2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Can't hear active sound on M235i
      04-11-2015, 07:37 PM   #1
wjones14
wjones14's Avatar
659
Drives: 2021 M2C
Just picked up my M235i yesterday! More about the awesome PCD experience later...
But, after reading so much about the active sound coming through the speakers, I don't hear it at all.
Mine is a manual transmission with port-installed Performance Exhaust and Rear Diffuser. In normal driving, I can hardly hear the exhaust at all, and there doesn't seem to be anything coming from the speakers. Only when I open the window do I hear the great sound coming from that exhaust.
Could it somehow have been programmed out when the MPE was installed? Or is there somewhere in the iDrive where the active sound can be disabled or adjusted for volume?
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT
      04-11-2015, 07:43 PM   #2
Xiaoxi
Xiaoxi's Avatar
269
Drives: a Miata
Congratulations!
The active sound is not nearly as prominent as people who whine about it make it out to be. It's very subtle. However, you can turn it up a little in iDrive main Settings -> Tone -> Speed
But bear in mind even cranked max it will not sound nearly as loud as your Mustang from inside the cabin. There's too much sound dampening.
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass
ig: @bee2ven
      04-11-2015, 08:12 PM   #3
MrBucket
Drives: '17 AW M2 6MT Exec Pack
Its there, its just that seamless that you cant really tell what is the actual exhaust/engine and what is the sound symposer. I have the M Performance exhaust and an intake and the car finally sounds loud enough. I honestly think the intake did more for the sound than the exhaust too.
      04-11-2015, 08:15 PM   #4
overcoil
Drives: M235i 6spd
Are you sure your in SPORT mode ?
      04-11-2015, 08:26 PM   #5
wjones14
wjones14's Avatar
659
Drives: 2021 M2C
Originally Posted by Xiaoxi View Post
Congratulations!
Yep, in Sport mode. Already getting in the habit of turning on the electronics, pressing Sport button, and then starting the engine.
Thanks Xiaoxi for the tip about the iDrive setting! Just went out to the garage and looked at that and AS volume was 1. I changed it to 10. Can't wait to hear it tomorrow.
      04-11-2015, 09:22 PM   #6
Zooks527
There's another thread that Active Sound may have been removed from the cars of late. It was certainly prominent when I was test driving cars, and very noticeable when you tapped the mode between comfort and sport (even with the gear locked in manual mode).
      04-11-2015, 09:53 PM   #7
Supernaut
Little Deuce Coupe
Supernaut's Avatar
Drives: SO M2C
I was told at PCD that the Speed adjustment was to increase stereo volume as the car increased speed, not an Active Sound adjustment.
Our cars were produced at about the same time, and I feel that active sound is pretty prominent. I notice mostly the MP exhaust at startup, but I think, the AS when driving. Hard to say for certain.
The MP exhaust sounded great in the delivery room, didn't it? When the adviser started my car up, it drew a small crowd and made my hair stand up.
And congrats on taking delivery!
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD
2020 Sunset Orange M2C|6MT|Black 788s
      04-12-2015, 08:42 AM   #8
drivethemachine
drivethemachine's Avatar
193
Drives: 2018 BMW 530e
Yea that "Speed" setting has nothing to do with ASD. It lets set how much the music volume should be increased as you go faster. (To compensate for wind noise.)
      04-12-2015, 11:25 AM   #9
worktolivelife
Drives: Mine
As BMW choose to implement ASD into the cars audio system it would seem logical/ desirable from design point of view to also make it speed related with regards volume? . Curiousity is going to get the better of me gonna have to just see for myself now
      04-12-2015, 11:58 AM   #10
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
No. ASD volume is independent of anything you can configure through idrive
      04-12-2015, 12:03 PM   #11
pikcachu
pikcachu's Avatar
1399
Should be really easy to test.
Throttle up to constant 2k rpm and switch from comfort to sport back and forth, you should be able to easily notice the sound going up and down
      04-12-2015, 01:47 PM   #12
Zooks527
If you have an automatic, switch to manual mode and select a gear before doing this, otherwise you'll also get an effect from the RPM changing.
      04-12-2015, 03:19 PM   #13
pikcachu
pikcachu's Avatar
1399
I mean do it in neutral or park
      04-12-2015, 04:01 PM   #14
Zooks527
Ah, makes sense.
      04-12-2015, 04:18 PM   #15
wjones14
wjones14's Avatar
659
Drives: 2021 M2C
Okay, I do hear it. It's very subtle and almost unnoticeable, but I can hear it (barely) when switching between Sport and Comfort mode at 2K rpm in neutral. I was expecting it to be much more pronounced based on what I had read prior to hearing it myself.
Thanks pikcachu for that simple test.
      04-12-2015, 05:38 PM   #16
pikcachu
pikcachu's Avatar
1399
It's more noticeable also around 3.5-4k rpm also
Ya it's not like it will blow your ears
      04-12-2015, 06:12 PM   #17
3.0L
3.0L's Avatar
8935
Drives: M235i, 20k miles
I thought the "Speed" setting was to give you an audible "Bling" warning when you exceed the speed you chose. I have mine set at 75 MPH and it "blings" me when I exceed that speed. I good babysitter when booking down the freeway.
When writing your life's plan, use a pencil with an eraser
      04-12-2015, 07:41 PM   #18
mmmmm235i
mmmmm235i's Avatar
104
Drives: 440xi GC
I agree, never really heard the sound that prominently. For this reason, however, I had the active sound coded permanently off. Never really noticed a difference, but I like to know what I'm hearing is actually the car and not the stereo.
2020 X3M Comp., Alpine White on Black/Beige
RETIRED:
2018 440xi GC, Carbon Black on Black/Blue
2014 M235i Black on Black, DINAN Stage 2
      04-12-2015, 08:03 PM   #19
Supernaut
Little Deuce Coupe
Supernaut's Avatar
Drives: SO M2C
After driving around today with the windows down, I'm getting more MP exhaust and less Active Sound than I thought.
      04-12-2015, 10:31 PM   #20
335BOY
Drives: 2017 SQ5
I think that's the whole idea. You're not supposed to hear it directly.
      04-13-2015, 06:02 AM   #21
angler
love to fish!
angler's Avatar
46
Drives: 13: SG 135i M-Sport Cabrio 6mt
Should have bought a convertible then you would hear it!
PSS|PPK|PE|LUX H8 V4's|CDV Delete|Performance Pedals|Motorsport Emblem|
