11-13-2014, 07:13 AM | #45 | |
Rep 115,999
Mike |
11-17-2014, 10:08 AM | #46 |
Rep 27
Drives: 2015 M235i
I have been using the Scorcher for 2 years and have had no problems (no codes, idle problems) . Going to the M235i next October 2015 it looks like I will have to get the B model and sell the A model .
11-17-2014, 10:17 AM | #47 |
Rep 853
I see your in CA, do you use 91 octane with the Scorcher?
CURRENT: 2019 Tesla Model 3 Performance
RECENT PAST: 2016 F80 Austin Yellow (6MT) / 2017 F80 Atlantis Metallic (DCT-ZCP) / 2017 Challenger Hellcat 8A / 2017 Focus RS/ 2017 Shelby GT350 / 2018 Audi TTRS / 2018 Raptor Crew Cab / 2020 X3M Comp |
11-17-2014, 01:54 PM | #48 |
Rep 27
Drives: 2015 M235i
11-18-2014, 12:16 PM | #49 |
Rep 42
Thanks for the info Delnari. I am considering the AFE as well. I know there are 2 different connectors that are available. Where exactly is the connector located so I order the correct one?
2014 M235i, mineral grey, black Dakota leather, Msport exhaust, Msport carbon fiber spoiler.
11-19-2014, 11:51 AM | #50 |
Rep 1,040
You only need to piggyback two sensors, the TMAP and Map sensors. The instructions are on aFe site, Scorcher Installation.
11-21-2014, 09:37 AM | #51 | |
Rep 197
Doses anyone know what the Dinan stage 1 runs at ? |
11-24-2014, 04:10 PM | #52 |
Rep 17
So is it correct that installing the aFe module would cause my P3 gauge to give false boost readings as it basically tricks the ecu? Are there any other complications that could arise with using the P3 and aFe module? I remember reading somewhere on here about the JB4 and P3 not getting along, I just wasn't sure if the same problems could occur with the aFe...
11-25-2014, 01:00 PM | #53 |
Rep 809
@Delnari , man I enjoyed so much your review, not only the technical specs but also the funny additional comments LOL. Thanks for sharing it, I haven't had the chance to read this until today. Cheers.
12-11-2014, 09:26 AM | #54 |
Rep 24
Out of all of ur tunes it seems like u favor this one the most.
I'll def most likely consider this set up over all first. I'm in the Alexandria area as well. I'll be looking out for u once I get my M235i and bike lol. (Unless I can wait for the M2 ) |
12-11-2014, 02:24 PM | #55 |
Rep 1,040
It has been certainly the "best bang for the buck" while not causing any issues that a higher boosted system might. Custom tunes and full JB4 will be largest increase. Keeping the motor and electronics safe while having more fun was my goal. Plus, I can resell it when my new car come 2016 shows up...
01-21-2015, 12:28 PM | #56 |
IG @bmwF9xG80
3813
Rep 7,593
+1 on aFe scorcher
+1 on Delnari
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
01-24-2015, 03:32 PM | #57 |
Rep 835
After reading your review Delnari, I too decided to pick up the scorcher. The JB while tried and true is just so ridiculous with all the extra wires. The setup is so clean and easy to swap out for maintenance no problem. I also have the AFE intake and the combination is outstanding. It transforms the car completely. I would reccommend this to anyone in the market for this sort of thing.
2020 X3M Comp., Alpine White on Black/Beige
RETIRED: 2018 440xi GC, Carbon Black on Black/Blue 2014 M235i Black on Black, DINAN Stage 2 |
01-25-2015, 07:17 AM | #59 | |
Rep 115,999
04-03-2015, 01:11 PM | #61 |
Rep 41
Might be a dumb question, but I just wanted to run it by you guys before I bit the bullet.
I know that running a CAI without a tune can cause the engine to run lean, which can lead to issues with turbo engines like ours (M235i xdrive), but these simple tunes that just trick the ecu into seeing a lower boost than is actually there, will they actually solve that problem? I'm just worried about long term effects, as no one here has any failure lights yet. I plan on getting the Momentum cai, with either the scorcher or racechip tune. |
04-03-2015, 09:45 PM | #62 |
Rep 1,040
I run the aFe Momentum intake with all the tunes I have installed for nearly one year now. No check engine lights or problems by having it. Currently running the RC Ultimate with "D" setting on 93 octane gas and all is good.
06-12-2015, 01:19 PM | #64 |
Rep 191,215
Thanks for the review OP
We have lots of happy Cali owners using the scorcher
06-12-2015, 02:29 PM | #65 | |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
You run the P3 boost function in analog (requires another wire from the p3 to a tap on engine bay sensor) mode that will give you true boost readings.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
06-12-2015, 04:05 PM | #66 |
Rep 853
How about issues with altitude?! Do any of these piggybacks combined with 91+~4500ft(in my case) cause problems?! Which "stage 1" piggyback would you recommend for that situation?
I know the JB4 has autotuning, more features, etc. just don't want to deal with the install. Thanks!
