11-16-2017, 08:47 AM | #1 |
Rep 1,117
Drives: 2015 BMW M235i
Pure Stage 2 turbo
Guys, just got quoted approx 9hrs labour for this install. Seems a bit high to me. Anyone else have some input?
11-16-2017, 06:55 PM | #3 |
Rep 2,577
Having it done in 9 hours require a very skillful installer and that's even excluding road testing. It took more than half a day for my mechanic to install STG1 and DV+ (though we weren't in a rush, had plenty of time), where you don't have to take off anything other than water pump.
My suggestion would be find someone who has experience and doesn't have to figure out how when working on your car.
Lemania 2320
11-16-2017, 07:22 PM | #4 | |
Rep 1,117
11-17-2017, 07:27 PM | #6 |
Rep 350
I was quoted $1500 for PS2 install and the fuel it PI kit form a reputable shop that has done PS2 installs on N55s before.. Another shop that services many euros and high end cars quoted me $1600 for just PS2 kit and then $2800 total for PS2 and the fueling! So needless to say you know who I will be going with. I'm not sure but the first shops sounds fair considering I'm really not sure how much labor usually is priced for this kit
amw896582.50 |
11-20-2017, 05:16 PM | #7 | |
sillyphuck
17
Rep 44
Drives: 2015 M235i
I looked into Stage 4 Dinan with a big turbo. Quote 10 hours just for labor on the install. The way the Dinan shop i go to made it sound. Its like you damn near have to remove (or fully remove) the entire engine from the vehicle to get to the Turbo... so 9 hours doesnt sound unreasonable. hope that helps |
amw896582.50 |
11-20-2017, 05:58 PM | #8 |
Rep 1,541
Our local shop is considerbly less. They have done quite a few installs. I believe they are an authorized dealer for Pure also.
Installation pricing: $800 if you supply the turbo(s) or $650 if you purchase the turbo(s) from SSR Performance Mike @ SSR Performance SSR Performance
11-21-2017, 02:51 AM | #9 |
Rep 2,357
9 hours is good. Took my shop around 11 hours - never done the install before.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
11-21-2017, 08:30 AM | #10 |
Rep 1,117
Thanks for the feedback fellas. My shop is kind of concerned about the core return and remanufactured turbos.
Are they all refabs? Are Vargas units brand new units? I've heard good things about the Pure setup so I never really second guessed it. |
11-23-2017, 12:40 AM | #11 | |
Rep 190,805
Tell your shop these are the most proven turbo for your car
amw896582.50 Anthony235715.00 |
11-23-2017, 12:39 PM | #12 |
Rep 2,214
What are you planning for tuning/fuel?
I've been seeing some folks running a PS2 "hardware" setup, with JB4 as the tune (custom?) and just the LPFP upgrade. If it's around 4-420whp with this, I'd be pretty convinced it's better than running a full tilt. Any thoughts, on that? I see this happening in winter of next year, for me, but the primary goal is to reach 420whp on pump gas and no Meth. Otherwise I'll keep stock turbo, get a flash tune and run meth on top to achieve my goals. Anything more will disrupt the balance of the car, in my opinion. Great to have available power for 1/4 mile or highway pulls, though..
11-23-2017, 03:18 PM | #13 | |
Rep 1,117
11-23-2017, 09:46 PM | #14 |
Rep 176
No point in upgrading the lpfp, it's the hpfp that's the limiting factor. Port injection is an option, but I think I'm going to pull the trigger and just run 93 gas, which is available where I am. Around 450 whp is perfect for my needs.
At the moment I'm FBO with a custom flash tune from frank smith tuning. Car is around the 380 mark. |
11-24-2017, 03:10 PM | #15 | |
Rep 2,214
Where abouts are you in Onterrible? (I joke, grew up there). I used to have a lot of access to the Petro 94, but I believe it has ethanol ? Either way I ran that stuff steady in all of my cars, without an issue. If you're in a smaller market I could see that being an issue. I couldn't get more than 91, here, until Chevron took over a couple of Shell stations, now have 94oct ethanol free in two local locations and all large markets. To think this is a "problem", we have a good life in front of us, lol..
11-24-2017, 03:21 PM | #16 | |
Rep 1,117
Onterrible! That's awesome and it's true. I'm in Windsor. Shitty gas and even shittier speeding laws. Back on topic though.....BM3 does have different off the shelf maps for various octane levels and even upgraded turbos. We do have the petro 94 but it is loaded with ethanol. The few times I ran it, the car would sputter on starts and I had really crappy fuel economy and it never even felt a bit more responsive. I normally run shell 91 because 0 ethanol and it normally runs great.
Talking to other modders in the area is mixed as well. Some scream by 0 ethanol shell 91 and the others only go for max octane.....I don't know. I might do some additional testing when I bring my car out again in the spring but so far, not loving the ethanol. Quote:
Dylan861330.00 |
11-24-2017, 04:34 PM | #17 | |
Rep 1,931
for 420 no meth or pi, your going to need a turbo upgrade for sure. You can hit 420 on meth and stock turbo. You can get to 400-410 on stock turbo, stock fuel but with lots of octane and a great tune. Highly doubt jb4 will do it, so flash would be ur only option.
www.nybmwcca.org
11-24-2017, 05:12 PM | #18 | ||
Rep 2,214
11-24-2017, 05:34 PM | #19 |
Rep 1,931
road track or drag track?
You dont want a ps2 setup for road track, youll burn those things up in no time. ps2 is a solid product, but many people are already on their 2nd or 3rd set from just doing hard drag and roll racing.
www.nybmwcca.org
11-24-2017, 05:37 PM | #20 |
Rep 1,117
Really?! My tuner expressed some concern as well. I don't really understand the reasons though. Is there a better brand? I mean, if this is case, I might just stay on stock turbo.
11-24-2017, 05:45 PM | #21 |
Rep 1,931
road track puts extreme wear on your parts. your going to be spinning that turbo the entire lap for a 20 minute session or longer. It will burn out very soon. Its a good part, but its not oem. Its like when people put 600hp in a car that started with 300 and wonder why things break. It wasn't designed for that purpose.
if you are thinking about running track days, or open laps, I personally wouldn't even think about a ps2. Which is why i haven't added pi/meth/ or upgraded turbos. That and I already had the upgrade in my n54 and couldnt stand the unreliability. The car in stock form has enough power to over take most v8 cars on the track. Concentrate on your safety/wheel/tire/brake and suspension setup. And most importantly, your driving skills before you add all go fast mods.
www.nybmwcca.org
11-24-2017, 05:54 PM | #22 |
Rep 2,577
Reliability with PS2 comes down to how much boost is thrown at it. PS2 runs a lot cooler than stock turbo under same boost and is not necessarily less durable even with its hot side bored out.
But you're right, ps2 owners tend to push, failure happens when they're making way more power than turbo is designed for.
Lemania 2320
ceedawg467.50 |
