09-13-2016, 01:29 PM | #1 |
Rep 52
Is this Normal for Tire Wear?
Bought a M235i new 2016 on April 30th 2016. Car has about 7700 miles on it.
The tire pressure indicator popped up this morning and I brought it in to service. I was told that the tire had uneven and extreme wear due to misalignment issues. Michelin PSS Tires The car has been babied, never hit a pot hole (not even scratches on the rims). I have the tire and wheel warranty and was told that I would only have to pay the deductible, but I have to also pay for re-alignment. Will this be covered under warranty? I don't really want to pay $350.00 on front tire realignment on essentially a new car. Thanks, K Last edited by Wreckt; 09-16-2016 at 10:18 AM.. |
09-13-2016, 02:31 PM | #2 |
Rep 2,010
I presume that you returned the car to your BMW servicing dealer. If that's the case, I would think that the worn tire and alignment would be covered under the warranty. Except for hitting something quite hard, I simply do not see a less than 5-month old car with less than 7000 miles on it being out of alignment unless it was delivered to you in that condition.
Question: have you examined the worn tire personally and if so, describe what you see. How does the tire look when compared to the other tires? How was the car driving/handling? Somehow, the out-of-alignment deal from whomever is servicing your car does not pass the smell test.
09-13-2016, 02:44 PM | #3 |
Rep 52
I was not there. My dad took it in for me since he has time being retired and all.
Handling has been fine. No vibration or anything at any speeds. Like I said, I have babied the car and never hit anything. The Rims are in perfect condition, there isn't even any curb rash. It was at a BMW Dealership service center where they told me about the "misalignment". I am taking it to the dealership I bought it from tomorrow in the AM to have it checked out in person. I have also called BMW NA and filed a report. |
09-13-2016, 03:51 PM | #5 |
Rep 5,579
Mercedes had/has a one year from purchase alignment offer/warranty - read your BMW documentation to find out.
Also, when parking and hitting a curb that can knock you out of alignment in some instances. |
09-13-2016, 03:54 PM | #6 |
Rep 5,385
How exactly is the tire worn to the point that they've determined excessive and uneven wear?
Was the tire pressure warning the first indication of a problem or were the tires getting excessively loud? Why didn't you just put air in the tire rather than taking it into BMW? Was there something else indicating a problem? My guess is the tire got pretty low on the air and during driving (perhaps with some hard corners thrown in), the outside shoulders got toasted and "excessively" and unevenly worn. High wear on the outside shoulder blocks of the front tires is common in these cars, especially if you corner fairly hard or track the car. If this was the case, I recommend 1) running higher than recommended front tire PSI (I run 37-38psi vs the recommended 33psi) and 2) check the onboard tire monitoring system at least once a week. It will tell you if you're underinflated or possibly have a slow leak. I don't think the tire pressure warning system comes on until 20psi or something like that. |
09-13-2016, 03:56 PM | #7 |
Rep 2,214
I've put over 15k kms on my PSS's and I drive hard almost every day here in the mountains. I've worn through about 1/2 of the usable tread so far, which is pretty good considering how hot it was here this year.
I try to get 30-40k kms (2 seasons approx) out of a street performance tire. Alignment on mine is still stock and unchanged. Currently sitting at 29k kms. I also run mine at 38PSI, always have with PSS's..
09-13-2016, 04:01 PM | #8 | |
Rep 5,579
Just had dealer mount four new PSS A/S and the tech did front at 37psi, guess he did that on purpose. |
09-13-2016, 04:06 PM | #9 | |
Rep 2,214
D
09-13-2016, 04:09 PM | #10 | |
Rep 5,385
I had 235/40R18 MPSS on my 2012 WRX and running 37-38psi all around was the sweet spot. Running 34psi or less made the sidewalls roll over too much and 37-38psi kept the tires cool enough when running the car hard. I'm seeing the same with the M235. I do wonder if the recommended front PSI is to create a bit more understeer, which I think it does. It also makes for a softer ride compliance in the front (blah!). |
09-13-2016, 04:40 PM | #11 |
Rep 52
Tire pressure warning was first sign of problems.
I commute 30 miles to work and wanted to make sure the tires were ok, which is why I took it to dealer. There has never been excessively loud noises coming from the tires. Also this car has never been tracked and only driving moderately in the city. |
09-13-2016, 05:07 PM | #12 |
Rep 2,214
I'd definitely take the issue up with the Dealership you purchased from. If that doesn't get you anywhere I believe Michelin will do a pro rated warranty for you. I'd try to approach it as "premature wear". Have the Dealership check alignment etc, as that could be posing a larger issue than just tires/pressures.
09-15-2016, 07:21 AM | #14 |
Rep 765
I also had mine aligned by a tuning shop - made a world of difference on wear and cornering. I didn't assume BMW was wrong, but I just wanted it a little more enthusiastic in its alignment for back roads/tracks
09-15-2016, 05:04 PM | #16 |
Rep 2,214
If you're actually driving the car hard, you'll have more contact area (less outer tire wear) in-turn with added camber and vice-versa. If you have added camber and do not corner hard, go to the track often, or live in a somewhat flat environment with no "twisties" it's a waste.
09-16-2016, 10:17 AM | #17 |
Rep 52
Yeah dealership still charged for realignment, which sucks.
BMW NA also wouldn't do anything saying that alignment is covered only in first 2000 miles, which I think is bullshit considering how do I even know how the car is aligned or how it bad it is in the first 2000 miles. I have a feeling that the alignment was never checked when I took delivery of the vehicle. On top of this I essentially have to replace the tires in the next 2 months for another $1000+ (Only 5/32 and 4/32 left on all tires after 8000 miles and 4.5 months of driving). I admit, I miss-remembered the mileage on my car, I thought it was around 6700 but it was around 7500 when I brought it in. I have never tracked the car. This is probably the last BMW car I will purchase for myself or my family, we will probably going to migrate to Porsche for our next SUV and my next fun car. While I really like the community aka you guys on the forums. I feel the service that BMW NA and the BMW Dealership provided is unacceptable. BTW it is Advantage BMW of Houston and Momentum BMW of Houston if anyone was wondering. Last edited by Wreckt; 09-16-2016 at 10:24 AM.. |
09-16-2016, 11:36 AM | #18 | |
Rep 5,385
Also, I'd check the tire depth yourself just to make sure they're not yanking your chain. You can buy a tire depth gauge for a couple of dollars or even do the penny method. The tires have wear bares which indicate the point at which you should replace. Just a couple FYIs here: 1) The M235 has minimal camber up front, thus the car can be hard on the outer shoulder blocks of the front tire. You should consider pumping the front tires up to around 37-38psi. You'll get better feel and reduced front tire wear. 2) Your car came with Michelin Pilot Supersport (MPSS) tires. These are summer tires have a low tread wear rating. These are probably the best handling and performing summer tires that you can buy for performance and wear. However, the tires can wear quickly compared to a more standard tire because you can't get exceptional performance from tires (or brakes) without elevated wear. Plus, like I said, the M235 is hard on front tires. You should not expect the front MPSS tires to last longer that 15,000-20,000 miles depending on your driving style. 3) The tire pressure warning light does not come on until the tires are grossly underinflated. Underinflated tires can wear very quickly, especially on the shoulder blocks because the shoulder tends to roll over a lot more. Summer tires will wear MUCH quicker if they're underinflated. You should use the onboard computer to check tire pressure on a very routine basis. 4) If you don't drive the car hard, then there's not much sense of running summer tires and should consider getting a higher wearing performance tire that will get the wear where you're more accustomed. 5) Most Porsches wear out tires at a more rapid pace then the M235, but the wear is flipped around. Most mid/rear engine Porsches will go through a set of rear tires about every 10,000-15,000 miles. Wide tires and a very aggressive performance factory alignment largely account for this. Porsche SUVs completely destroy both front and rear tires at a rapid pace. Be prepared. |
09-16-2016, 07:11 PM | #19 |
Rep 2,214
Great points ^^
OP, I'd strongly suggest switching out to the Pilot Sport A/S 3's as they are exceptional tires ,if you're not already considering them. They wear better, have better wet grip, and are quieter than the PSS's. They perform at about 80% of what the PSS's are capable of, but still lots of grip and feedback. Also cheaper... Just a thought since it doesn't sound like you "need" PSS's D
09-16-2016, 10:14 PM | #21 |
Rep 5,262
09-16-2016, 10:30 PM | #22 | |
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
