01-28-2018, 07:23 PM | #1 |
Rep 18
Deer Collision/Repair headlight replacement?
A deer ran into the driver side fender and I think its head hit the headlight. The rest of the front end is fine. The DRL and turn lamps don't work but main light works fine. I looked at the assembly and the housing was pushed back and the brackets cracked. Maybe wire got spliced too but I haven't removed the bumper. A DIY would cost more since the headlight is almost $1,400 + fender/paint job. My deductible is $500. But, the shop said they need the car from Tues-Mon. Seems kind of long and worried of joy rides.
Any suggestions? Junkyard for the headlight maybe? I can post pics tomorrow since it's running late. Any help is appreciated. |
01-28-2018, 07:53 PM | #2 | |
Kingslayer
411
Rep 1,479
01-28-2018, 08:58 PM | #3 |
NewFinishColumbia/detailer
604
Rep 2,096
There is always underlying damages with incidents like that. Take it to a reputable shop through your insurance company and you should be fine. They have adjusters that regularly stop by the shops unannounced and check on customers cars. The good insurance companies do anyway.
01-29-2018, 05:16 AM | #4 |
Rep 18
Thanks. I have USAA and this is one of their preferred shops. I just don’t get the amount of days it will take. I worked fabrication before and painted and it seems like a 3 day job. Things should be fine and I’ll post my updates.
Thanks! |
01-29-2018, 07:37 AM | #6 |
604
Rep 2,096
I have USAA also and have used the preferred shop. They even repainted my front bumper over a year later because the clear was flaking off in the spots where it flexed a lot. Rental car and all. Because I used the preferred shop they warranty the work lifetime.
BM235iW97.00 |
01-29-2018, 06:25 PM | #7 |
Rep 1,154
Good advice. You have to pony up $500 anyway so why not get it done right and make sure there is no additional damage. Write down the mileage before you drop it off if you are worried about joy rides. Good shops don't usually go for joy rides.
01-29-2018, 10:31 PM | #8 |
Rep 114
Even though it's a preferred shop, that shouldn't mean you can't look around. I took mine to a BMW certified collision shop. The parts are warrantied 2 years and if you have paint issues its lifetime.
01-30-2018, 08:47 AM | #9 |
Rep 2,870
Definitely take it to the pros - internal damage can be a real issue, especially if it tweaked the radiator support or a/t else structural; you are already seeing what the headlights cost, not to mention the aggravation of not getting things lined up right and aimed properly.
01-31-2018, 10:29 PM | #10 |
Rep 108
I'd lower my Comprehensive deductible after turning this claim in - keep it in the $100-$300 range, it's not the expensive part of your premium. Hitting an animal is actually a comp claim and not a collision so the claim itself won't likely cause a premium increase. Just my two cents - and as others have noted, take it to a certified BMW center you won't regret it.
02-01-2018, 09:39 PM | #11 |
Rep 18
Thanks for all the responses. It isn’t about forking out the money. Just wanted to see a about the length of the repair with the amount of damage. I asked a friend that does classic car restoration with his dad but he is busy. He said 2 days for them with the amount of damage. I’m assuming with getting the headlamp will take a few days. It’s been scheduled 👍
02-01-2018, 09:43 PM | #12 |
Rep 18
