep posted there as well, as the 2 series definitely isn't as popular.
      09-02-2020, 08:25 PM   #4
JD11937
Drives: 2017 M240xi
There are plenty of people running a lot of power on these transmissions. I have heard some complaining about slip, specifically in 6th but have only heard of one catastrophic failure. I have an upgraded turbo and daily drive my car but I don't abuse it and have had zero problems. You will definitely want to do trans fluid service, I'm doing mine at 45,000 miles. Some will suggest sooner, some later.
      09-22-2020, 08:20 AM   #5
hardparker
Father of Frankenfold
300
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
The 8HP50 is hella stout and has the same sized clutches, though fewer, as the larger 8HP70 and 8HP90. There's enough interchange between them that an 8HP50 can be built to handle more torque than the 8HP90 itself in stock guise with equal or greater clutch count and upgraded friction material.
Look at what the big power 8HP90 cars, like heavily modded Hellcats and the like are doing for transmission upgrades. You could basically have an 8HP50 rebuilt and upgraded to something like Southern Hotrod's 8HP90 War Viking. Then you'd have a hard time putting a motor in front of it that could break it.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
Tags
b58, zf8
