2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions How to code the Steering (EPS) on an F series BMW
      03-24-2023, 10:32 PM   #1
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
Credit: speedsnice https://f87.bimmerpost.com/forums/sh...81&postcount=3
In this thread I will be teaching you how to code the steering rack (otherwise known as the EPS) as this process should be almost the same on any F series BMW. But the instructions will be specific to my m2 so I cannot guarantee that they will work on other cars, so you can search on the forum of what modules you may need to code to get the desired results if my instructions are not the same for your car. Again I will be talking about coding in context of my 2017 BMW M2, on ISTEP level F020-19-07-539, so what I may be able to do might be different to what you will be able to do as there is a difference in vehicle and software version.
So before we begin you may ask why would I want to code my steering rack? The reason why is because BMW programs these steering racks differently from car to car, and this different programming has significantly different behaviors. Some programming/codings make the steering wheel super light for comfort, this is typically present on non M BMW’s and is typically geared for the luxury feel - meaning you sacrifice alot of steering feel and precision. Some steering feels are extremely heavy to the point where you have to fight the wheel and lose precision, like the stock F87 steering coding. Some steering feels are absolutely perfect in my opinion, and that is the F87cs coding. So having the ability to select different “codings” will allow you to better tailor the car to your desired steering feel, instead of being forced to deal with what BMW gave you from the factory.
Now you may ask how is this possible? Well the answer to that question is because the M2, M2C, M2CS, M3, M3CS, M4, M4CS, and M4 GTS (the non M models also share their own steering racks, and the SUV’s will share their own rack as well) all share the same electronic power steering rack: https://www.realoem.com/bmw/enUS/par...&q=32107852660. The only difference is the programming or coding that is used to operate the steering rack currently selected in the EPS’s ecu, otherwise they are all the same. The good thing about this is BMW does not have bespoke software for each car. Instead they have a bunch of “codings/programmings” in the EPS’s ecu that are toggled to a specific car. So essentially you will already have all the different codings available, all you have to do is set which one you want. The only exception to this is if your car’s current software level otherwise known as ISTEP has those codings available, aka if your car’s software is too old chances are you won’t have the GTS or CS settings. Of course the model of your car will affect this too.
The last question you may have is what do you use to code these things? Well my answer to that is either BMW’s special software called ESYS (which I will not be explaining in this thread), or Protool which is an android app that allows you to code everything ESYS can.
Here is a link to my review on protool explaining everything a bit more in depth, and why you really should buy this app over the alternatives: https://www.2addicts.com/forums/show...9#post29968569
Disclaimer:
Damage/Injury Disclaimer: Any technical advice, coding advice, installation instruction, or product installation demonstrated in my reviews is to be done at your own risk. I will not be responsible for personal injuries, injuries to others or any living being, or any damage to your car, or any property damage.
Coding these advanced features like the GHAS (differential), power steering (EPS), and DSC (traction control) can be very dangerous as it causes your car to behave much differently than before. So proceed with caution. Again I will not be responsible for any outcome that occurs due to you (the reader) using my instructions to code a car.
Monetary disclaimer: I do not make commission, or profits or any kind of monetary gain from the sale of this App (Protool).
Image Credits:
Images and videos used in this review are all property of their rightful owners as credited below each image, I am just using them for the purpose of this review but if you (the owner of the image) would like them removed please let me know via pm. Otherwise thanks to the respective image owners (I made sure to credit your online name and link where I found the photo) of the photos, without you this review would be so much more bland.
Before we start talking more about coding, I would like to give some tips on how to code your car safely:
Make back ups before you code, this way if something goes wrong you are able to revert your car back to factory settings.
Make sure you know exactly what you are doing before you code. This means doing plenty of research on what coding you will be doing, what the changes itself does, what ecus need to be coded and how to make the changes, and of course if the coding you want to do is available for your car.
Make sure you have an appropriate (and good quality) battery charger to keep your car powered while you code, because if your battery drops below a certain voltage while coding your car will shut off and this can leave the car bricked. For some coding you can leave the engine running while coding, but do not drive while coding.
Use quality cables/wireless adapters - cheapo adapters/cables are slow and can fail part way through the flashing process. In the past I have purchased cheap enet cables from aliexpress, and while on the outside they look clean and good quality. When I opened the obd2 shell I saw how terribly put together they were, the wires were stripped extremely poorly and the cables had patches of exposed copper all over the place. This could lead to a short if the adjacent exposed wires touched, and that would be bad news for the car.
Read the protool’s user guide completely and thoroughly before you begin, failure to do so can result in damage to your car.
How to code the EPS/Steering rack:
Step 0: Connect a battery charger to your car, if it dies during coding you may brick it. Connect only to the under hood terminals not directly to the battery to avoid damaging the IBS. Make sure you read the protools manual before starting to code, failure to do so can result in damage to your car.
Step 1: Connect to your car with protool, after this step you should see a menu screen like so:
Credit: F87Source
Credit: F87source
Credit: F87source
Step 2: From the menu screen you will tap on the Electric Steering (EPS) box under the chassis heading, and the following screen will pop up.
Credit: F87source
Step 3: Click on the coding option and the following screen will pop up:
Credit: F87source
Step 4: From this screen you will click edit coding and the following disclaimer will pop up:
Credit: F87source
Step 4: click confirm and back up the current coding for your car. This is a critical step incase errors were to occur. Afterwards the following menu will be displayed:
Credit: F87source
Credit: F87source
Credit: F87source
Credit: F87source
Step 5: Scroll down to “Variantencodierung Normal” and click on it, the following steering coding options will show up (these options are the chassis codes for each possible car, typically you should code only the chassis codes that share the same steering rack as your car otherwise you risk damage. So for example the m2 can have the m3 and m4 codings and vice versa, as they share the same rack. If in doubt look on the forums to see what others have done before doing anything risky. If you code a non compatible chassis you can get errors, also avoid the not supported, custom, or veh options - only select valid chassis codes AGAIN IF YOU ARE UNSURE DON’T DO IT, RESEARCH THINGS CAREFULLY).
Credit: F87source
Credit: F87source
Credit: F87source
Step 6: select on the desired chassis code, for me I selected F087CS. Once you have done so click on confirm, and then finalize to finish coding your car. You may be told to cycle the ignition afterwards, so follow the instructions on your screen.
Step 7: Disconnect from the car and you are done! If there are any other instructions to follow protool will let you know and you should follow them. Otherwise enjoy your new EPS/steering rack coding!
https://f87.bimmerpost.com/forums/sh...2#post30368242
      03-24-2023, 10:33 PM   #2
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
Reserved for future posts.
      03-25-2023, 03:31 PM   #3
Kernel Kurtz
Kernel Kurtz's Avatar
347
Drives: 2020 M240i xDrive
Interesting, thanks. Will be watching this thread.
I've coded the EPS max-current value down from 105 to 85 amps on my F22 using Protool. This has had the effect of making both the comfort and sport mode steering heavier, and is an improvement, but comfort is still too light. Obviously nothing is going to improve the overall road feedback of EPS, but there are certainly improvements in feel to be had.
When it warms up a bit more here I plan to look further into other coding options for the steering, and this gives me another place to look. Hopefully others can share their experience here. I will be sure to do so. Cheers.
F87source7255.00
      03-25-2023, 03:54 PM   #4
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
I'm not sure if you have access to gts mode, but if you like heavy steering that was pretty good. Then f87 was the heaviest by far, to the point where I personally found it uncomfortable.
      05-07-2023, 10:57 AM   #5
juantg93
juantg93's Avatar
Spain
Drives: BMW F22
I have a f22. And i code eps for 4-series. I think is better.
      05-07-2023, 05:19 PM   #6
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
That's great to hear!
      05-09-2023, 04:33 PM   #7
juantg93
juantg93's Avatar
Spain
Drives: BMW F22
In the variant selection profiles there is also the m235i racing variant, which I am curious to try.
      05-09-2023, 04:56 PM   #8
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
I believe the m235i shares the same steering rack as the m235ir (as per real OEM) so that coding shouldn't be a problem. Try it out and let us know if you like it.
      05-10-2023, 07:47 AM   #9
LanceM26
LanceM26's Avatar
Drives: BMW M235i, BMW M240iX
Following
      10-12-2023, 03:40 AM   #10
SpencerC_6MT
SpencerC_6MT's Avatar
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
"nobuildlevel"
I've just started messing around with ProTool EPS settings, and I came across something I can't find an explanation for. Every M135i steering config (the default for my pre-LCI M240i) has a "nobuildlevel" counterpart. Can anyone explain what the difference is? Would it be worth coding in?
I'd also love to know about any other settings to sharpen the steering. The 105A -> 85A trick is nice, but not mind-blowing.
      10-12-2023, 04:29 AM   #11
F87source
F87source's Avatar
No_Country
7255
Drives: Bmw M2
Attachment 3297669
Sorry I can't be too much help (since I'm not too well versed on the m135i), but I think you should email protool about this.
      10-12-2023, 02:28 PM   #12
SpencerC_6MT
Just sent them an email - they don't know either Guess it's time to be a trailblazer. FWIW, I have an '17 M240i, the EPS settings are only labeled "M135i". I assume this means I share EPS coding with early F2x cars, a little disappointing since I heard rumors of later cars having better programming. Perhaps it's an LCI-only change.
F87source7255.00
      12-04-2023, 09:44 AM   #13
SpencerC_6MT
Quick bump for anyone still interested: I found an interesting setup that I've been trying for a few days now, and I like the results. Under the 3 "vehiclevariant" settings, I tried switching to the Alpina EPS settings. Think the name is "F030_Alpina_Sdrive", there's also F32/F33 settings. I wasn't sure whether an Alpina-type setup would tend softer or more aggressive than stock BMW, but I found a nice combination of both. At low speed, the wheel is very light, like switching from Sport to Comfort. However, it gets heavier rapidly above 20mph, and at speed, it feels a little heavier than my car's default [F020_Sport_M135i_Nobuildlevel_Sdrive_Vdc]. I specifically appreciate this change because it makes it easier to tell when the steering is "engaging" so to speak. Although slop on-center is inevitable with old bushings, I can actually tell when I'm leaving the "slop zone" and actually turning the car now. It sounds a bit strange, but confidence-inspiring in practice.
Note this is all still on the 85A setting for Max Current
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
Mike F.103.00
      01-29-2024, 03:46 AM   #14
BMW_E_F_G
BMW_E_F_G's Avatar
Netherlands
17
Drives: BMW M550i COMPETITION G30 2017
Hi,
I am going to try this on my G30 M550i.
      02-25-2024, 04:58 PM   #15
SpencerC_6MT
Originally Posted by BMW_E_F_G View Post
Hi,
How did it go? I don't know much about G-chassis coding, I'm curious what options you have and how much difference it can make.
