2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions F22 coding cheat sheet
      10-11-2018, 12:06 AM   #2047
masterfung
Drives: 2018 X5 50i
Hello friends, I need some help! Just bought a 2018 F23 Convertible for the wife.
Trying to code for her NGHB and VLD. I did it on my F15 earlier this year. I already cleared her VO for 8S4 and 5AP. I'm trying to figure out which ECU's I have to code...
Can anyone let me know and which cheat sheet should I use in 3.27? I see a ton of cheat sheets.. Used Almaretto for my F15. Which cheat sheet is specific for F23 (M240 Convertible) codes?
It was hard as heck finding a M240 with Full Adaptive LED's! Car has 160 miles and were breaking it in.. so far.. love it!
Thank you for the help and advice!
      10-11-2018, 12:12 AM   #2048
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Can anyone let me know and which cheat sheet should I use in 3.27? I see a ton of cheat sheets..!
Cannot be done on an F23.
      10-11-2018, 12:17 AM   #2049
masterfung
Drives: 2018 X5 50i
<mind explosion>
Spent to much time trying to find a 2018 M240 with Full adaptive LED's and it can't be done? Wow... !!!!!!!!!!
I do appreciate the quick reply and your cheat sheet for my F15 was awesome...
Now I have to deal with a stomach of disappointment... I'm curious what the difference is if anyone knows?
Thanks for the reply Almaretto.
      10-11-2018, 09:01 AM   #2050
masterfung
Drives: 2018 X5 50i
My car has the Kalfas 2 and has part number S552A.
https://www.mdecoder.com/decode/vc283521
But you sounded sure Almaretto... just want to be 100% before I go cry.
      10-11-2018, 02:50 PM   #2051
Almaretto
Almaretto's Avatar
2374
North American vehicles do not have same fully capable headlights as Euro vehicles. This is the case with F20/F30/LCI F80.
      10-11-2018, 04:10 PM   #2052
masterfung
Drives: 2018 X5 50i
Ok, but I can still enable VLD without issue, just not NGHB?
Thanks again.
      10-11-2018, 07:49 PM   #2053
Almaretto
Almaretto's Avatar
2374
Thanks again.
It will not work completely, but should not cause glairing for other drivers.
      10-11-2018, 10:19 PM   #2054
masterfung
Drives: 2018 X5 50i
      10-23-2018, 05:40 AM   #2055
Avex
Australia
51
Drives: F22 M235i AW
before i begin setting up, do i need to get a premium token direct from the developer (Token Master)? i hear he's difficult to reach and response might take days. Can i still code my car without this token?
      10-23-2018, 01:41 PM   #2056
Almaretto
Almaretto's Avatar
2374
Premium Launcher generates token for you, which is needed for FDL coding.
      10-24-2018, 05:58 AM   #2057
Avex
Australia
51
thanks Almeretto, i had some experience with inpas+k-can+ebidas coding on my e92 so this was surprisingly easy for me to setup. I've already coded 80% of what I wanted, except for the m performance logo on nbt evo and m4 ASD. Which i found out from this thread is a limitation on some 2015 m235is
      10-24-2018, 06:02 AM   #2058
Almaretto
Almaretto's Avatar
2374
Cluster logo is hit or miss. It depends on both chassis and which hardware vehicle has.
Animation changes on CID (IDrive Center Infotainment Display) can be done on any NBT or Evo unit.
ASD is mostly turned off. Customization is no longer possible with newer firmware.
      10-24-2018, 06:05 AM   #2059
Avex
Australia
51
cluster logo worked perfectly for me. got the m performance in the centre cluster and was able to change m235i to m135i 550d, etc.
i'm not too jaded about ASD,the default m235i sound was good enough for me.
      10-24-2018, 06:12 AM   #2060
Avex
Australia
51
i'm trying to code a few lighting features. I've got the left and right blinkers to stay on as a welcome light. But notice the rear and blinkers fade away nicely whereas my angel eyes simply has a hard switch off. I'm hoping to code in a fade away effect as well but the angel eyes are already activated by default - so i'm not sure which setting to tweak.
I'm also trying to code my rear lights to come on permanently like a daytime/night time running lamp which are default on most e92s. Right now it seems to be switched off in the day...
      10-25-2018, 02:05 AM   #2061
Almaretto
Almaretto's Avatar
2374
8TL
      11-27-2018, 05:42 PM   #2062
Raymondo1234
Raymondo1234's Avatar
Drives: 2016 M235xi
Changed my steering wheel to the mperformance with race display, and now I periodically get "cruise control malfunction" warning when starting the car. The cruise control works fine.
Can I use BimmerCode (in expert mode) to change which steering wheel I have? I'm thinking this is the issue.
      11-28-2018, 06:25 PM   #2063
outubro
Drives: 320d
good night
I have a BMW F20 made a retrofit HBA-KAFAS -Kafas camera 9278359 but when active higth beam
I have in bc (camera front) Camera-based driver support systems and the green light of the assistant turns off.
Can someone help?
      12-07-2018, 05:15 PM   #2064
sea_m2c
sea_m2c's Avatar
82
Drives: 2019 M2C - 6MT
I haven't found any threads of people successfully DIY coding the LCI Kombi gauge cluster to a pre-LCI vehicle. Only people who have had coding services done for them.
Has anyone come across the necessary coding for that retrofit or can point me in the direction of an active thread?
Thanks in advance!
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i
      12-11-2018, 07:38 AM   #2065
doughboy
doughboy's Avatar
1546
Drives: 2018 M2 Comp 6MT
This is a great thead!!
I've added 6NS to the FA & VO coded into HU-NBT2 in my 2018 F87 M2 (I think 6NS only effects the HU module, is that correct?)
I've now got 2nd phone option and the car requests access to my phone messages too. I've checked "office" in bluetooth settings, but still no "office" or "messages" menus in Idrive...
Any help or ideas guys?
      12-11-2018, 06:14 PM   #2066
Hammy
Drives: 2019 BMW 440i xdrive
Just got my KIWI3 in the mail and just coded my digital speedo..... man this thing is so easy to use with Bimmercode.
      12-11-2018, 08:24 PM   #2067
Almaretto
Almaretto's Avatar
2374
IOS or Android? For IOS, you have to enable banners or something like that.
      12-12-2018, 12:12 AM   #2068
doughboy
doughboy's Avatar
1546
Android. Thanks..
