04-02-2016, 08:21 PM | #1 |
Member
899
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
2 Series rated as "Moderate" lighting
Just picked this up from the F15 X5 forum regarding our 2 series rating on our headlights http://www.iihs.org/iihs/news/deskto...ed-improvement
http://www.iihs.org/iihs/ratings/veh...s-2-door-coupe The performance of the HID headlights with and without automatic switching is the same in the IIHS tests. Presumably a driver could activate high beams when it is safe to do so as efficiently as the automatic system. However, the IIHS article states for HID headlamps with automatic switching: "High-beam assist compensates for some limitations of this vehicle's low beams on the straightaway and on both left curves." This apparently justifies the higher "marginal" rating for the HID headlamps when equipped with automatic switching. Last edited by X54TH; 04-02-2016 at 09:53 PM.. |
04-02-2016, 09:20 PM | #2 |
Rep 6,938
Drives: 2018 M2 AW DCT
Neither of your links work. I heard that the halogen lights on the 228i rated poor.
04-02-2016, 09:56 PM | #3 |
Member
899
Rep 2,032
They should be fixed now. Sorry about that.
Here is the report on the 2 series. http://www.iihs.org/iihs/ratings/veh...s-2-door-coupe |
04-03-2016, 09:18 AM | #4 |
Rep 6,990
It's still BS - I can see WAY more than 130 feet in both my 335i and 228i, which are equipped with HIDs. Turning on the high beams makes things show up hundreds of feet ahead, particularly reflective signs or deer/other animal eyes.
04-03-2016, 07:15 PM | #5 |
Member
899
Rep 2,032
I'm going to get my coding guy to code the following for the M235. These options are decoded for the US and Canada. This should enhance the lighting.
Enable Anti Dazzle High Beam Assist Enable Variable Light Distribution VLD: This allows the light beam to adapt according to vehicle speed. When driving in the city, a low beam is used to better illuminate the road immediately ahead without dazzling oncoming drivers. Then at higher speeds, the headlamps are raised to increase visibility. |
04-11-2016, 11:36 AM | #7 |
Rep 5,372
I have to agree here. My last two cars (G35, WRX) as well as my wife's 2015 Outback have HIDs and I find the xenons in my M235 to be fine on dark roads and lit roads and better than the noted cars in terms of light and cut off. I never once thought about the headlights in my M235 being poor. I rent tons of cars for work and none of them have HIDs. They're all terrible and it feels like you're driving in heavy rain.
04-11-2016, 11:39 AM | #8 |
Rep 3,256
Honestly, I think the headlights are poor. My S2000 had vastly superior HIDs in terms of brightness and clarity. The beam cutoff was more distinct. Granted it didn't have auto-leveling or the ability to turn with the road, but the feature is useless when the lights are basically pointed down. I need to go back and adjust the lights but so far I'm unimpressed.
04-11-2016, 11:52 AM | #9 | |
Rep 3,842
04-11-2016, 12:41 PM | #10 | |
Rep 3,256
I don't think the software works with a mac which is my home computer. Might pick up a cheap one either off ebay, best buy, or that shady guy down the street that always seems to have electronics. Do you have the euro codes loaded in your car? If so, what are your thoughts? |
04-11-2016, 12:48 PM | #11 |
Rep 229
These tests are good. Hopefully they will push the manufacturers into better designs, and NHTSA into more modern regulations. And maybe pressure BMW into no longer selling crappy standard lights. If their safety ratings take a hit, they will notice, it's bad for business.
I pretty much agree with the test results. The Xenons aren't awful, but they leave a lot to be desired. No reason they can't be better, especially considering lights on some cheaper cars performed better on the test. Marginal is about right. |
04-11-2016, 01:08 PM | #12 | |
Rep 417
Also, this test is kind of limited since they only test one car with a certain light setup. But that said, the consistency across the range of all the tested 2ers is concerning. |
04-12-2016, 05:01 AM | #13 | |
Rep 3,842
There has been some controversy as to whether our US cars have the same hardware needed for the Euro light coding. My car was "decoded" after manufacture so I'm going to give it a try. PM me if you are interested in a collaborative effort, SD here. |
04-12-2016, 06:54 AM | #14 |
Member
899
Rep 2,032
The North American cars can be coded for:
Anti Dazzle High Beam Assist Variable Light Distribution Definitions according to the coding sheet and my coding guy. He has successfully coded both. ADHBA: Enable multi-stage High beam assist… will turn high beams individually on/off depending on oncoming traffic. VLD: This allows the light beam to adapt according to vehicle speed. When driving in the city, a low beam is used to better illuminate the road immediately ahead without dazzling oncoming drivers. Then at higher speeds, the headlamps are raised to increase visibility. Attached is the coding sheet for the F22. |
04-12-2016, 11:22 AM | #15 | |
Rep 3,842
04-12-2016, 12:20 PM | #16 |
Rep 1,184
I've actually thought my beams seemed low. I ended up adjusting them up a little bit and they are waaaay better. I also did have a couple friends drive by me to make sure they weren't aimed too high.
I think the xenon's are actually quite good just aimed too low from the factory. I've head if you bring it back to the dealership and tell them to "please raise them to the highest legal limit" people have had good results. |
04-12-2016, 12:34 PM | #17 | |
Rep 5,372
04-12-2016, 01:11 PM | #18 | |
Rep 1,184
Made a huge difference and I don't think it's obnoxiously high. I've checked it myself from down the road sitting in another car. I have also never been flashed in the 5 months since I raised them. |
04-13-2016, 03:05 PM | #19 | |
Rep 281
04-13-2016, 03:57 PM | #20 |
Member
899
Rep 2,032
Not sure but we ordered it with High Beam Assist and every other option (except the power lumbar option). My coding guy has all the details through the VIN and indicated all of it can be coded. So, not sure what happens if you don't have HBA.
05-01-2016, 08:26 PM | #21 | |
Rep 26
05-02-2016, 10:51 AM | #22 |
Rep 5,372
I did 2.5 turns on mine and the seemed to help, even though I never found the stock lighting terrible at all, maybe just a bit low.
