01-08-2015, 09:44 PM | #1 |
Rep 1,503
Annoying shift indicator (6MT)
Anybody else think that the shift indicators in our cars are annoying?
Even when I'm in sport mode its telling me to go into 5th when I'm at 3rd at 2500rpm. Is there a way get rid of this in the settings? Or perhaps change this to a gear indicator instead (showing me which gear I'm in) |
01-08-2015, 09:47 PM | #2 |
Resident BMW Fanboy
259
Rep 866
Yeah, go to settings and into the instrument cluster options. You can "uncheck" the shift point indicator.
The shift point indicator is a good idea to save gas, but i find that it's kind of hard to shift up without using up the clutch too much at those low-rpms because the revs drop so quickly.
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
01-08-2015, 10:13 PM | #3 | |
Rep 1,503
01-08-2015, 10:14 PM | #4 |
Resident BMW Fanboy
259
Rep 866
I don't remember the exact lable but it should be the 2nd thing that you can uncheck. it's definitely in the top 4.
01-09-2015, 06:37 AM | #5 |
Rep 809
Drives: 2014 228i Msport
Yep I find it annoying also but on my 228 it only shows up in Econ and comfort mode, dosnt do it it sport or sport plus mode
A peasant and proud of it
Save The Manuals!!! |
01-09-2015, 09:02 PM | #8 |
Rep 1,503
Can't seem to find it anywhere :/
Does someone know the exact procedure here? It shows in sport and sport+ for me Last edited by ocN55; 01-09-2015 at 09:51 PM.. |
01-09-2015, 10:54 PM | #9 | |
Rep 26
edit: I just went out an checked, because you asked for exact steps. Go to the main menu, then select "Settings." The very first item is "Instrument cluster." Select that, then disable "Shift point indicator." Take some time to go through the menus while you're there. You might find some other interesting items. JB |
01-10-2015, 12:13 AM | #10 | |
Rep 1,503
Control Display (under this I only see brightness for the display) Time/Date Language I don't have premium or tech package, could that be the reason why we have different things? |
01-10-2015, 12:32 AM | #11 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Thank god I don't have this - I might put my fist through the cluster.
I think I know when to shift - hint, that's why I got the manual.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
01-10-2015, 11:10 AM | #12 |
Mensch
60
Rep 122
No dice on my 228i. Brightness for center display and drive mode are the only options. Gonna see if the dealer can disable it when it goes in for service. If I wanted a car to tell me when to shift I'd get a Prius.
01-10-2015, 02:32 PM | #13 | ||
Rep 809
01-10-2015, 03:16 PM | #14 | |
Rep 24
01-10-2015, 03:57 PM | #15 |
Rep 321
I have the premium package on my M Sport 228i. I have the shift arrows in comfort...and I've never put the car into eco..but I imagine they're there too.
01-11-2015, 12:16 AM | #16 |
Rep 721
If you have the extended display in the cluster it will also show you icons of a foot pressing on the gas too much and a shift knob as well as reminders to drive more economically. It also tells you how much extra you will be able to travel on a tank from having driven in eco pro. Most I've seen over a tank is about 3-4 miles, but I don't put it in eco pro often and never for a whole tank driving around town.
01-11-2015, 12:21 AM | #17 |
Rep 1,503
I think it is telling me to shift a little later but... I still find myself in 3rd at like 2500rpm and then it says 5 or even 6 in the center cluster, insisting me to upshift into that gear
01-11-2015, 06:00 AM | #18 | |
Rep 321
01-11-2015, 06:05 AM | #19 |
Rep 721
Yes its for eco pro mode. Its hilarious how lazy the throttle gets. If you stomp on it though it will still accelerate hard, you just need to coax it into doing so.
01-11-2015, 01:31 PM | #20 | |
Rep 1,503
01-12-2015, 03:49 PM | #21 |
Resident BMW Fanboy
259
Rep 866
I guess you can only disable it on the extended display (aka you have tech package).
01-12-2015, 04:02 PM | #22 |
Rep 587
Drives: 2020 M2C
