06-29-2021, 10:27 PM | #1 |
6 speeeeeeeeeed
147
Rep 214
Engine Coolant Flush
Hey guys,
BMW quoted me like $400 CAD for a coolant flush. This sounded absurdly high so I called around some places and got some reasonable quotes $150-220. I know BMW uses a machine to cycle and clean the coolant, but this one spot I called up didn't have the machine, but they would use a vacuum or something to clean it + a cleaning solution before adding the new OEM coolant. Does this sound like its fine or should I opt to find a place that has the coolant flush cycle machine like BMW? Cheerio
17' 240i 6MT - black on red
06-30-2021, 08:57 AM | #2 |
Rep 351
if you're looking at a coolant flush it's probably time to do your water pump and thermostat. all 3 jobs are easier to accomplish with a drain and fill.
Zyzzthetic146.50 |
06-30-2021, 08:59 AM | #3 | |
6 speeeeeeeeeed
147
Rep 214
Edit: Do you mean a water pump flush and thermostat flush?
06-30-2021, 07:10 PM | #4 | ||
Rep 351
typically water pumps and thermostats die at 80,000 miles. replacing them requires a full coolant system drain which makes it a good time to replace all those parts and the fluid. edit: odd that they recommend the flush. they say why? typically maintenance isn't required that early unless the computer calls for it or they have some basis. |
06-30-2021, 08:42 PM | #5 | |||
6 speeeeeeeeeed
147
Rep 214
I'm at the cabin, but I'll upload a screenshot when I return. Maybe they're trying to scam >.>
06-30-2021, 10:00 PM | #6 |
Rep 301
Drives: BMW M235i
It's pretty standard to do a coolant drain and refill about every 2-3 years, no matter what the make of car. If you do it yourself it's really cheap. I definitely wouldn't pay a BMW service shop $400 for a coolant flush. If you can't do it at home look for a self serve garage bay in your area that you could rent for maybe an hour.
Zyzzthetic146.50 |
06-30-2021, 10:24 PM | #7 |
Rep 3,504
^ This.
Zyzzthetic146.50 |
07-01-2021, 07:11 AM | #8 |
Rep 351
Zyzzthetic146.50 |
07-01-2021, 07:51 AM | #9 |
Rep 527
Is it easy to get all the air out or can some get trapped in the system if evacuation and fill is not used?
Zyzzthetic146.50 |
07-01-2021, 08:13 AM | #10 |
Rep 351
I was worried about that too. I ended up filling the system through the expansion tank, massaging the hoses, utilizing the bleed screws, and the water pump bleed procedure, it was fine. no need to use the vacuum fill system.
Zyzzthetic146.50 |
07-01-2021, 08:34 AM | #11 | |
Rep 516
Also read that the same warning was not around for the previous model N54 and N55. |
Zyzzthetic146.50 |
07-01-2021, 09:40 AM | #12 |
3697
Rep 3,618
The ISTA does call out for the specific fill procedure with the B58 that doesn't apply to most other engines, the full text is:
"Filling without the vacuum filler device (watering can filling) is not permitted. Non-compliance will result in danger of component damage and/or engine damage. Filling specification absolutely must be adhered to. The operation of the vehicle is not permitted unless the filling procedure has been completed. Otherwise, functional limitations (degradation) and/or overheating may occur. A bleeding procedure is required after a part has been exchanged in the cooling system and/or after refilling the cooling system." |
Zyzzthetic146.50 |
07-01-2021, 09:52 AM | #13 |
Rep 537
I can see that as the B58 does have two water pumps, one electrical (for turbo) one mechanical and NO thermostat. It has a heat management module instead.
Zyzzthetic146.50 |
07-01-2021, 12:41 PM | #14 |
Rep 351
I recall a similar warning for my n20. maybe find a b58 diy somewhere. see if someone else has had success without the vac fill
Zyzzthetic146.50 |
