2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Crazy instrument cluster
      01-02-2018, 03:24 PM   #1
Sha
Drives: i8, X6M, X1
Hi. 21k on the clock. Came at a stop light and greeted with a lightshow. Anyone have any ideas why?
      01-02-2018, 07:36 PM   #2
wjjkoevoets
Bright Sky
wjjkoevoets's Avatar
Netherlands
1164
Drives: BMW M235i (8AT)
2014 BMW M235i  [0.00]
Seems like the cluster is rebooting. I would think faulty cluster or a short circuit.
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive.
      01-02-2018, 07:43 PM   #3
overcoil
Drives: M235i 6spd
I think I read of this being like a one time occurance with some other 2-series owners - thought I read about it here
      01-02-2018, 11:51 PM   #4
rmastbro
Drives: 2016 M235i EBII
Did you have your navigation programmed with a route enabled ?
      01-03-2018, 12:00 AM   #5
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Yes I remember seeing a similar video before too....
      01-03-2018, 12:28 AM   #6
rmastbro
http://www.2addicts.com/forums/showt...o#post21166877
      01-03-2018, 12:51 AM   #7
kevinf
Drives: BMW 228i
I was the OP in the above linked thread. I was seeing the issue only under the condition of being at a specific intersection and navigation active with a route. It was fixed after a software update. I will see if I can find the work order for this
      01-03-2018, 08:16 AM   #8
MarcoZandrini
Drives: 2018 M240i
There’s a software update for the gauge cluster. The dealer will install the update for free. It takes about 2.5 hours for the software to load. What are they using, an RS32 cable?
      01-27-2018, 04:24 PM   #9
Sha
Drives: i8, X6M, X1
Thanks for the replies, i checked the other threads and they seem to line up. Nav was on, some part of orlando, can replicate it any time i drive there. Nothing urgent i suppose so im waiting till my next service appt.
      02-01-2018, 11:56 AM   #10
rmastbro
Simple temporary fix ...
I was also having issues with my 2016 M235i and found a temporary fix or permanent if you don't care about showing the turn by turn on instrument cluster.
As many others have already pointed out, the problem is related to the navigation displaying the turn-by-turn directions on the instrument cluster and here is a simple fix until you have time to goto the dealer to update the navi code.
Goto Main Menu -> Settings -> Instrument Cluster
Uncheck Navigation
