Any long term issues with N55? |
View Poll Results: Did you have any issues w/ your N55? Could be on drivetrain or something else | |||
No issues so far, car has under 30k miles | 18 | 36.00% | |
No issues, car has >30k miles | 22 | 44.00% | |
Had some minor issues (less than $1000 to fix) | 4 | 8.00% | |
Had some expensive issues (more than $1000 to fix), didn't tune the car | 3 | 6.00% | |
Had some expensive issues (more than $1000 to fix), DID tune the car | 3 | 6.00% | |
Voters: 50. You may not vote on this poll |
11-21-2018, 08:09 PM | #1 |
Rep 395
My factory warranty will expire and I'm not sure if it is worth paying $2500-$3800 for +36 months of warranty. I plan to keep the car, don't plan to tune or track it.
Did anyone have long-term issues w/ your car? If so...
11-21-2018, 08:55 PM | #2 |
Rep 255
40K miles, rear differential replaced under warranty.
I believe this was an aberration...the diff leaked and was noisy. No root cause determined. Parts were ~$2500 retail if you were to pay.
Current Fleet, 16 F22 M235i xDrive, 15 Audi Q5 3.0 TDI (my Wife's), 07 E85 Z4M Roadster, 01 Toyota Tundra 2wd Long Bed
Retired (a few of them...), 08 E60 550i 6M, 01 Audi S4, 70 Fiat 124, 88 E28 M5, 72 Datsun 510 2Dr, 73 TR6 |
11-22-2018, 10:05 AM | #4 |
Rep 1,117
Drives: 2015 BMW M235i
if you aren't planning on tuning then it might be worth it just for peace of mind. I would stick with BMW certified only though. I've heard nightmare stories of some third party programs.
rainfall161.50 |
11-22-2018, 11:24 AM | #5 |
Rep 780
I’m at 57,xxx miles and have only had a coolant hose get nicked when a rock hit the retaining clip on the highway. It fell and rubbed the belt- was the reservoir hose so no overheating (had a obd reader telling me temps). Easy warranty fix no issues since. Running e85 and jb4
11-22-2018, 12:11 PM | #6 |
Rep 30
Drives: 2015 M235i, Alpine White, Cora
I bought my 2015 M235i XDrive CPO with 62,000km on it in April 2018 and now have 80,000km. Since owning I have had the following work completed.
- Front Left Control Arm - Front Left Strut - Front Right Strut *Note these first three items were to chase down a loose rattle sound over bumps* - Rear Output Shaft Seal - Valve Gasket - Passenger Door Pull & Lock Assembly - Transfer Case Fully Replaced Let's just say I'm glad I got the extended warranty. This is my second BMW both were not very reliable. But that is/was expected. BMW = Buy More Warranty |
11-24-2018, 12:20 AM | #8 |
Rep 260
11-24-2018, 07:49 AM | #9 | |
Rep 89
The main warranty issue I had was at 900 miles when the FEM (fronted electronics module) flat out failed. All electronics on the car except tail lights died and had to get a tow. Car sat at the dealer ship over the weekend so the battery was dead too. They replaced FEM and battery under warranty and sent a 500 dollar check for the inconvenience. I call the FEM failure a fluke so overall I feel I have had good luck with the car since that early incident. Worth noting for the tail lights my car is kept outside so not that the lights should leak but it gets 100% of the south eastern PA seasons. |
11-24-2018, 10:07 AM | #10 |
Rep 5,538
11-24-2018, 10:13 AM | #11 |
Rep 5,538
The small issues were: for whatever reason 1 time my fuel gauge light stopped working, apparently dealer knew about this issue or had some fault code or something so they ended up replacing the entire cluster. another famous issues is the audio amp, sometimes it stops working and then was fine after restart, they installed new amp, no more issues
rainfall161.50 |
11-25-2018, 03:16 PM | #12 |
Rep 395
very helpful answers! With these answers in hand and given that I drive like grandma 80% of the time and a responsible adult the other 20%, I don't think I'll be getting the extended warranty.
11-25-2018, 04:08 PM | #13 |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
51,000 miles, I'd say about 13,000 with tune. No engine issues so far *knocks on wood*
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
11-25-2018, 07:07 PM | #14 |
Rep 5,538
I think BMWs are pretty reliable cars....at least until 50k miles. What happens after I dont know. Also I dont think it make a difference how you drive. I used to believe that driving like grandma will keep your car trouble free, that is until I bought S2000 and red lined it every single day many times per day. I had zero issues up until I sold it like new with 80k miles. After that I stopped babying my cars and no issues so far with my BMW or Lexus. I dont red line them, but I drive the way I like
11-25-2018, 07:37 PM | #15 |
Rep 5,372
I've got 30K miles and closing in on 3 years with my 2016 M235 6MT. No warranty issues or problems to report. On very occasions, my subs will stop working, but it's easily addressed by stopping the engine, letting the car go through a full shutdown, and then the subs come back on. It's been a known issue for years with no fix.
Long terms issues with the N55? 1) Valve cover gasket. It will likely leak within 5 years. 2) Oil filter housing gasket. It will likely leak within 5 years. 3) Overflow coolant line from radiator house to expansion tank. It will likely break within 5 years. 4) Charge pipe. It will likely break within 5 years. 5) Water pump. It will likely fail within 5-7 years. 6) Transfer case on X Drive models. There seems to be a high number of failures with these. IMO, save the money and roll the dice. The chances of all of these things happening are low. You should expect to be paying $1,000/yr to maintain a 4+ y/o BMW, some years worse than others and some better than others.
11-26-2018, 05:09 AM | #16 | |
Rep 520
Is the N55 really that bad?? |
11-26-2018, 09:42 AM | #17 |
3626
Rep 3,594
The N54 we had for 8 years never had any issues other than valve carbon build-up which seems to be a lot less on the N55, I'm sure the N55 being a slight derivative outside the only major change from twin turbo to twin-scroll turbo, wouldn't be significantly different in reliability.
11-26-2018, 09:50 AM | #18 |
Rep 1,931
MAF sensors will need replacing probably, also the O rings i have heard do rot, especially if they dont change the one in the oil filter housing, or the one on the left side of the intake tube.
www.nybmwcca.org
11-26-2018, 10:43 AM | #19 | ||
E4 Mafia
325
Rep 412
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
outside of the charge pipe and transfer case, those issues have been staples of BMW engines for a long time including the M54.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
11-26-2018, 01:37 PM | #20 | |
Rep 5,372
All the repairs for the N55 I noted are easily done by a DIYer or indy BMW shop for less than $1,000 except for the transfer case.
11-26-2018, 02:37 PM | #21 |
Rep 520
Wow, aside from an alternator and one leak, it was routine servicing and service-replacement parts only for 122,000 miles. There’s a myth in Britain that the M54 is bombproof and trouble-free; possibly a little cognitive dissonance creeping in!
11-26-2018, 07:58 PM | #22 |
Rep 109
Mine failed too! Sounds like yours really up and killed itself. I brought my car in for a failed windshield washer pump at around 20k miles and ended up having to get the FEM module replaced. I thought it was a fluke as well so hopefully we're the only ones!
