2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Upgrading the basic audio in a 228
      12-13-2017, 01:43 PM   #23
happyjack
happyjack's Avatar
Drives: '21 F87 M2C 6MT
Originally Posted by Maynard View Post
Strangelove thread has been my go-to for planning this, but I've not shopped specific prices - IIRC, the Bavsound isn't the cheapest, and may lack some parts despite the 'plugNplay' moniker. I know the pics they show online are all dual speaker sets, but HIFi's don't have the sail panel tweeters, so be sure they are the proper coaxials. Mounting sail tweeters is possible, but probably needs several specific interior bits.
If you go this route, post back w/ results - I'm especially curious about how the speakers sound w/ the base amp (all the reviews I've found are people w/ the HK amp).
the bavsound upgrade kit for a 2015 228i w/ base system actually shows a pick with 5 speakers and it describes them as "BAVSOUND 4" (100mm) 3-Leg Point Source Neodymium Coaxial, Flush Flange, Pair + INTEGRATED 13mm Point Source Silk Dome Tweeter" -- so, you're correct, it doesnt include the sail tweeters. that was part of my questioning the value of this upgrade...or if i should look at an upgrade that would provide component tweeters.
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door
retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line
Maynard3848.00
      12-13-2017, 02:49 PM   #24
Maynard
Drives: 228iX & M2C
Duh, should have read it rather than just looked at the pictures. From what I know, coaxials are equivalent to separates if they use good components, at least in this setting (in a soundbooth you would be able to do better, but in a moving car it should not be something you can notice). Probably a bit of a difference b/c they aren't aimed as directly, but to me it is not worth the hassle of tearing up the sail panel and hunting down the HK-specific pieces (not a HUGE hassle, but I still haven't gotten time to pull the center channel, so I try to be realistic about how little I'm able to make time for).
      12-13-2017, 03:09 PM   #25
BEM-S4
BEM-S4's Avatar
You cannot buy the sails alone, they come with the HK tweeter installed which you pull out and throw away. You'd also need to install the tweeters in the rear which requires a slightly different cover grille if memory serves, since you can get Bavsound for HK which has mid and tweeter in each location. But they don't sell a kit, at least to my knowledge which may be dated, that has tweeters in front and coax in rear.
In all honesty I have the coax in the rear in my wagon and they sound really nice, I wouldn't go through the brain damage or added expense of messing around with adding separate tweeters throughout. And let's be perfectly frank here, the stock HiFi system is so crap anything will be an upgrade.
Maynard3848.00
happyjack1657.00
      12-14-2017, 08:32 AM   #26
happyjack
happyjack's Avatar
thanks for the feedback. any other solid choices for the base/hi-fi upgrade that might be a better value? i've seen the posts on JL audio and eton as possible alternatives...
..kind of ready to make a decision with this bavsound opportunity sitting there.
      12-14-2017, 08:36 AM   #27
BEM-S4
BEM-S4's Avatar
I will throw in my 2 cents as you decide. I am a big fan of Bavsound, well documented on the forums. The extra $ you spend vs other alternatives gets you U.S. company with good customer support if you need help, versus buying grey label stuff that's not really sold here. It's all pretty idiot proof, and you have a 4 year warranty. On the back end the gear tends to hold its value very well based on classifieds here - so if you resell when done you're probably not spending a whole lot more versus other alternatives.
It's not going to get you true top end performance, but for that you wouldn't be looking at value-focused DIY. You'd be throwing huge dollars at professional install stuff.
Viffermike1753.00
happyjack1657.00
      12-14-2017, 11:37 AM   #28
happyjack
happyjack's Avatar
thanks BEM...i'm just about convinced this bavsound kit is the right option at the right price for me. hopefully can report back the improvements soon!
      12-18-2017, 01:39 PM   #29
happyjack
happyjack's Avatar
merry christmas to me....will report back improvements soon.
gonna evaluate the improvements with the stage 1 speaker kit, and then think about the subwoofers later on. i do enjoy a nice thumpin' bass.
Last edited by happyjack; 12-18-2017 at 02:14 PM.. Reason: clarified 'stage 1' kit
      12-18-2017, 01:43 PM   #30
BEM-S4
BEM-S4's Avatar
gonna evaluate the improvements with the speaker kit, and then think about the subwoofers later on. i do enjoy a nice thumpin' bass.
One thing with the ghost subs - you end up lowering the bass setting and hence shoving less low range through the mids / tweeters or coax. So your speakers end up doing less heavy lifting and sound even better.
      12-26-2017, 10:34 AM   #31
happyjack
happyjack's Avatar
stage one kit is in hand. just need to find some time to knock out the install.
      01-05-2018, 01:25 PM   #32
ap887
Drives: 230i
Are you using the stock amp? Curious how this works out for you.
      01-05-2018, 01:32 PM   #33
happyjack
happyjack's Avatar
for now, yes. stock amp and no sub. my guess is that i'll add a sub next.
need for these arctic temps to pass so i can get the install done. i was just too busy to carve out enough time to do this over the holidays.
i'll definitely report back results.
      01-05-2018, 01:34 PM   #34
BEM-S4
BEM-S4's Avatar
Aside from being uncomfortable everything is held together with plastic clips - which get brittle and break easily in the cold.
      01-05-2018, 01:39 PM   #35
happyjack
happyjack's Avatar
excellent point!
i can just feel the box eye-ballin' me everytime i walk past my workbench.
1FUNCAR20.50
      01-06-2018, 03:11 PM   #36
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I'm patiently awaiting the install.
78' Honda CB400A project
Miata1387.00
      04-14-2018, 10:27 AM   #37
1FUNCAR
1FUNCAR's Avatar
Drives: 2018 M240i Coupe
As we patiently await your feedback.
      04-19-2019, 01:19 PM   #38
BEA5T
Drives: E39 M5
Hey guys, so this is a bit of a delayed (2+ year lol) post.
But what I ended up doing was ordered the tweeters from the Harmon Kardon version. In my opinion if you will do anything, you must do this first.
Then I was able to find a cheaper set of BAV speakers stage 1 components on ebay from a 3 series (it was like 50% off) and they fit here perfectly fine.
You can splice into the wires, or you can make it pretty with a splitter.
https://www.ebay.com/itm/1-BMW-E60-E...frcectupt=true
The original Harmon Kardon tweeters as well as the BAV tweeters come with a capacitor so you don't need to worry about blowing them. It is plug and play.
https://www.ecstuning.com/b-genuine-...t/51337269361/
https://www.ecstuning.com/b-genuine-...t/51337269362/
It is ridicolous how the base model doesn't have tweeters. I recently rented a Dodge Uhaul van. All it had was a radio - but it had fucking tweeters. Disgraceful, bmw.
Easy fix though.
      04-20-2019, 10:15 PM   #39
paposalsa
Drives: 2015 BMW 228i
Easy fix though.
It is pretty sad when my daughter's Nissan Sentra has a better sound system. Even the OEM system in my 2004 Toyota Tacoma sounds better.
      05-10-2019, 06:46 PM   #40
Bluesmobile
Drives: 2015 228i Convertible x-drive
How easy are these tweeters to install? How difficult was it to remove the existing triangles off, get the door panels off and then attach the speaker wires? Can’t see from the pictures on the ECS site, but I’d imagine there are wires that you run toward the existing speakers in the door panels? Sorry for all the questions - I’m a total newbie when it comes to this. All I want to do is install the tweeters!
