2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M235i CLICKING NOISE
      10-01-2015, 07:44 AM   #23
five3three
Drives: m2c
Does anyone have a link to the service bulletin that applies to this? I went in a few months back for this issue and the end result was told it was normal. I may have them do the work when I go in for my upcoming oil change.
      10-01-2015, 05:26 PM   #24
bobby66
There is a SIB about that SI B34 08 14: Ticking Noise from Front Axle When Cornering
SITUATION
The customer may complain of a ticking noise from the front axle when cornering, maneuvering, parking or
pulling away from a parking space. The noise can be heard as a light metallic ticking from the front outer
cornering wheel.
CAUSE
Movement between the brake disc and wheel bearing hub.
CORRECTION
Remove and clean the front axle brake discs.
Sand the hub surface on the brake disc
to the wheel bearing hub using 80-grit
sandpaper.
Sand the surface in a radial motion
(inside to outside around the surface.
Clean the wheel bearing hub surface.
Important!!
Do not sand the hub surface.
Do not apply any type of lubricant to
the components surface (wheel bearing
or brake disc).
Reinstall the front axle brake discs.
I brought this to the dealership, they took note of this and made fixes by cleaning the hub, sanding the rotors (apparently my turns were very aggressive causing a lot of uneven grooves in the rotor, sand pads and clean up a lot of brake dust).
