2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Automatic high beams
      07-18-2014, 04:02 AM   #45
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
Originally Posted by Oyinko View Post
I coded the vld but I didn't see any difference on freeway. Did I miss something?
Light switch needs to be set at"auto" ?
Current car.M240i.
Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
      07-19-2014, 03:16 AM   #46
Vlad-Miami
Drives: BMW M235i MW/CR
My car is coming next week, fully loaded model. Definitely will try to recode and will let you know the results. Can anyone give me some hints on how coding is done on vehicles? Do i need to buy ODB device? Or how is it done?
      07-19-2014, 10:41 AM   #47
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
http://www.2addicts.com/forums/showthread.php?t=1010377
      10-19-2014, 09:34 AM   #48
Bahuba
Bahuba's Avatar
20
Drives: MR 2014 M235i
Originally Posted by pikcachu View Post
Looks like it is pretty simple to re-code anti-dazzle and variable light distribution
just remove 5AP and 8SA from your VO and code FLA and FEM_BODY module
http://www.bimmerfest.com/forums/sho...4&postcount=53
(note: you will lose any previous coding of the FEM_BODY module and FLA, so you will have to re-code it again)
damn it, i should have order the damn "high beam assist" $250 option
Pikachu, can you clarify what what you mean by "code FLA and FEM_BODY module." For FEM_BODY, do you mean make the changes in lines 36-37 in your coding spreadsheet. I don't see FLA mentioned, or is this lines 38-41?
      10-19-2014, 12:56 PM   #49
pikcachu
pikcachu's Avatar
1399
for Variable light dist, you can either... modify to FA and VO code ("code" button) FEM_BODY or do the changes shown in 36-37 in the sheet and "code FDL" button
i dont have HBA so not sure if there is any individual change in the FLA ecu so it's just easier to just make the change to the FA and then just hit "Code"
      10-27-2014, 06:55 PM   #50
nyeager
Drives: 2015 M235i xDrive
@pikcachu I did FDL coding for VLD as opposed to FA / VO coding; what I'm trying to figure out is why the driver's-side light looks like it moves a lot more than the passenger-side light. I'm actually not even sure if the passenger-side light is moving at all.
From the videos you posted, it looks like you're seeing the same thing but it's interesting as the description for VLD states:
"1 - City Light: Shallow and Very Wide Beam Pattern active from 0 - 50kph (30MPH) (Both Headlamps are Panned outwards 12° horizontal from center and 0.7° lowered vertically)"
Thoughts?
      10-27-2014, 07:37 PM   #51
pikcachu
pikcachu's Avatar
1399
it's like that... cause the passenger is already pointing wide
      10-27-2014, 07:39 PM   #52
nyeager
k, figured it was just something like that. Thanks!
      11-05-2014, 08:09 AM   #53
Bahuba
Bahuba's Avatar
20
So, I took the plunge and coded this in (removed 5AP, 8S4 from FA and coded FEM_BODY). I have the HBA feature, and I have to say this is one of the funky-er features. My drive back home consisted mostly of 2-lane backroads with a fair bit of oncoming traffic. So after activating the HBA, at first nothing unusual, but then at a certain point the blue high beam indicator came on the dash, then I could clearly see the tunnel effect and the left head light swivel when on-coming traffic appeared. Most notable when not following a car. Also noticed, the high beam indicator never went off even with oncoming traffic, until I slowed down to a stop. Before I coded this, the high beam indicator would automatically switch off with oncoming traffic.
      11-06-2014, 06:08 AM   #54
220i_viking
Norway
Drives: 220i, Glaciersilver, m-sport
I have this on my car, doesn't seem to work that well. Tried them when it was dark and it wouldn't turn on the high beams. Might be that I'm a bite of idiot, but didn't seem to work.
Previous cars: '04 Z4, Smart ForTwo Brabus, '10 118d, '08 MINI Cooper S (lightly modded)
      11-06-2014, 07:44 AM   #55
Bahuba
Bahuba's Avatar
20
For me, this feature deactivates in well lit areas. I.e. the blue high beam symbol in the dash turns off. Possibly because the camera is picking up too much ambient light, or slower speed? But I can clearly see it working on unlit two lane roads with on coming traffic.
      11-24-2014, 11:44 PM   #56
220i_viking
Norway
Had a long road trip a couple of weeks ago and when it was completely dark it worked brilliantly After that they worked in more light areas as well. Maybe they just needed a jump start
      11-25-2014, 08:53 AM   #57
Bahuba
Bahuba's Avatar
20
It has to do with the speed. At lower speeds (below 50km/h?) it switches to low beam. Definitely the biggest surprise feature.
